Question about Music
Problems setting midi channels using KN3000 and Cubase
To select a sound on the KN3000 I click the relevant 'part select' being 'Right 1' = Channel 1 (say Piano) , 'Right 2' = Channel 2 (say Jazz Guitar), 'Left' = Channel 3 (Say Bass Guitar). I notice if I then reselect 'Right 1' and press the keyboard percussion I can assign the drums track which automatically goes to track 16. I laid down the tracks in Cubase 5 and so I am OK to here. Say after that I want another track which is Clarinet, then if I change the 'Right 1' part on the KN3000 to get the Clarinet sound, when I play back the music that I have already recorded in Cubase 5 all the tracks play back using the Clarinet sound.
Presumably one can play more tracks than 3 and a drums track, because if I look in the midi area -basic channels set up screen there are 16 channels in total. Also once the midi connectors are attached to the KN3000 once I click on one of the part selects such as 'Right 1' to change it, it changes all of the parts, instead of the one I am selecting. I have tried looking in the manual, but still do not understand. Please can you help?
Thank you.
Sylvia
  • sylviadavid Apr 26, 2009
    Thank you for your reply. By Omni do you mean 'Local Off'. I have tried recording with local off, and although I recorded the clarinet on channel 4 I still have the same problem. In that if I play back the Piano track which I recorded on track 1 it is now playing out a Clarinet sound (because I had changed the right 1 button on the keyboard to play the Clarinet sound). I have found that if I use the sequencer facility in the Keyboard to choose a clarinet sound on track 4 instead of using Right 1 then I can get Clarinet without messing up the Piano sound. However, if I switch my keyboard off and it goes back to initial settings then when I open up the project again both those tracks play the default Piano.
    At least originally I can record both sounds now, thank you for your help, if you know a way I can get it to remember the settings when I switch the keyboard on and off it would be greatly appreciated. I notice there is also a master and slave settings presets which when the KN3000 is the master all the setting move to local off, you can also set the KN3000 as a slave. Which I tried on playing back the pre-recorded sound, but it did not solve the problem.
    Kind regards,
    Sylvia
  • sylviadavid Apr 30, 2009
    Thank you for your further reply. I thought I had been saving each track. You have kindly helped me understand what can be achieved, so I will play about with the functionality of my keyboard, to achieve this. Thank you again for all of your help.
    Sylvia
    President:
  • 1,138 Answers
If you are sequencing midi tracks you can imbed the patch change in the track and the midi channel assignment and when the sequence plays the info will be sent to the keyboard. Do you have it set to receive Omni?
Posted on Apr 25, 2009
  • Michial Gueffroy Apr 28, 2009
    Have you been saving after recording each track? I'm not using Cubase myself but have done a lot of sequencing. Are you trying to use your keyboards sound module as a slave to generate the sounds and still play live with it? I don't know if you can with your keyboard. I have a Roland SC-155 that has sequencer and keyboard inputs. In my experience when I played the sequence when it was recorded properly It would send a system exclusive message to the sound module which would include the channel messages, part messages and patch messages for each track. You can even send lighting change messages and volume control messages etc if they are imbedded and saved in each track.
Keys working explanation or user guide
You need to load software on your computer that contains midi sounds - sampletank, Reaktor, etc. Make sure everything is set to Midi channel 1.
Jan 20, 2013 | Alesis Q49 USB/MIDI Keyboard Controller
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
PSRE323 - is there a way to specify what midi channel is used for midi out, how do you do it. Manual didn't seem to specify anything.
How they expect you to find the information is beyond me!!! I downloaded the manual and it appears that the information you want is on page 57.
Near the bottom, and the only way I spotted the parameter of MIDI channel number setting is seeing the range as 1 to 16.
They list this as L part and R part channel/track setting... these will be for the left and right parts of the split keyboard... that is you can set a MIDI channel to between 1 and 16 for both the left and right division of the split keyboard.
I don't think many people would find this... AND shame on Yamaha, there doesn't seem to be a MIDI implementation chart, which you should get familiar with for any MIDI devices you might have... the chart is a quick access to the MIDI capability of MIDI devices and they didn't include one in the documentation for this unit...
