Question about Sony M-2000 Desktop Cassette Transcriber / Recorder
Foot pedal dirty - Sony M-2000 Desktop Cassette Transcriber / Recorder
Engine wont start, unless I push the gas pedal and keep my foot on it.?
Could be a dirty throttle body, or a stuck idle air control valve.
Is the check engine light staying on now ?
Apr 23, 2013 | Toyota Highlander Cars & Trucks
Engine will turn over, but car will not stay cranked.
You'll have to figure out if it is a fuel or ignition problem.
Is the check engine light on ? Have you checked for trouble codes ?
It uses an idle control valve to adjust the idle speed. The valve could be dirty or failing, or the throttle body could be dirty.
Jul 03, 2012 | 2004 Chevrolet Impala
Why does my gas pedal sticks, even if it's only pressed half an inch?
Thorttle body could be dirty causing it to bind. Or cable to foot pedel is binding up.
Jun 13, 2012 | Chrysler Sebring Cars & Trucks
My 2002 Lexus es300 is idling too low ,I have replaced the TPS sensor & now somebody has mentioned a foot pedal assembly ....Could this be right ?
ok it could be alot of different things idle air is dirty or the throtle body needs cleaned. Is the gas pedal cable driving or electric (but i don't thing it is the pedal)
May 22, 2012 | 2002 Lexus ES 300
My sewing machine doesnt stop when I take the foot from the pedal what to do?
Your electronic foot control spring might be stuck or needs replacement.Precaution is needed in servicing this footcontrols due electrical shock.Often electrical lubricant is needed to loosen the tracks of the control brushes.Observe these possibilities,spring or dirty control brushes.
Nov 25, 2010 | Janome Memory Craft 9000 Computerized...
My Pfaff Creative 1475 won't run. The lights are on but when I push the pedal down it doesn't do anything. Please help
there are 2 things it could be
1.the foot pedal could have gone out
2.the motor,,here's how to tell about the motor,, smell the motor & see if it has a smell to it,,if the motor has a smell like old dirty socks or a burn smell then chances are the motor has gone out
the motor would have to be replaced at a repair shop,, the foot pedal you should be able to do your self
websites for parts are--sewingpartsonline.com & sewforless.com
Nov 20, 2010 | PfaFF Creative 7570
Dirty airfilter, car will not start
If you took out the filter and it's dirty you can't see light thru it replace it. As far as not starting unless the air filter is now a solid block of dirt it should start, if the engine is fuel injected you must not touch the gas pedal while starting the engine or you will flood it.If it's flooded assuming you replaced the filter. Push the gas pedal to the floor hold it there while starting, after the engine starts remove your foot from the pedal to avoid engine overreving. This should fix the problem. Air filters should be changed every 12 months if you drive in dusty condtitions sooner the better
May 27, 2010 | 2003 Nissan Altima
Husqvarna 2000 sewing machine foot pedal stuck on but not pressed
you may need to take foot pedal apart and clean it the contacts inside may be dirty and causing it to stick
Dec 13, 2009 | Husqvarna Viking 1
Foot pedal broken
http://geeksquad.fixya.com/ThreadView.aspx?prdid=49977&thid=629933
Foot pedal broken
Posted by Monte79 on May 28, 2008
I have Bissell Power Steamer Clear view IIII #3105403. I let someone borrow it (mistake #1) and he over extended the foot pedal that angles the upright during use. The pedal is still connected, but the power steamer is locked in the upright position. There is also a bit of dirty water in the bucket, and i cannot empty it because it's basically locked in now. HELP
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Sorry you are having a problem with your Bissell, it sounds like he bent the handle release lever and you either need to bend it back or replace it depending on the level of damage to the item. Please feel free to contact the Bissell factory to see the best way to fix the problem, it is not an expensive fix however so contact your local vac dealer or get a referral from the Bissell factory for the nearest Bissell authorized dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 28, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Sony M-2000 Desktop Cassette Transcriber / Recorder Logo
23 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
