Question about Frigidaire Kitchen Ranges
Frigidaire ES100 p/n 316257511 is not coming up to temperature. Is there an easy way to fix this?
I broke a 6" probe off inside my FEF389WFCD electric range. IT IS NOT the Temperature sensor, it is attached to a bare copper wire and comes in through a hole between the light and the broiler.
You claim it isn't a temperature sensor, perhaps because there is a working temperature display? I don't know because I am not familiar with your appliance.
From your description I expect it is the thermostat thermocouple that is broken and the bare copper wire is actually a capillary tube. Normally a sealed assembly with the thermostat, when broken the thermostat doesn't shut down the oven.
Apr 24, 2018 | Frigidaire Kitchen Ranges
Why is my Frigidaire oven (model # ffgf3013lwd) overheating?
Hello Julie Clark, thank you for your post!
From what you are describing it sounds like it could be an issue within the EOC (electronic oven control) or element. I would recommend you contact a professional to come out and diagnose your appliance to avoid any unnecessary part purchases. -Matt
Sep 16, 2014 | Frigidaire Kitchen Ranges
My Frigidaire electric range has the f-3 message error what does that mean
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that will walk you thru checking an oven Temperature Sensor .
Fault Code F1 F3 F9 Dr
Dec 04, 2010 | Frigidaire Microwave Ovens
Washer will not begin cycle because the "dr" indicator comes on. automatic door lock seems to be malfunctioning. is this an easy fix without the need for costly repair men? Frigidaire -...
easy fix,if you go to sears .com click on parts put your model number in it will break down and show you everthing about the part and where it goes,let me know how it turns out-mike
Sep 28, 2008 | Frigidaire Washing Machines
Error code A5 on Frigidaire 12,000 btu air conditioner
I have a Frigidaire model FAK104R1V window air conditioner that did the same AS error code. The problem is going to be one of the 2 temperature sensors in the unit. Mine happened to be the ambient temperature sensor located at the front of the unit. They are fairly easy to replace and you can buy a new sensor for about $15 online.
Jun 11, 2008 | Heating & Cooling
The buzzer is loud
Frigidaire # LFFH2067DoW2 # WB52430831 upright freezer (frost free commercial)
Freezer is still freezing. The alarm sounded and I switched the switch off to turn off. The manual says that the temperature isn't at the right temperature and once it reaches the correct freezing temperature the light will come back on or the sound would go off after at least 4 hours. This was since last night about 6:00 and if i switch the switch the alarm is still sounding. The left side of the freezer is a little warmer than usual. Any suggestions
Mar 02, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Rinse cycle temperature
You may have a problem with your Temp Switch or the Sensor Thermistor.  Very easy to check and fix depending on your technical ability.  Both of these parts are connected off the Automatic Temperature Control Board.
Feb 29, 2008 | Frigidaire GLTF1670A Front Load Washer
Squealing!!
the noise is coming from the drum axle bushing that allows the drum to spin on it's axle. Gain access to the rear of machine and apply some high temperature grease that is found in automotive parts stores to the bushing. run it while observing spinning drum at rear for any possible other problem where squeal can be found such as drum slides.
Dec 26, 2007 | Frigidaire GLEQ2152ES Electric Dryer
Kitchen Ranges Logo
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
