Question about Hardware & Accessories
How to set timer T17-RFi - Hardware & Accessories
What tool to use to remove throttle body
Depend on the vehicle but most are held on by torx screws usually t15 or t17.
Jul 31, 2016 | Cars & Trucks
Schematic? Need to try to solve RFI problem.
try inserting aluminium foil around the smoke detector to shield it from radio frequencies leaving only the holes uncovered to let moke in and sound out.
Jun 27, 2015 | GE Security Tx-6010-01-1 Supervised...
Error t17-020
The short answer is the "counter solenoid not connected".
I have left this disconnected after working on one before by getting into "that hurry routine" :).
Jul 15, 2014 | Riso RZ220 Duplicator
I would like a manual instruction for a sauter t17 thanks
A laptop?http://www.sauter-controls.com/fileadmin/Sauter/Broschueren/Manual_operation_and_local_visualisation_e.pdf
Dec 19, 2012 | Computers & Internet
I need instructions for a kingshield electronic plug in timer model t17
Timer is not identified
1) Kingsfield is Greenbrook:
Open following link to possibly identify timer and download manual:
http://www.greenbrook.co.uk/categories.php?cat=4
2) If timer is not shown, then add a comment with in-focus photo of timer posted on Flicker for possible help.
3) You posted next to a photo that looks similar to timers on following link:
There are other models of this timer that I have no manual for, so add a comment with clear description and link to photo.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Timex
Jun 25, 2011 | UPM Indoor Electronic Programmable Plug-In...
My RISO MZ770E gives error code "T17-020" Any Help would be appreciated
Error T17-020 means: The solenoid counter is not connected.
Hints: Check connection. Reconnect. Change counter.
Feb 17, 2011 | Riso RZ220 Duplicator
2001 f350 7.3 overdrive light is flashing and speedodometer is jumping erratic
it indicates an insufficient output from the OSS sensor.The output shaft speed (OSS) sensor is a magnetic pickup that provides transmission output shaft rotation speed information to the powertrain control module (PCM).
I suspect RFI, affecting the OSS signal to the CPM. I will post the actual PCM rationality test, it will help you understand what the PCM looks for before setting the code.Possible sources of strong RFI are the alternator, Battery cables corroded, fuel pump faulty, and any other wire running next to the returning wiring harness, the return signal from the OSS signal is tied to your transmission solenoid, TSS, and a few other electrical systems, any of them will send an unwanted voltage that can interfere with the signal.
Jul 30, 2009 | 2001 Ford F350 Super Duty SuperCab
CR-V high pitch sound at speed.
You have a RFI problem that's radio frequency interference. you need and RFI strap for radio to radio attena or an RFI strap from chassis to engine. hope this helps. this is the only way to get rid of unwanted RFI. good luck!
Jul 09, 2009 | 2007 Honda CR-V
Hardware & Accessories Logo
22 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
