Question about Garden
Twin strongburg carbs. "Will not idle"; clean fuel, rebuilt carbs, starts but quits after fuel runs out? fuel pump works, fuel check valve in bowl works-not stuck, ? MAYBE fuel not syphing into carbs?? wrong casket?? pleas help. Vincent...Scuttlemug@aol.com 9-10-2113
    New Friend:
  • 64 Answers
Check your distributor shaft and condenser. Most carby problems are nothing to do with the carby
Posted on Oct 16, 2013
steve_lima
  • 181 Answers
SOURCE: old homelite chainsaw, wont pull fuel
most of the time there is a air leak in one of the two crank shaft seals.to get to them you need to pull off the flywheel and the clutch assy.look for wet areas. that will be where the seal is letting out the oil and air.If you keep putting starting fluid in the carburator you will burn the rings,the piston and the cylinder up
Posted on Jan 07, 2009
  • 97 Answers
SOURCE: Echo CS440 wont idle when warmed up
Check for air leaking at cylinder to block.gasket.
Posted on Mar 19, 2009
  • 205 Answers
SOURCE: Stihl chain saw won't achieve max rpm
Crank seals are leaking, causes lean or low vacuum for the carb to work properly
Posted on Mar 26, 2009
  • 83 Answers
SOURCE: air leak only idles with choke closed no high speed.
Remove your exhaust manifold. Look into the cylinder with a flash light. You are looking for scratches. Anything larger then a light fingernail is definite proof you need a new cylinder/piston assy.
If it passes that test do the following:
Pour mixed fuel straight into your cylinder until 1/4 full. Slowly pull your saw over while looking into the cylinder. If you see bubbles after the ring/rings go by then you need a new cylinder/piston assy. On rare occasions if no scratches are present on the cylinder wall or piston, you may be able to change just the rings.
Posted on Mar 31, 2009
  • 226 Answers
SOURCE: WHAT IS WRONG?
I would check(maybe you already have) to see if there is a small kink in the line you replaced. And I would adjust the carb - it could easily be that also. (Maybe you have done that already) I am assuming that the air filter is clean. You might try seeing temporarily how it runs without the air filter, cause that can affect the carb performance. Hope this helps, Rick
Posted on Apr 17, 2009
24 hp brig motor does not seem to be getting fuel
the additive in gas eth. causes fuel lines to break down and not deliver gas to the carb. replace fuel line.
check fuel pump, remove fuel line to carb. turn motor over, if fuel does not spurt out fuel line replace fuel pump.
float in carb may be stuck, remove bowl from carb. and check needle valve, if gummed up clean.
Jun 02, 2014 | Briggs & Stratton Briggs Stratton Intek V...
I have a john deere tractor with a Kawasaki 20HP V-TWIN that will run on starter fluid, but will not start normaly, I replaced all the fuel related items on the engine, including rebuilding the carb,
recheck your jets also check the needle valve seat they swell up and stop fuel flow next replace the solenoid with a short bolt and try that they might sound as they are working but don't
Aug 13, 2012 | John Deere 420,1020,2010,2020,2510,2520...
I have a 06 honda trx250ex put new gas and oil in it and plug and battery and iit turns over but wont start but when i put started fluid in where the plug goes it starts for like a second or so and quits...
your problem is a clogged carb. clean float valve, main jet and idle circuit with a can of spray carb cleaner.
disconnect fuel hose at carb and see if gas flows.
reconnect hose and open float bowl drain valve. If no gas tap on side of float bowl with plastic end of screwdirver to free up float.
still no gas? remove float bowl and try to shoot carb cleaner into the fitting for the gas line from tank.
if gas flows now then put it all back together and it should run
if not then remove carb and clean carb passages, main jet, idle circuit.
Mar 21, 2011 | 2006 Honda Xr 250
When i start the bike cold or hot i have black smoke from the exhaust pipes..choke on or off and cant get bike to idle..i turn off the petcock and after a few seconds the idle starts to come back to...
