Question about Juicers
Looking for new blade for Golden Harvest Majestic Juicer Model T20215
Overheating champion juicer
to the person. champion juicer running hot. if your blade is dull it will run hot bcuz its harder to turn and gets clogged easy. look online for new or less used blade.
Jun 13, 2014 | Champion G5NG853S Household Juice...
Jack Lalanne Power Juicer250
the power is not properly supplied to blade .....just check whether the connections are proper ....
Aug 09, 2008 | Jack Lalanne Power Juicer 250 Watts
How do I get the part shaped like a half moon to release the blade from the juicer:
Fit the stubby metal bits on the half-moon into the holes on the top of the blade. Hold the half-moon firmly and exert pressure to turn it to the right. The blade should unlock.
May 09, 2014 | Jack Lalanne Power Juicer 250 Watts
Acme juicer vibrating so much.
I've had one for 21 years and when I replaced the blade the same thing happened.
The blade is not supposed to be held firmly in place so it can slip intentionally to
minimize vibration. If you bought the juicer new, think back, and I believe you will
remember the vibration problem. I seems with a worn blade they vibrate less. The
motor is very durable and uses roller bearings like on a skate board. I went back
to the old blade, which I sharpen with a drill using a small bit.
Jan 11, 2010 | Acme 6001 Juice Extractor
I HAVE A JUICER MODEL #JE95XL ITS ONE YEAR OLD,I
Go to Lowes, to the cabinet knob dept. Get a cabinet knob that matchs the holes in blade. You can always bend the screw a tiny bit if needed to fit. Put the screws into cabinet knob, and tighten. Cut the heads off and you are ready to go. They have a knob that is stainless steel, just a flat piece across the top, an 2 straight pieces that go down. I think it was $2.97. It gives good grip, and takes the blade right off.
Aug 21, 2009 | Breville JE95XL Juicer
Acme juicer #6001, has a new blade, becomes unbalanced...
Hello, First, make sure the screw on clamp that holds the blade down is centering the blade correctly. Also make sure it tightens down firmly against the blade. Wiggle the blade to ensure it is mounted securely. If this doesn' fix it try your old blade again. If your old blade works you may have a bad, unbalance blade but I would suspect he screw on clamp knob may be somewhat worn and not securing the blade causing it to run "out of round" when a piece of vegetable pushes on it. If everything looks good with both blades and the blade securing knob it could be a worn bearing on the juicer. Try wiggling the motor shaft and see if there is any play in it. I have an ACME 6001 that is quite old so I wouldn't suspect the bearings are going. One other thing, does the bowl take 3 to 5 minutes to stop spinning when you shut off the motor? If it does then the shaft and bearing are probalby ok
Good luck with it...gary
Jan 05, 2009 | Acme 6001 Juice Extractor
Jack lalane juicer
All in the name of health I said a lot of bad words, except that I know I never toss out my owner's manuals. I finally went to find my juicer model number when I noticed that the box said that it came with a recipe book (!) so I ran to my recipe book cupboard and sure enough the owner's manual was with it. (Maybe yours is there..)
Anyway, the key is this "crescent wrench." Doesn't look like a normal crescent wrench at all, but the handle is shaped like a crescent moon. It has two little pegs that stick out and fit into the two holes in the top of the blade, Then it twisted counter-clock-wise, the blade **still screwed into the piece underneath it, then it easily comes out, as do the other parts inside. It was just that rotten little "wrench" piece WHICH, I might add, is unique to my model. If you download the other owner's manual that's online, it doesn't mention any such tool for their model. (sorry, I can't find a model # for mine. There is a "V3 52803" on the back of the manual if that's the model.) Good luck. Hope this helps you. Happy, and healthy juicing.
p.s. in the end...it's all about Jesus.
Oct 19, 2008 | Jack Lalanne Power Juicer 250 Watts
Rival juice extractor model 965
I HAVE LOST THE BOOK AND PAPERWORK TO MY RIVAL JUICE EXTRACTOR MODEL 965. IS IT POSSIBLE TO GET ANOTHER BOOK AND PAPERWORK FOR IT?
Jul 15, 2008 | Juicers
Take apart and clean the juicer
ok so i am tryin to take apart my juicer to clean it but i can't find a way to do it. Can u help me?
Dec 04, 2007 | Jack Lalanne Power Juicer 250 Watts
Juicers Logo
106 people viewed this question
Top Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Juicer Expert? Answer questions, earn points and help others
