Question about Maytag MDE308DAYW Electric Dryer
My Dryer won't start. The light inside comes on, but when you push the button, it doesn't start.
  • jared_m89 May 25, 2009
    The light inside my kenmore 70 series dryer comes on, but when i close the door and push the start button it will not start.
  • 113 Answers
It could be a bad doorswitch
Posted on Apr 24, 2009
rogrrabbit
  • 986 Answers
SOURCE: my dryer wont start
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Posted on Nov 15, 2009
jsrock516
  • 5911 Answers
SOURCE: Won't start when we push in start button. There's
No...the bulb is probably a symptom of the problem and not the cause. You should start by checking the thermal fuse. These are common symptoms of when a thermal fuse blows. If the model number is correct, you can access the fuse by:
1. UNPLUGGING the dryer and turning the entire unit around so you can access the rear panel (you may have to disconnect the exhaust vent hose).
2. Locate and remove the screws around the perimeter of the rear panel. With the screws removed, the panel will come off. Set aside.
The thermal fuse is located on the blower fan housing on the lower left hand side of the dryer (as viewed from the rear. It is a small plastic (usually white in color) component with two wires attached to it.
Disconnect the two wires from the thermal fuse and take a resistance reading. You should read something close to 0 ohms on the resistance scale if the fuse is good. If the the fuse is bad, you cannot reset it and it must be replaced.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need. The thermal fuse is listed as item 23 (part number 3392519) under the "Bulkhead" parts illustration.
If the thermal fuse has blown, it usually blows for a reason. The number one cause, is poor exhaust ventilation or dirty dryer interior, causing the unit to overheat.
Another cause of a dryer that fails to start is a bad power cord, bad receptacle, or tripped circuit breaker.
Double check your power source by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
Here are some additional links that can give you some advice on how to maintain your dryer and troubleshoot if necessary:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
http://www.fixya.com/support/r3574332-dryer_ducting_installation_advice
If you have any questions, or if your model number differs from the one you listed the question under, please post back and let me know. I hope this helps you.
Posted on Mar 21, 2010
Testimonial: "This was EXTREMELY helpful, especially for a 57 y/o woman trying to do repairs by herself!!!! I've contacted a male friend to come help n you r right"
SOURCE: Roper dryer won't start when you push in the start
how do I take a resistance reading on a thermal fuse?
Posted on Mar 30, 2010
  • 9 Answers
SOURCE: My kenmore 400 series dryer
There is a thermocouple on the inside that prevents the dryer from getting too hot. If this burns out this opens the circuit so the dryer will not work but all other functions will work.
Posted on Sep 23, 2010
  • 314 Answers
SOURCE: my dryer is model res7648eq2..i have power to it
Do not fear because all may not be lost! Follow these steps to determine why your computer won't turn on.
Difficulty: Average Time Required: Anywhere from 10 minutes to a few hours or more depending on why the computer won't turn on Here's How:
  1. Try to relax! There's a good chance you can figure out exactly why your computer won't start and then get it back up and running.
    I don't usually start a troubleshooting guide with the same advice a therapist might give her client, but when faced with a computer that won't start most people tend to panic, worried that all the data on their PC is gone forever.
    It's true that the most common reason a computer won't start is because a piece of hardware has failed or is causing a problem but that hardware isn't usually a hard drive. Your data is probably safe - just not accessible.
  2. . Try these steps if your computer will not turn on and is showing no sign at all of receiving power - no fans running and no lights on the computer case.
    Important: You may or may not see a light on the back of your PC depending on the kind of power supply you have and the exact cause of the problem.
    Note: Don't worry about the monitor yet. If the computer is not turning on because of a power issue then the monitor certainly can't display anything from the computer. Your monitor light will likely be amber/yellow if your computer has stopped sending information to it.
  3. Follow these steps if, when you turn your computer on, it promptly powers back off.
    You'll probably hear the fans inside your computer turn on, see the lights on the front of your computer turn on or flash, and then it will all stop - always before the boot process is complete. You may or may not also hear beeping coming from inside your PC
  • If your desktop computer does nothing at all when you try to start it, first check that the power cable is securely plugged in at the back of the computer as well as into a working power outlet. It's amazing how often this is the case.
