Sony pcg 2c1l
BOIS WON'T BOOT THE VIDEO
4 Suggested Answers
dan231
  • 236 Answers
SOURCE: sony pcg k45
Put the cd in and restart. If it doesn't give you a message to press "x" to boot from cd, then you need to chage the boot order in the BIOS.
To get into the BIOS, restart and press del or F2 (it might say something on the screen like press del to enter setup) that is the BIOS.
Change the boot order to CD first.
Posted on Dec 18, 2008
myrlex
  • 674 Answers
SOURCE: Sony Vaio PCG-6L7P unable to boot. Unable to load
HARDWARE PROBLEM, TRY TO RESET THE BIOS OR REMOVE THE REMOVABLE DISK CD/DVD ROOM, THEN USE EXTERNAL
Posted on Jun 26, 2009
bronk50
  • 27725 Answers
SOURCE: How to remove hard drive from sony vaio pcg-2c1l
As you install new programs, rip music files from CDs or download data from the Internet, the hard drive on your Sony Vaio PCG laptop will eventually fill up and run out of room. You can replace the hard drive with a new one that has a larger capacity.
Power off the Sony Vaio PCG laptop, disconnect the power cord and then close the lid. Flip the computer over so that the bottom is facing up toward you. Press down on the raised latch that holds the battery into place and then pull the battery out of the laptop. Locate the five screws arranged in a square pattern on the right side of the laptop case. Take a screwdriver and remove all of the screws. Slide your fingernail or the tip of the screwdriver underneath the seam of the square plastic cover and lift it up. Grab the cover and remove it. Pull out the two screws that hold the hard drive onto the motherboard. Grab both ends of the hard drive and carefully pull it directly upward for about an inch so that you can see the cable connected to the motherboard. Disconnect the cable and then pull the hard drive the rest of the way out. Take out the four mounting screws that are located on both side edges of the hard drive. Take the replacement hard drive and install the mounting screws into its left and right sides. Plug the cable that runs from the motherboard into the corresponding port on the replacement hard drive. Check the direction of the new hard drive and lay it into the open slot in the same direction as the old hard drive. Use the two screws you pulled out earlier to hold it in place. Slide the cover piece back on and replace the five screws. Push the battery back into the laptop until the latch snaps into place. Hope this helps.
Posted on Dec 08, 2012
Dec 08, 2012 | Computers & Internet
Sony vaio pcg-71318L overheating
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Aug 30, 2012 | Sony Vaio PCG-71318L
Sony vaio a417m wont boot
If you only want to enter BIOS then you can try the below keys .
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Aug 06, 2012 | Sony VAIO Notebook
My Sony pcg-9c1l won't turn on!! When I press the
Could be your adapter, adapter socket - most common issues.
AC ADAPTER CHARGER POWER FOR SONY VAIO PCG 9C1L PCG 9D1L VPCCW14FX... Test your power adapter with a multi-meter. Example below
Hope this works to help you and your situation.
Mar 11, 2012 | Sony Computers & Internet
Hello. I have Sony Vaio PCG-5426. And I can't reinstall windows on that machine. I have out CD-ROM "II FreeCom" and i try to reinstall with that. In BIOS menu I acces for first boot drive...
you shouldn't need to have to press f9 to boot from cd rom if you have it set in the bios as the first boot device , are you sure the copy of windows on cd that you have is bootable. Try booting from the disc on another laptop or pc and see if you can start it
Another option to try is to boot from a usb drive
instructions on how to do that are here
http://www.xtremesystems.org/forums/showthread.php?t=118576
once you have booted to usb you should be able to access the cd rom
depending on what version of windows you are trying to install you will need to run different programs.
you could also install vista or windows 7 to usb drive and install it from that, it is much quicker than installing from cd/dvd you would need to be able to boot from usb to start with though
how to install vista or windows 7 from usb instructions can be found here
http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/
please vote for me if you found any of this useful
Feb 20, 2011 | Sony VAIO PCG-5212 PCG-5426 PCG-551L...
Jun 26, 2009 | Sony Computers & Internet
Sony vaio pcg-fxa36 will not boot get error realtek RTL8139(A/B/C
ok, what is happening is the laptop is trying to boot from the ethernet port, what you have to do is go into the bios (this is usually F2 on boot) and change the boot order to hard drive, save settings and exit the bois screen, the pc should now boot to windows
kind regards and please don't forget to rate us
Dec 03, 2008 | Sony VAIO FXA36 Notebook
Booting problems.
try right click desktop go to properties/display setting check that display is set properly go to advanced settings check out there if everything OK go to control panel/device drivers uninstall video drivers reboot it should boot with standard vga drivers check if display is OK then try loading your proper video drivers
Jul 27, 2008 | Sony (B99860307) for VAIO PCG-K series...
Sony pcg-fx140 bootup problem
1. check bios for first boot option to hard drive.
2. If xp, run repair from cd (enable cd boot in bios).
Jul 03, 2008 | Sony MBX-49 ASSY Motherboard
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
