Question about Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor
How to change belt on husky h1503tp air com. - Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor
How do I adjust tank pressure
By letting air out.
Remove the pressure regulator plasic cover (usually one screw) and there will be 2 adjustment screws. One is for "cut-in" pressure (to start the compressor when the pressure drops below the set point), the other is for "cut-out" (to stop the compressor once that set point has been reached.
Oct 16, 2014 | Husky H1503tp
Motor does not shut off at 155 psi
The pressure shut off switch is not working right.. I would contact husky about a replacement part
Nov 28, 2013 | Husky H1503tp
Need to find out how to replace belt on WL65 cambell hausfeld air compressor
Not sure how easy it will be to locate repair instructions if they are not in your manual. However maybe the diagram of the pump is all you need. Just click on the first link below. It will open up the pump diagram. #14 is the belt.
I also included the link to the site where you can get a look a at the parts list and order parts for your compressor.
Hope something here helps.
If not please let me know and I'll try and describe the proccess for the belt remove to you.
Pump diagram:
http://www.mastertoolrepair.com/images/WL390100-Pump.jpg
Compressor diagram and parts list:
http://www.mastertoolrepair.com/wl650003-wl650102-wl650102aj-wl650202-wl650601-p-28707.html
Pump parts list:
http://www.mastertoolrepair.com/wl390100-p-17694.html
Nov 19, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Need the napa belt number for this. or wherever i can get a belt for it.. i dont have the belt that was on it
Measure this with a tape - go to NAPA and tell them what you are doing and give them the distance around the two pullies. The NAPA affiliates I have used in the past have had a very liberal return policy if I was in error.
Oct 21, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Belt Replacement on Husky Q26 Air Compressor
YOU HAVE TO TAKE COVER OFF LOSEN THE BOLTS ON THE MOTOR SO THE MOTOR SLIDES TO THE RIGHT SO THEN PUT THE BELT ON THEN GET A CAR JACK AND PUT BETWEEN MOTOR AND PUMP DO THE JACK UP TILL BELT GETS TIGHT AND TIGHTEN BOLTS UP ON MOTOR X4 GOOD LUCK
Aug 25, 2009 | Air Tools & Compressors
I need a new belt for my Husky air compressor but I don't know
This is a simple way to replace your belt without the old one for comparison. Use a piece of rope thick enough to fit inside the pulley, (cloths line works well). Simple wind it around the pulleys marking where the two ends meet. Cut and measure it. Take the piece of rope and measurement to a auto parts store and ask them to match it up. An automotive belt will work fine.
If this is a flat belt they should still be able to help you.
Aug 07, 2009 | Air Tools & Compressors
Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor Logo
32 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
