Question about Personal CD Players
Bmw 7 series cd changer
Hi i have a cd stacker and a cd got jammed, so i took it out of the car opened it up and tryed unjamming it by using a knife, and unfortuntly i cut one of the ribbings inside. any suggetions where i can get another ribbon from. thanks
0 characters
1 Points
ESA PCD391K - I have had it for several years but never used it. Now when I try to play an audiobook CD in the car, it keeps stopping and skipping back to the beginning. Happens on its own, and...
Hi Bob!
Does it happen only with that specific CD? Try playing another CD and see if problem persists.
If it does - get a new CD player; If not, your audiobook CD might be damaged/scratched... Try getting another copy of it.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Apr 20, 2011 | ESA PCD391K Personal CD Player
I can't open the changer--I think a CD is caught in it. now what? It says Open and makes a humming sound.
yes you are right , it is possible that a cd has got caugh in the mid transffer and got logged in. Unless it shifts to the end position to rest will it eject well. The humming you hear is the motor trying hard to eject. Open carefuly and look inside , do not use force but try to guide the cd carefully assisting it to slide within or out of the slot. Plase rrepeat this and tthe cd will free itselt and you will have a working set. Please check all cd again before reinserting as they may be warped. helpful Good day
May 06, 2010 | Personal CD Players
I want to open the cd player to replace the jack connector. I took out all the screws, but something inside is holding everything together.
if it is in guarrantee Don' t open it! you may cause damage in it's mechanism! refer servicing to qalified every engineer says
Jul 05, 2009 | Coby CX-CD1112 Personal CD Player
I just want a user's guide for the 5 disc changer/model #rs2663
You can find the manual here:
You will need to scroll down just a bit and click the GET MANUAL button. On the next window, scroll down and enter the code (you don't need to enter your e-mail address) and then click DOWNLOAD NOW to download the manual.
Hope this helps,
Mar 23, 2009 | RCA Personal CD Players
10 year old stereo system CD changer won't play discs
Dust may not be the entire cause, but without knowing the make and model, anything I list would be pure speculation. Please post the make and model. That should give me enough info to list the probable problems and their solutions.
Mar 17, 2009 | Personal CD Players
I have duraband cd walkman. When ever i try to play cd it just reads 'open' on the lcd screen and doesnt play anything. pls help
HI .
have you tried a laser cleaner to free the lens of dust, this might be one cause or the laser may be worn out .
Nov 18, 2008 | Durabrand Anti-Skip CD-915 Personal CD...
Needs a manuel for my system
Hi - You can download the manual by clicking the link underlined in blue below:
Magnavox MAS-100
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Oct 11, 2008 | Personal CD Players
Can't switch on
hi try this: take a small flat (watchmaker) screwdriver open the battries cartige an look for the springs that connect and holds the battries shive the screwdriver between the last coil of the spring and extend it (for better connection) check with brand new battries look inside the inlet ac adapter and look for a little silver tab shove the screwdriver inside and make some distance from its position (for better connectin) check with the ac adapter if that didnt worked then check the play button - maybe it got bad connection open the cd player look at the play button - there is rubber between the button and the board clean the connection with borad with some alcohol assemble it all toghter and see if good NO?? sounds like one of those "ghost in the machine" thing GOOD LUCK
Mar 29, 2006 | iRiver iMP-450 SlimX Personal CD Player
Personal CD Players Logo
101 people viewed this question
Top Personal CD Players Experts
Todd Zettlemoyer
Todd Zettlemoyer
Are you a Personal CD Player Expert? Answer questions, earn points and help others
