Question about GE WPGT9360EPL Top Load Washer
Machine is dead
I went to put on a load of clothes and the front panel will not do anything. I checked the power supply - plugged something else in to the plug and it works. The power will not come on to the washer. My dryer (matching) is also having problems. Tumbles, but no heat. I thought this was going to be a great washer and dryer....any ideas?
    Problem Solver:
  • 4 Answers
Hi: Please check the membrane "HOME" button. If you do not feel the click like the other buttons the membrane posibly is bad. If this is the case you can remove the top rear metal cover,access the ribbon (transparent)connector from the display board and carefully disconnect it, now plug the washer to the power and check if goes on, if not plug back the ribbon to the board (with the machine connected to outlet) and it will turn on. Let me know.
Posted on Sep 29, 2007
  • 447 Answers
Hard to diagnose ths one but i would start by verifying power in to all the pc boards (there is 2)
Posted on Sep 28, 2007
SOURCE:
Water leaked on top of maytag front load washer. now inop
is this a stackable washer? my guess is that the main seal on the machine went bad.if its no longer powering up,i'm almost positive something has shorted out.you may have to replace the control board,and the seal at this point.in my experience,unless you can get a good deal with a certified repair man,buying a new machine would probably save you a bit of money in this case.it's hard to say exactly what the problem is.the water could have shorted out the brain"control module" or could have leaked to a point to where it could have fried the pigtail(power plug).but from the sound,i'm gonna have to say that machine is dead.no offense or anything.
Jan 09, 2013 | Washing Machines
Hoover dyn8164d washing machine, when the last load washed I went to remove the clothes and there was a 'buzzing' coming from the top right area of the machine, I turned it off as usual, and t
Possible that the main power has failed , the power supply of the unit had packed up or there is a serious fault in the controller unit. You need to open the control panel unit to trace this case specially using a multimeter, check for the AC power to the unit and check for the DC to the circuit. If not the panel is a suspect.
Dec 31, 2012 | Hoover Washing Machines
Samsung wf317aag stopped mid cycle now machine has no power
First, are you sure there is power to the unit? Check the breakers and post back.
Nov 03, 2012 | Samsung WF317AAG Front Load Washer / Dryer
My daughter was using the machine, we believe she overloaded it. At the beginning of the cycle, it was very loud trying to turn the load and then there was a smell like thing was burning. We stopped it,...
hello, if it's total dead then it could have blown the fuse. it will be a glass type in the washers power supply. that smell could be the motor burnt out. which can cause a short to ground cause the fuse to blow check the belt at the back might have come off or snaped hope it helps
regards
shaun
Apr 04, 2011 | EuroTech EWC177 Front Load Washer / Dryer
Washer is putting holes in clothes
Check the inside of the drum when the machine is empty by feeling the entire surface with your hand. Take care as you are looking for something that's got stuck in one of the holes in the drum and is protruding into the drum, and this can often be a wire from an underwired bra!
If you find anything it should be removed by pulling it out carefull with a pair of pliers.
Mar 21, 2010 | Frigidaire ATF6000ES Front Load Washer
My washer went on control lock and now it wont turn on i tried to unplug it but nothing works
Would plug something else into outlet to make sure your power supply is ok. If you remove bottom panel in front(three screws) or top panel(three screws in back and slide panel back slightly to raise off) there should be a tech sheet with some suggestions. If it is less than a year old call for warranty service. Keep kids away with panels off. If unit is completely dead a guess would be main control board on top, but that is just a guess.......
Jan 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
GE front load washer, wbvh5200j1ww. no power.
the door can be manually unlocked by removing the bottom front panel, reach up and there is a pull tab on the lock mechanism. it is a crime that they do not post this online or in the manual, and let folks ruin their clothes.
power problem was a part called the "FILTER" it is where there power cord plugs into, something along the lines of part number 201. cost is $85 plus tax. service man has not seen one of these ever go before.
Dec 07, 2009 | General Electric WBVH5200J Front Load...
GJP85200 Whirlpool Oven display went dead
First you need to check if a supply is available to the machine. The safest way to do this is with a non-contact voltage detector. You can get one for around £10. (Also called volt sniffers by some) If you have an electrical supply to the machine I would call for service, use yell.com to contact your most local cooker engineer. If there is no supply you need to check back at your fuseboard to find out why.Have you reset all the trips?. Is there a spur with a fuse in it between the cooker and the fuse box?
Apr 04, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Zanussi IZ 12 Washing Machine Front Load
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Aug 28, 2008 | Zanussi FJS1225W Front Load Washer
Total Power Shut-Down - Can't get it to come back on
Hi , recock the breaker ,one the line was disengage..
Jan 27, 2008 | Kenmore 46462 Front Load Washer
GE WPGT9360EPL Top Load Washer Logo
181 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
