Question about GE GSL25JFXLB (250 cu ft) Side by Side Refrigerator
It appears that the defrost cycle is not working on my GE GSL25JFXB 1B. I need an electrical schematic of the refridgerator and the mother board to trouble shoot it. Where can I get one please. Thanks
  • 744 Answers
SOURCE: My freezer has stopped working - GE Profile
There could a problem with the condenser fan as well. The cost will depend on what they find. Try calling a shop for an estimate. Mke sure they are authorized and qualified to work on your brand. Any warranty left?
Posted on Mar 15, 2009
MNTECH
  • 1543 Answers
SOURCE: Defrost not cycling
Pull the temp dial off inside the fresh foods section and then take the plastic light shield off. You should see a hole in the metal control housing now, on the right side, about the size of a nickel. There is a plastic part in there that you can turn with a flat blade screwdriver. Turn it very slowly clockwise until you hear a click. (Refrig should now be in defrost) If refrig turns itself back on before an hour is up, timer should be OK and I'd check the defrost heater WR49X391 for continuity. If refrig takes a hour or more and has not turned back on, manually turn the part again slowly until it clicks again and the refrig begins to run again. Order a new defrost timer WR9X502. Doors left open or bad door gaskets can also frost up a refrig and would require appropriate action to correct those situations.
Posted on May 11, 2009
SOURCE: where do I get a GE GSS23SGSBSS service manual, I
I took a ohm reading on the cirsuit board between the defrost (J4) and line (J9) terminals and found that the defrost element was open or burned apart
Posted on Aug 15, 2009
aasc
  • 1606 Answers
SOURCE: GE model #GSS201EMBWW is not defrosting, checked
This is how the defrost works . I have NEVER found a defrost problem associated with a bad main control board since these computerized GE's came out in 2000 . Lots of thermistor problems , lying to the board , causing different problems .
Your GSS model refrig does not have a defrost timer . It works off of the main control board . Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Posted on Aug 31, 2010
  • 2468 Answers
SOURCE: I have a GE refrigerator
you can jumper the board where the line cord enters the board,it will say comp/defrost/neutral in the center,jumper between the center terminal and the outer one that says defrost,if it still doesnt defrost you need to disconnect the defrost heater and check for continuity,then do the same with the defrost thermostat,but the thermostat needs to be below freezing to test it or it will show open(bad) the heater will show some resistance to be good
Posted on Apr 06, 2011
My GE refrigerator is no longer cooling. Model GSH25JSTC SS. I just replaced the mother board WR55X10942 and it is still not cooling. Water dispenser, fan is working fine.
Is the compressor running? Is it any good? Is the thermostat control working and cycling the compressor on? Is the self defrost mechanism stuck in defrost cycle (shuts down compressor), etc?
Is the motor getting power?
U need to check all of these areas.
Apr 08, 2015 | GE Refrigerators
Where is the defrost timer located on model GE GSS22JETG WW? This is a side by side
USUALLY LOCATED IN THE FRIDGE AT MIDDLE TOP BUT SOMETIMES CAN BE FOUND IN THE FREEZER ALONG THE WALL
Mar 08, 2015 | GE Refrigerators
Ice maker not working AND food in fridge is freezing
Seems that you have a problem with your controls. Check the timer sequencer and thermostat.
Mar 16, 2014 | Refrigerators
Ge refridgerator model gh405499
From what I know of ge, ice makers are independent. Mother board has no control over I'm. How old is this fridge. Some of the newer ge are made by Samsung and are control.
Nov 03, 2012 | Refrigerators
Ge side by side frig won't defrost gss25sgmb new heater motherboard thermostats
Replace the thermistors #4 and #5 . 4 is the white bullet looking piece on top of the coils inside the freezer , with 2 white wires . 5 is at the bottom of the freezer , on the left side . These thermistors tell the main board , the temp and the board goes into defrost according to temp the thermistors "tell it " .
Aug 14, 2012 | GE GSS25SGMBS Side by Side Refrigerator
Refridgerator , works fine for a few days then it goes into defrost and does not come out until everthing thaws out. I had a new relay switch installed and that helped for about 3 weeks. Computer board...
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
Dec 02, 2010 | GE Refrigerators
The freezer coils load up with ice and stop air flow to the refridgerator and freezer
Likely Defrost heater built into coils. Secondly defrost thermostat mounted at top of coils or computer board in rear that controls defrost cycle. Check heater and thermostat continuity first after unplugging unit.
Aug 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Where is the defrost timer located on ge side bty side model gss25jfmdww
Hi, This model has a mother board instead of a defrost timer. If you are having a defrost issue, the first part you want to test is the defrost heaters. If you need instruction on testing the defrost cycle, please let me know so I can assist you further.
Thanks
Vic
Jul 15, 2009 | GE GSS25JFM Side by Side Refrigerator
Defroster cycle stuck
Unfortunately GE has been having a problem with the main mother boards on your model refer, the mother board controls the defrost cycle and there is not reset for it, you may have a bad board.
Mar 17, 2009 | GE GSS20IEM Side by Side Refrigerator
I have a frigidaire package heat pump,in heat mode it goes into defrost everytime it runs for a few minutes,no matter what the outdoor temp.is..it runs about five minutes or so and goes into defrost for...
That is usually caused by either lack of airflow through the outdoor coils. (Dirty coils, need cleaning)
Bad defrost board. (needs to be diagnosed with multimeter and extensive explinations and/or experience to be sure)
Low refridgerant, causing premature freeze up and in turn causing frequent defrost cycle. (Recharge to proper pressures with proper refridgerant type. Requires EPA certification for use of refridgerant, you would also need refridgerant guages, temperature reading device, and refridgerant.)
Dec 07, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
GE GSL25JFXLB (250 cu ft) Side by Side Refrigerator Logo
29 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