Black smoke indicates that your mixture is way too rich. Now, you didn't say what carb you're running, stock or aftermarket. But, what it sounds like to me is the needle and seat in the carb is leaking fuel and overfilling the float bowl. When you're running down the road, you'll using enough fuel so that the float bowl does not overfill. When idling, you don't use as much fuel, the bowl overfills, and fuel flows into the carb creating a very rich mixture. Is you overflow hose that connects to the bottom of the float bowl connected, clear and open? If so, turn the petcock on without the engine running. If the overflow is clear and the needle valve is leaking, you should see fuel start to flow out of the overflow hose. This is very important that it do this. If the overflow hose is blocked and you forget to turn your petcock off, you could wind up with a couple of gallons of fuel in your engine. It will leak out of the float bowl, into the carb past the intake valves, past the rings and into the engine. I've also seen it get into the primary drive case as well. I'd put a new needle in the carb and check the float setting according to the book. it's sets with the carb on an angle if the carb is the original Keihin CV.
Good Luck
Steve
Jan 29, 2011 | 2003 Harley Davidson FLSTFI Fat Boy
Wont stay running
the problems is in the carburetor, common problems when unit does not run often and rust get get build up. get some automotive carburetor cleaners and spray it heavy in the carb, don't worried about flooding it or damaging anything, it will dry out faster than gas. (use little gas if you need to) try to start it up and get it running with the carb cover off and continue to spray carb cleaner in the carb while the engine is running, do this couple of time and hope that would clear it out. if that don't work you will need to take it apart and clean it. you have small tiny object obstructing the carb flow. the unit doesn't have a fuel pump, it run on gravity feed, the carb are easily obstructed. hope that help a bit
Sep 30, 2009 | Coleman Powermate Premium Plus 6250W...
Engine starving for fuel, fuel filter very low, almost empty
your fuel pump is diaghram actuated by pulses from crankcase pressure, if you look there is a small tube that runs from pump to valve cover, pull fuel line off carb and have some one crank it over to see if it's pumping. could be pump or blockage between tank and pump, if fuel flow seems good to carb, i would pull bowl off and check for dirt and also make sure anti run on valve, the thinghy that holds the bowl on to carb is opening properly, it should open and close when you turn key from off to run, beyond that it could be you have some water in your gas.
Jun 26, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Yamaha 06' V-star 650 idle prolbem!
Fuel filter is located near the fuel shutoff valve within three inches. It is inline between the shutoff valve and the fuel pump (towards tank).
The fuel circuit is: Tank/Fuel Pump/Fuel Filter/Fuel Shut-off Valve/Carbs.
You first step is to check for fuel delivery to the filter. Make sure the bike is cool and no iginition sources are nearby. Disconnect the inlet line at the filter and turn key on and crank engine (to trigger fuel pump.) Do not try and start at this time (choke off).
If fuel is adequate to the filter, check the filter by blowing through it, it should easily pass air. Replace filter if questionable.
Next reconnect the fuel lines and remove float bowl drain plugs in the back of the carbs (2 per carb). If with key on and cranking fuel pours out of these ports then you probably have clogged fuel jets. If not then the float bowl needles / pipes could be plugged with varnish from dried fuel. You can try spraying carb cleaner into the fuel inlet to clear the varnish and then retest. Careful not to spray carb cleaner on yourself (wrap straw with a rag).
If you have good fuel flow to the carbs and bowls you probably have varnish plugging the jets. You should remove the carbs and clean them thoroughly.
Hope this helps,
Kal
May 18, 2009 | 2006 Yamaha V Star Custom
My briggs & stratton will not start
If the engine fires on starting fluid, then you are missing fuel, so you need to start with the source, is fuel getting to the carb? if not why not. Check fuel lines, shut off valves and filters.
If it is, is the carb float allowing the bowl to fill?
If there is fuel in th float bowl, then you need to look at mixture and idle settings.
hope this is of some help.
Ed
Apr 19, 2009 | Briggs & Stratton Briggs Stratton Intek V...
94 kawasaki bayou 400 not geting gas priming pump dont get hard
Lets start with the basics. Is the gas valve turned on? Do you have plenty of gas in the tank. If not, turn the gas valve to the "reserve" position if your valve has a reserve setting. There may be a water trap bowl at the base of the gas valve. Turn the valve off and remove the bowl if you have one and then clean and replace it.
Next, drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine.
If the bike doesn't start after a couple of minutes then shut off the gas and remove the carburetor.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray all the little airways and fittings in the carb. Remove the two screws on the outside of the carb and spray into the screw holes as well.
Be sure to put each screw back in the hole it came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
Pleas rate this as " FixYa " if my solution works. Thanks
Mar 26, 2009 | 2004 kawasaki KLX 400 SR
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
