Question about Sewing Machines
Swf embroidery machine
Machine just shut down, for no reason. got it back on and it ran for another 2 or 3 minutes and shut down again, it's not blowing fuses or a breaker. Someone please help!!!!!!!
SOURCE: Fuse keeps blowing.
We just found the fuse!! You need several kinds of screwdrivers and loosen the bottom. Then the side piece has one screw that holds it on and we had trouble getting that off but eventually I just held it differently from my husband and it came off so easily. We finally got to the black plastic box that is held on the bottom with two screws and 3 clips of wires. Once we got that loose there were two more covers to take off until we finally found the two fuses! My husband is on his way to Radio Shack now to get a couple 3 amp fuses. It's obviously blown - so we trust this will work once we get all the screws back in the right place!
Posted on Apr 03, 2007
SOURCE: new home 8000 memory craft embroidery machine
llkaygifts,
I just found this site...they have the manual for your machine...I think it like $12. Heres the link... http://www.sewusa.com/Sewing_Machine_Manuals/New_Home_Manuals/New_Home_8000.htm
Posted on Aug 05, 2008
mohammed387
  • 1952 Answers
SOURCE: embroidery sewing machine ''emotions'' EM1
www.embroiderydesigns.com/free_embroidery_design_download.aspx
Posted on Jun 12, 2009
  • 152 Answers
SOURCE: Can't get computer and embroidery machine to connect.
If your using Windows Vista, you have to have the multi user account in the off postioin. Also if you had 3D embroidery software and you upgraded to 4D software you have to be sure to uninstall the 32 bit drivers from the 3d for the 4d to work properly.
You do have to install the communication software that came with the diamond also. It won't communicate through the 3d or 4d only.
Posted on Oct 10, 2009
  • 109 Answers
SOURCE: feed dogs stuck in down position
The feed dogs come up as soon as you start sewing again. Just make sure they're in the up position and start sewing.
Posted on Aug 23, 2010
Can I fix a Bernina Artista 630 Y Axis sensor myself?
Have you consulted the owner's manual, SetUp - pg 92 re screen calibration? Try going through the SetUp function again.
BERNINA Support Machine and Accessories Finders and Software Support...
Feb 16, 2016 | Bernina Sewing Machines
Singer 400 will not power on
Try turning the power switch on with the embroidery unit in place, insert the foot control. Then turn the power switch off, remove the foot pedal and turn the power on again. If that doesn't work, try inserting the foot pedal with the power switch in the off position, withdrawing it, then turning the power switch on.
Your motor was designed to shut itself down if it overheats or if stitching was interrupted. For instance, if your needle hit something solid and the needle bent or broke.
Generally, it will go on again in 10 minutes to 2 hours, depending on what the cause was. Occasionally, it can take longer. Using the foot pedal tends to reset the motor. I discovered this by accident one night, when I assumed that it was a Reset port and gently stuck the eraser end of a pencil in it until I felt resistance, then withdrew it. The machine had only shut down for about 3 minutes, but it turned right on again.
Jun 29, 2015 | Singer Futura Xl-400 All-In-One Sewing And...
Hi. I have a commercial one head tajima embroidery machine. I was sewing and realized I had no thread on one bobbin so I stopped the machine. Instead of continuing on, I decided to start all over with a...
Your new embroidery program has to be loaded first. The 2b7 is referring to needing instructions or in other words the embroidery program has to be loaded. Shut the machine down and turn the machine back on and load just as before.
Jul 06, 2017 | Sewing Machines
Put in viking machine embroidery arm, the machine went crazy then shut off? help?
More details needed. What model machine? What does "went crazy" mean? What happens when you turn the switch off, then on again (with the embroidery arm attached)? Does the machine function normally once the embroidery arm is removed?
Jan 04, 2013 | Husqvarna Sewing Machines
Frame skips on swf embroidery machine
ooooo ouch Can you get it to return to "home"
Dec 13, 2012 | Sewing Machines
Pfaff Creative Vision embroidery/sewing machine says motor overload then shuts down
I had the same problem and it was my power supply. I've had more than my share of problems with this machine and it's only 3.5 years old. Good luck.
Nov 08, 2008 | PfaFF Sewing Machines
I recently bought a Singer Futura CE-200. I was using the embroidery function, but had to stop due to threading problems. When I went back to the computer a few days later my computer was shut down. I...
Wow, I finally get to have a solution.
1. Turn the machine off.
2. Remove the hoop.
3. CAREFULLY slide the bar on the embroidery unit to the left.
4. CAREFULLY slide the piece where the hoop attaches toward you.
5. Turn on the sewing machine. The machine should take the unit to "standby" with a click.
6. Attach the hoop with the power on.
7. Exit the Futura software.
8. Restart the software.
This "should" fix the problem, however, you may have to repeat this process more than once to get it to "stick".
Jul 25, 2008 | Singer CE-200 Quantum Futura Computerized...
Fabric doesn't Feed
I have a Janome, and when switching from embroidery back to sewing, I must touch a button that electronically moves the mode from embroidery to sewing. In some cases, I've also had to turn off the machine for a few minutes and then turn it on again.
I used to own a Viking - it had a little door covering the attachment link for the embroidery arm. If it wasn't perfectly shut, the machine wouldn't convert to sewing mode, regardless of what button I pushed.
Nov 19, 2006 | Bernina Activa 130
Sewing Machines Logo
19 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
