Question about Konica Minolta Office Equipment & Supplies
Print jobs stuck in queue
Two jobs are stuck in the queue and wont delete
BARRET
  • 21 Answers
SOURCE: job in queue
Let me exaplin the cause why the jobs get stuck in queue: When ever we try to print there is a windows service called print spooler that manages the print jobs in queue. We can clear the jobs in queue by just disconnecting the usb cable and restarting the print spooler service. Here are the steps to restart the print spooler : 1.Click on start 2.Then click on Run 3.In the Run box type " net stop spooler " Then press enter Note: Type the text with out inverted cotes in the run box this will stop the print spooler service Next we have to restart the print spooler 1.Click on start 2.Then click on Run 3In the Run box type " net start spooler " and press enter Once done reconnect the usb cable and check for the jobs in queue. If there are no jobs in queue you can set the print directly settings to avoid this issue in future. Just open the printer and faxes folder and right click on the printer icon and select properties and then click on the advance tab and under it select the option print directly to printer and click on apply and Ok to save the settings. Once done try to print this should resolve the issue.. Wish u success..
Posted on Sep 19, 2007
MUKHTAR
  • 2022 Answers
SOURCE: Jobs stuck in the print queue for hp 2410xi all-in-one
just go to run and type services.msc and press enter it go to services option select print spooler and stop it and then run it will remove all the pending job and ready for print new job.
let me know if you stuck anywhere bye.
Posted on Dec 03, 2007
websnail
  • 419 Answers
SOURCE: printer will not cancel print job
Sounds like the printer spool is frozen.
Assuming you're using WinXP and logged in as an administrator (or with admin permissions)
START
Control Panel
Administrative Tools
Services
Locate the "Print Spooler"
Right click on this and choose "restart"
This will restart the print queue and will probably try to print the job again or delete it properly. If it tries to restart, just right click on the printer job and choose cancel again..
You may need to repeat but that should at least get you back up and running with other print jobs again.
Posted on Jan 25, 2009
len52155
  • 20 Answers
SOURCE: can not print...jobs are held in queue
go to administrative tools THEN SELECT SERVICES. STOP THE PRINT SPOOLER SERVICE. then see if the item is still in the print queue.. if so delete it .. but I think it'll go away when you stop the service. when it does.. restart the print spooler
Posted on May 20, 2009
anujbhatt
  • 66 Answers
SOURCE: i have a print job pending in the queue but cannot
Click on start menu and then click on run or in the search box, type services.msc and hit enter
it will open the services window, locate the service named as print spooler in it ,
Right click on print spooler and select restart, restart it atleast 6-7 times, then check the printing queue....
Posted on Dec 11, 2009
How do I delete a print job?
turn off the printer and remove power to the printer. Job will be stored in printers memory. Go to p.c you printed from and check printer queue see if job is in printer queue on p.c as well and then delete from queue. If it does not delete from the queue go to if windows p.c the services under control panel and stop and restart the spooler service.if print job is stuck in the printer queue.
Mar 10, 2015 | HP Envy 4500 e-All-In-One Printer, Copier,...
I cancelled a document while it was printing and it is still in my queue days later as deleting and it wont let me print anything else or restart that print job.
The best way to delete the print job is to turn the printer off, then disconnect the cable from the printer to the computer. Turn the printer on with the cables off, and go to your computer and delete the document, Then once it's deleted, turn the printer off again, and then hook the cable back up. Then turn the printer back on. That should do it.
Good Luck
Mark
Sep 13, 2014 | HP deskjet 3940 color inkjet printer -...
I can't print the items in my printer queue. How do I get them to print?
It sounds like you have a print job stuck in the print que. When this happens the print jobs after the stuck one will not print either. You will need to clear the print que and reprint the jobs. Here is a link to an article showing how to purge the print que and get your printer back printing again.
http://www.ccl-la.com/blog/index.php/how-to-delete-print-jobs-that-are-stuck-in-your-print-queue/
Apr 14, 2013 | Lexmark X7350 All-In-One InkJet Printer
Should i delete my printer first?
Did you stop the print que under control panel - system before you tried to delete the print job? This article at the following link may help:
Feb 15, 2013 | HP LaserJet Office Equipment & Supplies
How do i clear print queue , document says deleting but wont finish
go to start-in the run or search box-put in services.msc-hit enter-look for print spooler-left click on it-hit stop-then hit start or restart.
restart pc or go back to printers and faxes cancel print jobs stuck in the queue again.close printers and faxes and open it to check if queue already cleared up.that should do it.
May 27, 2011 | Office Equipment & Supplies
I have a HP D 2560 and it will not stop printing
There seems to be lot of print job stuck in queue and needs to be deleted
Click the link below to know how to resolve the print job stuck in queue issue.
Link
Oct 29, 2010 | HP Office Equipment & Supplies
Deleted print job stuck in queue
You can always restart the computer, that will "unstick" a print job that gets stuck deleting.
Jul 01, 2009 | Dell Inkjet 720 Printer
My last print job gets stuck deleting in the queue!
Go to C:\Windows\System32\spool\PRINTERS on your PC and you will see two files listed fior each of the outstanding print jobs. These will have the file extensions .SHD and .SPL
You need to delete both of these files then power off and power on your printer to be able to continue printing.
Feb 15, 2009 | Lexmark X5470 All-In-One InkJet Printer
1 document stuck in que
Hello u6rysl,
Turn the printer off.
Reboot your machine.
Go back into the print queue and remove the print job.
- Vincent
Nov 22, 2008 | Office Equipment & Supplies
Dell 924 Printer
Delete All has worked for me.
Aug 12, 2008 | Dell 924 All-in-One InkJet Printer
82 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
