Question about Samsung Refrigerators
Red light on door panel next to "energy saver" button
erpaalai
  • 999 Answers
SOURCE: kitchenaid KUDS25SH
Hold the button down until it beeps and the light goes off. Eric
Posted on Sep 03, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Rinnai Energy Saver 1001F
Try this link http://www.rinnai.us/documentation/downloads/Owners_Manual_1001-551.pdf
Posted on Sep 09, 2009
  • 6 Answers
SOURCE: Dishwasher KUDC25CH; Control Panel is not working
WASH THE DISHES URESELF U LAZY ****!!! :)
Posted on Oct 17, 2009
rylee_smith
  • 8619 Answers
SOURCE: green clean light wont stop blinking unable to use
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 19, 2010
SOURCE: the kitchenaid dishwasher (model KUDC25CHSS1)
On my unit, I had the same problem (child lock LED on, or flashing.The cancel process of pushing anything was not possible, as a bad/stuck switch prevented any input from the control panel buttons.
The underlying cause of the problem turned out to be a faulty switch associated with the "Light China" button. I determined this by removing the control panel from the door and using a digital multimeter with OHMS and DIODE settings, was able to check each individual push-button switch using the following table to check the 12 switches (applies to the KUDC25CHSS1 model).
There are 2 ribbon cables, it is the larger of the two cables you need to check. Pin 1 is noted on the ribbon. You can use 2 normal sized paper clips to insert into the ribbon cable and make your connections. (My Ohm meter has aligator clips on its leads which helps a lot...maybe another set of hands would help if you don't have these kind of leads).
-Using OHMS: the reading should be infinite (open circuit, so no reading/no connection inside the switch) when not pushing the button, otherwise you will receive a reading when you push the switch.
-Using DIODE/beep: Ensure polarity is followed in the table below. When connected, pushing the associated button will cause a beep to occur, otherwise there will be no beep and no reading.
+Positive Lead -Negative lead
Antibacterial Sw 13 3
Rinse Only Sw 13 2
Light China Sw 11 2
Normal Switch 13 4
Delay Switch 11 4
Energy Save Dry 13 5
Cancel 12 5
Start 11 5
Soak & Scrub 12 6
Super Scrub 11 6
Short Wash 12 4
Sani Rinse 11 3
All my switches checked out OK, except for the "Light China" switch. On the OHMS settings I was never able to measure an open circuit for that switch, which means the switch was always closed. or connected.
I noticed that "Light China" was pin 2 and "Rinse only" also used pin 2, which happen to be cycles I never use. With power turned off, I carefully removed some of the plastic surround of the matching connector on the Control Board right next to it's associated Pin 2 all the way to the bottom. Then I carefully bent over pin 2 as close to the connector base as possible. Making sure all the remaining pins were straight, I plugged on the control panel ribbon cables and all is well again.
Prior to trying this I was resolved that I needed to buy a new dishwasher because I wasn't going to pay over $350 for a new control panel. Instead, I eliminated 2 unused cycles at no cost, and maybe I can get some more use out of this dishwasher.
Posted on Aug 02, 2010
Manual for samsung frig RF263BEAE8R/AA
Go to manufacturer web site for manual download.
Aug 25, 2017 | Samsung Refrigerators
The alert ding goes constantly and no doors are ajar
How do I use the digital control panel on my Samsung fridge ...
www.samsung.com/uk/support/skp/faq/1023129
Samsung ElectronicsFeb 17, 2015 - Energy Saver Button. For better energy efficiency press the Energy Saver button. If condensation occurs on the doors turn the Energy Saver ...
Support - 4-Door Flex Refrigerator ... - Samsung
www.samsung.com > ... > French Door
Samsung Electronics4-Door French Door Chef Collection Refrigerator. 4-Door ... Will the Water Dispenser on the French Door Refrigerator Work Without a Water Filter Installed?
My New Samsung Fridge Won't Quit Beeping - eHow
www.ehow.com > Home
Remove bulky food items that might keep the door ajar. ... Samsung refrigeratorsfeature an internal door alarm system to alert you when a door ... The alarm turns off and the beeping stops no matter how long the doors remain ... Therefore you hear thedoor alarm go off in intervals, even though the door is actually closed.
Jan 19, 2016 | Samsung RF4287HARS French Door...
Why is the red light on? on the touch screen next to energy saver
have you tried pushing the energy saver button to see if it goes off. I would think it is the indicator for the energy saver
Jul 26, 2014 | Samsung RF4267HAWP 28 cu.ft. French Door...
Samsung Refrigerator Error Code 1E or IE
I'm not sure what all the wild goose chase answers are all about, but you guys are WAY overthinking this and not solving the problem. I'm a 45 year old stay at home mom, decidely and possibly forever "un-handy". The solution is simple, as I just administered it this morning after a self-imposed power outage: Press the "Energy Saver" + "Lighting" button simultaneously for 3-5 seconds and you should be back in business. When this happened on a previous occasion, we had a repair guy come out, although the fridge was operating perfectly bc we weren't sure if that error message was indicating something important. Well, I felt like a schmuck when the guy showed me how to reset the panel (and we were both a bit irritated that phone tech support didn't do a better job of level 1 troubleshooting). So there it is...if your fridge is working fine but showing 1E, press Energy saver + Ligthing at the same time (you may need a flashlight since the panel will be dark).
Aug 20, 2012 | Samsung RF4287HARS French Door...
How do i turn off energy saver toshiba e studio 203d
When u press the Energy Saver button, The machine will enter Energy Saver mode where all the display lamps are light off. Just leave Energy Saver mode, just press again the Energy Saver butto
May 18, 2012 | Toshiba e-studio 203sd
Is there a reset button on the dishwasher? if so, where?
Not sure what type of reset you are after. Is the dishwasher not responding to any panel switches.
Is the keypad locked, i.e., is the control lock light on? Then press Energy Saver Dry button for 4-5 secs.
Are some lights flashing and dishwasher will not start? Have you tried to turn mains power off and back on?
If you think the controller needs a reset, you could try this sequence of keys within 7-8 secs.
hi temp scrub/ energy saver dry/hi tempscrub/ energy saver dry/ hi temp scrub/ energy saver dry.
If the reset sequence has worked correctly, then all lights should light up. Press Cancel to exit from reset mode. I am assuming you have a users manual. If not then download from here.
Please rate the solution if it helps your problem otherwise post a comment
Feb 18, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
Own a Kenmore 665 dishwasher. The clean light is flashing (7 times) and the machine won't run. Have pulled the control panel and checked the door latch switches and they appear fine. No obvious burned...
It sensed a problem in the heater circuit. try this sequence to reset the code. If it comes back again you will have to determine a cause.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
Sep 13, 2009 | Kenmore Dishwashers
Do not know how to use the energy saver feature
i have a problem for minolta di351 by code c009 pls help me
Feb 21, 2009 | Toshiba e-Studio 350 Copier
Blinking Clean Light
  • Close dishwasher door
  • press "Hi-Temp Wash"
  • press "Energy Saver Dry"
run the 'normal' cycle without the hi temp feature
Nov 16, 2008 | KitchenAid 24 in. KUDI01FL - Multiple...
Refrigerators Logo
137 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