  • If you're starting from a button on the keyboard, make sure the keyboard is connected to the computer.
  • If the computer is plugged into a surge protector, see if the surge protector has a reset switch that you can push. (If it doesn't have a reset switch and the problem is with the surge protector, it will need to be replaced.) Try plugging a lamp or other device into one of the surge protector's outlets to make sure it's working.
  • If you can hear the computer's fan or hard-disk drive, or if you can see indicator lights on the main unit but the monitor stays dark, make sure that the monitor is connected to a working power source, that it's turned on and that it's securely connected to the computer via the video cable.
  • If the monitor and computer have power but the computer displays a "Non-system disk or disk error" message, check to make sure you didn't leave a disk in the A: drive. If you did, eject it and restart the computer.
  • If the operating system still won't start even though the computer and monitor have power, try restarting with a Windows CD-ROM in the CD-ROM drive or, if you've got a Macintosh, with a Mac OS disc in the CD-ROM drive. (You can start a Mac from the CDROM drive by holding down the C key while starting up.)
  • If the operating system then starts, your problem is probably with the startup hard drive or with the operating system installed on it. If you can't fix the drive, you'll have to replace it
  • please tell how these work by staying how help
    Posted on Dec 20, 2010
    Electrical on but dryer does not start
    Sounds silly, but because it's an electric dryer, it's run on a 220 line. Double check your breaker box to make sure both breakers are in the correct position. If only one breaker is in the correct position, you'll have electrical power, but the drum won't spin.
    Jul 28, 2013 | Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas...
    Won't work. No service code.
    the first things to check is the door switch,open the door and push in the switch,if it doesn\'t click when pushed in the switch is bad,next thing to check is the belt,on some models there\'s a switch on the pulley assy. if there isn\'t any tension on the pulley the dryer won\'t start.if you need more help i need the model number off of the dryer,open the door and lolook around the opening where you put the clothes in and you\'ll see a tag with the model number,if the dryer hasn\'t been taken apart and cleaned out the thermal fuse could have popped,if the dryer gets to hot inside from a blocked vent line or the duct that the lint filter slides into is blocked the fuse will pop and it\'s non resetable.
    Mar 18, 2013 | Kenmore Dryers
    Dryer has power but doesn't spin or heat up
    Check to see if the door switch "clicks" when you push and release it. If the switch is bad, the dryer won't run. Here is the part in case you need it.
    Oct 30, 2012 | Frigidaire FGQ332ES Gas Dryer
    Ld lg3788w gas dryer drum won't turn
    not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
    Nov 27, 2011 | Dryers
    My Whirlpool Dryer GEW9868KQS has power, but won't start when the button is depressed. The sensing light comes on, but the dryer doesn't start. Any ideas?
    It's probably either the start switch or door switch. Try bypassing the switch and see if it starts. If it does,you can either replace the switch or try taking it apart and fixing the switch yourself. (I had a switch that simply required a copper contact to be readjusted and its worked perfectly for several years)
    Oct 18, 2011 | Whirlpool LER4634J Electric Dryer
    Dryer turns on but does not start when i push the start button. The timer comes on all the buttons light up, light is on inside dryer, but does not start just makes a sound when i hit the start button
    if it's a humming sound the motor is bad or something is jammed keeping the motor from spinning.open the dryer door and move the drum by hand if the drum can't be moved the belt could be jammed on something or there's something stuck in the blower wheel.the blower wheel is behind the duct that the lint filter slides into.if you can move the drum then you most likely have a bad motor,try spinning the drum and push the door switch in and have someone else push the push to start button and see if the dryer will start,if the motor has a flat spot it could start like this.let me know what you find
    Jul 14, 2010 | Kenmore 62602 Electric Dryer
    Dryer doesnt run when i push the start button light inside comes on when i open the door but nothing happens when i go to start it
    There can be many reasons why your dryer2_bing.gif will not turn...
    This tip that I wrote will help you to figure out what is happening...
    Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
    http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
    Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
    http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
    heatman101
    May 20, 2010 | Dryers
    Maytag MDE308DAYW Electric Dryer Logo
    630 people viewed this question
    Top Maytag Dryers Experts
    Tim Whalen
    Sal De
    Are you a Maytag Dryer Expert? Answer questions, earn points and help others
