Question about Samsung LE40R74BDX 40 in. LCD Television
Samsung t24C350EW stand - Samsung LE40R74BDX 40 in. LCD Television
Replacement lcd tv base stand
Contact the authorized dealer for Samsung.
May 01, 2014 | Samsung Televison & Video
Stand for samsung le23t51b
Try a "generic" search for a TV stand. There are sources of these online
Mar 31, 2013 | Samsung Televison & Video
Samsung t24b350nd how to remove stand
should have a couple of screws holing stand in place. remove screws then lift tv off of stand
Feb 13, 2013 | Samsung T24B350ND 24" LED Monitor
Where can I buy a new base for the Samsung 24
The original Samsung stands will be very hard to find, only available from somebody that has wall mounted their monitor and no longer needs the stand. You can get a third party stand such as the one in the link below that will mount your monitor. All modern monitors have mounting holes in the back for VESA mounting, this is a standard configuration.
http://www.amazon.com/Adjustable-Tilting-Mount-Bracket-10~25inch/dp/B003L171KW/ref=sr_1_12?ie=UTF8&qid=1339684562&sr=8-12&keywords=monitor+stand
Jun 13, 2012 | Samsung 24" LCD Monitor 2494SW
Need a stand
I could not locate a stand for purchase on http://www.partstore.com/Model/Samsung/Samsung/PDP4294LV1.aspx
By the way, your tv is a rebranded Samsung model.
Without the stand, you only option would be to wall mount the tv.
You can purchase a wall mount for your tv from your local Wal-Mart or something to that effect for around $30.
Mar 13, 2011 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
How do i remove stand from samsung syncmaster 2333 to mount on wall
its a snap-type plug-in stand, just hold the stand firmly and pull the monitor equally upward, then it will snap quickly....... but a proffessional reminder! Before mounting your SyncMaster on a wall, be sure to plug the two (2) stand holes located at the buttom of the monitor. My Samsung SyncMaster 2333HD LCD TV was twice intruded by adult-size lizard, both incident resulted to main power board damaged!!!!
Feb 13, 2011 | Samsung SyncMaster 2333HD 23 in. LCD TV
Removing tv stand
Remove the screw and pull the TV upwards.
Have someone step on the stand
Dec 07, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Samsung LE40R74BDX 40 in. LCD Television Logo
65 people viewed this question
Henry  Thomas
Henry Thomas