Dec 31, 2010 | Yamaha Survival Kit B2 for PSRE223,...
I have a MIDI problem with the Obey 40 - basically it's very erratic in accepting midi instructions. I have about a dozen banks of scenes created and one chase and I'm trying to set up my MIDI files to...
I am assuming that you are imbedding the changes in the midi sound files themselves. They will need to be on a separate track with the correct midi channel assigned at the beginning of the track.
Dec 09, 2010 | Chauvet Obey3 3 Channel Dmx-512 Controller...
I have the yamaha dtexpress and a midifase conect but cant get anny sound to the computer??????????????
try a midi loopback device or a viruual midi cable such as sonys virtual midi cable: http://www.johnrofrano.com/tutorials/virtualmidirouter.htm
i dont know if this one will work, you could also search for loopb1 and hubi's midi loopback device, one of these should work.
what you have to do is use one of these programs, or something similar, to connect your midi input to the soundcard's midi wavetable or to your midi/synth/sequencing software's midi input.
also, the drum machine should be set to output to midi channel 10. make sure that your software is set to recieve on midi channel 10, if applicable.
Nov 29, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
I NEED TO KNOW HOW TO SET UP MY ROLAND JUNO D WITH MY AKAI MPC 1000, PARTICULARLY HOW TO SET UP THE MIDI ON THE ROLAND.
Simple way is MIDI out from Juno to MIDI in on MPC, then (depending on how you want to work), connect MIDI out from MPC to the in on the Juno. If you do this you MUST turn local control off on the Juno or else you'll get double triggers (internal + msg in from MPC). Now to record sequences on MPC , set MIDI to as track in setup window (on the 2500, this is accessed by pressing MODE then pad 9, then press button under the corresponding tab [on LCD]) then set your MIDI channel by port, meaning if your MIDI cable is physically connected to out A, in your LCD in bottom right corner it will show as follows: 1A. This indicates you are transmitting on MIDI channel 1; port A. Remember, MIDI IS NOT AUDIO!!!!! Since the Juno is a synth and not a workstation, all transport controls are handled by the MPC, that's pretty much it... Hope this helps a little, enjoy!
P.S. Go to mpc-forum.com its THE sh**! They also have links for their e-book I have one for the 2500 and its awesome!!!
Aug 16, 2010 | Roland Juno-D
I have a behringer Xenyx 1622 mixer and am using cubase when i plug it in the it says its ready to go but, something happens and theres no volume..and i cant set it up in cubase?...any suggestions..
When you open Cubase you MUST open a new project.
Then select 24 track audio for example... unless yoou are doing MIDI record and playback.
Then open up a mixer panel and select a channel to read or connect to a file.
There are too many options to describe and the "says its ready to go " is not enough information to know where you are.
You may have to imprt files or record music... Don't forget to select a track on the display of tracks.
Apr 27, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
My PSR 550 giving signal (thru m audio fast track)...but no sound
You have to decide whether your keyboard will function as the controller to send the midi info to your program and have the program use the onboard sounds on your soundcard or use the sounds on your keyboard.Here is a link to a forum that I highly recommend:http://www.recordingreview.com/ It is free to join and the free download of Killer Home Recording Setting Up is great. There is lots of info on this site that will explain exactly what you need to know.Check out midi troubleshooting 101 and Getting Started with Midi Sequencing. The site owner Brandon Drury uses Cubase himself and I highly recommend their forum. Hope this helps.
Mar 02, 2010 | Music
Recorded midi, output set to dtxpress channel 10 no sounds is gen
You have to discover the receive channel for the dtxpress. Try downloading Midiox which is a freeware app that actively displays everything that is happening midiwise in real time.
Aug 26, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Yamaha Psr-340
I don't have Cubase myself but there must be a track setting that allows you to monitor what you are playing live. Also make sure your keyboard shows up as the midi controller on the software. Your receive channel has to match the send channel of the keyboard. Make sure that synthA or synthB shows up as the sound source (audio out). XFi Midiport is your midi in but since Cubase already sees your keyboard your problem is an audio one not a midi one. Hope this helps.
Jul 18, 2009 | Music
Music Logo
370 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
