Cannot get new thermostat to work
I just replaced a cracked plaster wall in my dining room on which an old Honey well t87F 1859 thermostat was mounted. The stat was damaged during the demo and I went a purchased a new Honeywell CT87K. I thought this was a simple install but the furnace (oil, steam radiators) does not switch on when the new stat is installed. If you connect the two wires coming out of the wall directly, the furnace turns on. What am I doing wrong?
  • bobbycagna May 11, 2010
    you have to make sure that the stat wires are on the right terminals. look at your boiler and see where they are. normally the wires on that stat and boiler will be color coded, meaning B would be for a blue wire, r would be for the red wire etc. Let me is this helps.
  • 37 Answers
Didn't wire up correctly or if purchased a digital one didn't set up correctly, look at the instructions and should tell you how to set t-tstat up or if you have to remove or move jumper.
Posted on Apr 25, 2009
How to repair crack between ceiling and wall
Hi simple way is to use some expansion foam from hardware shop squirt it in along the crack it will expand a good bit so no to much cut over spill back when dry then skim with plaster
Feb 05, 2014 | Drywall
How do i seal a crack in the grout on the shower floor using wet area silicone? Is this suitable and what do we do?
problem usually happens when grout is not fully cured and sealed when water penetrates it so... remove old grout using grout removal tool (you can pick up from any where that sells flooring(tile) pick up some new sanded grout to match and sealer apply then seal 24 hrs cure time is req. before sealer wait 2 hrs then re-apply sealer 7_2_2014_6_45_58_am.jpg
Aug 31, 2013 | Home
I am replacing my sink, medicine cabinet and adding a small cabinet below the sink. I need to know how to remove the old and install the new.
The task you are embarking on is a great DYI project. But, be forewarned, it can get tricky. First, make sure the new sink will fit in the space of the old sink. If not do you have enough space for the new sink to fit securely against the wall? Next, remove the cabinet. There should be about four screws. You may also have to use a razor to cut calking from around the outside of the cabinet. Sometimes it's used to fill-in gaps between the tile and cabinet. Remove the cabinet. If the cabinet is setting in the wall, make sure you check and see where the support beams are located. If you are not putting in another wall cabinet, then you will have to know what kind of wall you have. Sheet rock, no problem. Plaster requires a bit more work. Measure the hole, and then you will need chicken wire, lime, plaster, paint, and matching tile. Fasten the wire to beams in the wall. The wire will hold the plaster in place. Let dry, sand smooth then paint. If you have sheet rock walls measure the hole cut the sheet rock to fit. Fasten it to the beams, use plaster or Spackle to cover the holes from the screws. You will need sheet rock tape to hide the space between the existing wall and the sheet rock patch. Smooth on cover the tape with Spackle, smooth by sanding.
To remove the sink: first, turn off the main water supply. Get a pipe wrench and remove any connections. If you're not familiar with plumbing you may want to get a plumber to attach the connections.
Putting a cabinet under the sink is the easy part. Make sure you have the right size cabinet. Get a leveler; make sure the sink and cabinet are level. Depending on your walls, you can just screw the cabinet to the wall. If they are plaster walls you will need wall anchors. That should do it. Enjoy
Feb 23, 2013 | Plumbing
Can I hang a mirror in my dining room? What effect will it have?
You can hang mirrors on the wall by your dining room table. When you have guests, it will create an illusion of a very full house, adding warmth to the dining room area. If you light candles at the table, they will be beautifully reflected in the mirror.
Feb 18, 2013 | Home
Loud pop while fixing a light
That was the sound of arcing electricity. Most likely the fixture is shot...replace the wiring and the sockets and you should be fine.
Dec 16, 2012 | Furniture
Plaster board
Selley's make a product called Spakfilla. It is used for patching cracks and cavities in wall and ceilings.
It is easy to apply - just follw the instructions.
Mar 05, 2012 | Computers & Internet
I have plaster walls in an old house the stud finder just keeps beeping how does this thing work?
Your stud finder keeps beeping because old plaster walls have lath boards behind the plaster that are attached to the studs and running horizontally. Try adjusting the sensitivity of the stud finder by placing it on the wall and turning the sensitivity down until it just stops beeping. Then move it back and forth in a wide enough arc to be sure that you have crossed a stud, turning up the sensitivity ever so slightly until you get a tone when you cross a stud. Hope this works out for you.
May 08, 2011 | Stanley Garden
Honeywell T87f 3855 Doesn't Activate Heater
thats becaue you need more than this zone working like you said about the master/slave this zone is a slave.
Jan 25, 2009 | Heating & Cooling
How do i uninstall my old honeywell mercury thermostat
There are three parts to a T87F thermostat. Outer ring, thermostat body, and base mount. Remove the snap on ring that goes around the dial. Remove three screws from the thermostat that mount it to its base. Remove the thermostat. Disconnect and record what screws each wire attaches to. Remove the screws holding the base to the wall.
Jul 12, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
280 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
