Question about Hitachi 53UDX10B 53" Rear Projection Television
Unable to align red crosshairs in horizontal range
When setting up digital array on 53UDX10B TV red cross-hairs
cannot be adjusted in the left to right (horizontal) however the red can be adjusted in the up and down (vertical) the blue crosshairs can be adjusted in both the vertical as well as the horizontal , of course this results in some red shadowing alignment necessary pos 1 =0 adj necessary , #2 right 1/8 inch, #3 = 1/4 inch to the left, #4 = 1/4 to the left ,#5 (center) =1/4 to the right , #6 =1/8 inch to the left , #7 = 0 adjustment crosshairs aligned on top of each other, #8 = 1/4 inch to the right (and there is a double shadow of the the x axis , #9 = 1/4 inch to the left , all these adjustment are given looking at the tv from the front ,yr of purchase 2001. i am a electrican and feel confident if some part replacement is necessary, love this tv and i like to be able to adjust or repair.
    Scholar:
  • 33 Answers
No there are no quick fix options for this fault. The convergence amplifiers operate similar to a high power audio amplifier, so if there is an impairment anywhere in the system, it will result in distorted audio, or in the case of television convergence amplifiers, one or more colors won't align. The convergence power pacs need to be replaced and the out of tolerance precision resistors located near the power pacs need to be carefully checked and replaced as necessary. And the power supply fuse links to the power pacs checked and replaced as needed.
It is also possible that there are root faults that cause the amplifiers to go bad which include bad connections or a bad digital control module. This repair is possible for anyone having basic electronics knowledge and soldering skills. After the above repairs are performed it may be necessary to perform the static convergence realignment procedure using the outer cross hairs as you mentioned, and realigning them.
Posted on Apr 28, 2009
My bsa sweet 17 6-18 is shooting about 2 inches high at 100 yards. on the adjustment turret it has an arrow that shows which way to turn for up. What is moving up? the point of impact relative to the...
To raise the point of impact, turn the elevation screw counterclockwise. To shift left, turn windage screw clockwise. If you raise the horizontal cross hair you will lower the point of impact of the bullet. If you move the vertical cross hair to the right the shot placement will go to the left. Make small adjustments tap the scope with a screwdriver handle to give it a shock, not to hard to help move the cross hairs and try to bore sight first. Hope this helps Fix ya up.
Jun 02, 2011 | Bsa Optics Sweet 17 Target Riflescope...
Tip
How to set convergence on Projection TV ' s
I have given an general explanation on most projection TV ' s
  1. Enter the menu on your TV. Use the remote control and bring up the menu.
  2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  4. Press "Enter." A crosshair pattern will appear on your screen.
  5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  8. Repeat these steps for all colors.
on Mar 18, 2010 | Televison & Video
How do I adjust the convergence properties on an RCA rear projection tv?
Normally on the RCA rear projection TV's you would bring up your menu and choose the Setup menu, then press OK on the remote. That menu would then have Convergence as a choice. Once that was chosen the next menu would give you the choice of either letting the TV run it's own Autoconvergence program, or you would select either Red or Blue convergence.
Choosing Red Convergence would bring up a Yellow cross-hair in the middle of the screen. If the Convergence was not correct you would see separate Green and Red cross-hairs. Once they were perfectly aligned you would again see one Yellow cross-hair.
Choosing Blue Convergence would bring up a Blue cross-hair in the center of the screen. If the alignment was out you would see 2 Blue cross-hairs. Using the Up and Down and Left and Right cursor keys you would adjust the alignment until a single solid Blue cross-hair was in the center of the screen.
May 15, 2011 | RCA Televison & Video
It has tripple vision and looks like a bow tie.
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
    To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
    To process and save the adjustment made, follow the steps below;
    1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
    2. Enter the menu on your TV. Use the remote control and bring up the menu.
    3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
    4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
    5. Press "Enter." A crosshair pattern will appear on your screen.
    6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
    7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
    8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
    9. Repeat these steps for all colors.
    Take care
    Jul 06, 2010 | Televison & Video
    How do you set convergence
    What is your Make and Model number?
    Red/Orange horizontal lines
    it could be that the tv convergence circuit is going bad. One shure way of finding out is to go to the tv feature menu(picture,audio etc.) and select the customer convergence setting, you should get a cross hair pattern(cross in middle of screen). that cross should be white and by aligning the red or blue colors they should move left, right, up or down
    Jul 27, 2009 | Akai PT5492S 54" Rear Projection...
    Mitsubishi VS-50501A convergence problem. The image looks like a bow tie and the convergence will not align. This TV only has manual convergence. I already replace the STK391-020 ICs, it has 3 of them....
    These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
    Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
    Here are some of the most common problems with these sets...
    Problem #1) Convergence
    Yours may have one or more of the following symptoms
    • Screen Looks 3-D
    • Colors wont align
    • Screen may look distorted or warped
    • No Audio/Video - makes a chirping sound.
    Problem #2
    Another common problem is dull or washed out video.
    Your TV2_bing.gif may have one or more of the following symptoms....
    • Dull looking picture
    • White looking picture
    • Halos around objects
    • Red/Orange looking picture
    You can see some more examples and find a fix here
    bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
    Feb 15, 2009 | Mitsubishi VS-50501 50" Rear Projection...
    The red square on the digital array alignment is moving up and down,but now side to side
    convergence ic bad
    http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
    http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
    Jan 04, 2008 | Hitachi 53UDX10B 53" Rear Projection...
    Convergence
    Replaced convergance power packs (2) stk392-110 check all 2watt resistor the packs, to enter the convergance alinment mode on the set. Using the remote control press and release the sleep timer button when sleep timer displays timer equals zero immediately press the display and V. status buttons at the same time.  If done quickly enough the service menu will appear once entered the careful not to does disturb or change any other settings press the number seven to enter the convergence alignment mode a full crosshair pattern will appear in this alignment mode you can adjust the blue and the red to line them on the green using the select and the number pad you can move to the next crosshair to align the boot to the green and then the red to the green when done pressing the muting button on the remote control will save your changes will take a little while to figure this out as you work with.  If you make an unwanted error pressing exit without hitting the muting button will restore your convergence to its previous  setting.  If you're green is off after entering the service mode press the number six on your remote control in this setting will be able to adjust the green only once that is done us the muting button.  Then enter button seven if need be to adjust the blue and the red.  Remember no changes have been stored until the muting button is pushed open this helps.
    Oct 14, 2007 | JVC AV-48WP30 48" Rear Projection...
    Hitachi 53UDX10B 53" Rear Projection Television Logo
    183 people viewed this question
    Top Hitachi Televison & Video Experts
    Jaime Hernandez
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
