Question about Thermador PRG304US Gas Kitchen Range
After power outage, on my 2002 Thermador PGR304 range the oven light is blinking and no oven power?
SOURCE: oven shuts off
Sounds like the spark module has been shorted out and quite possibly the main control board. Apptech.
Posted on Oct 19, 2008
SOURCE: thermador PDR30 4ZS/05 duel fuel
It's the motherboard. You must have had a power surge. I just replaced mine. Motherboard + shipping 200.00. its not easy to replace but not so difficult.
Posted on Jan 10, 2009
SOURCE: Flashing Lights on Thermador Oven/Range
I HAVE THE SAME PROBLEM. MY OVEN BINKS ONCE FROM BAKE AND TWICE FROM THE OTHER LIGHT. OVEN DOES NOT WORK, ADND WE REPLACE THE CONTROL BOARD ALREADY. WHAT DOES THAT MEAN?
Posted on Jan 31, 2009
the lights flashing in a sequence indicates the error code. The error codes indicates what the problem is with your stove. Based on the response to your message, it sounds like their error code is 12, one then two. It is not clear what your error code is.
There is an explanation of the error codes on the wiring diagram that comes with the stove. I found the wiring diagram for my stove taped to the inside of the kick plate. The kick plate had to be removed to find it.
my oven is not working either. the error code I get is 34. I am told by a technician that error code indicates that the computer is not recognizing that the cooling fan is operating, which is why my oven will not work.
When I try and order a new cooling fan from Thermador, the website says that it is temporarily out of stock. Obviously, other people are having the same problem I am.
Posted on Mar 06, 2009
SOURCE: Thermador Pro Harmony Range--> Blue Lights Blinking
thermador rang, blue light blinking. Oven is not working,
Posted on Feb 05, 2010
When Thermador oven is on and the simmer burner on low-low and the igniter sparks, the oven shuts off and the clock blinks (as if there were a power outage).
Check your earthing, all the way back to the earth stake too for safetys' sake!
Otherwise, try lighting the burner with a gas match instead of the peizeo ignition module >> check ignition module
Oct 16, 2013 | Thermador Ovens
Thermador Oven E10 error message--due to power outage?
HI. During the power outage, there may have been a power surge. This has shorted your main control board. This E-10 is indicating that this is the issue. This code represents a failed control board. It must be replaced, in this case. Once replaced, the unit will return to its normal operating status.
Dec 08, 2009 | Ovens
Oct 03, 2009 | Thermador Pro Harmony PRG304EH (Gas)...
PRD486EDG doesn t heat up Oven light blinks once
PRD486EDG Oven doesn't heat up. Oven light blinks twice, then the heat light blinks twice. Tried reseting the power
Mar 18, 2009 | Thermador Pro Grand PRD486EDG (Dual Fuel)...
Oven shuts off
Oct 19, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Feb 03, 2008 | Thermador SC302T Electric Double Oven
Fisher&Pakel Oven os301
re-boot, I shut the breaker down for a few seconds and bingo, problem fixed
Aug 07, 2007 | Fisher and Paykel OS302SS, Stainless Steel...
Thermador PDR30 4ZS/05 duel fuel
Mar 11, 2007 | Thermador PDR304ZS Dual Fuel (Electric and...
Blinking oven and heating Lights
for no reason the cleaning light went on, even though the oven was not on. The oven light and heating light were alternating each blinking 5 times. The door locked up, too. It seemed to think it was in a cleaning cycle. Any way, problem solved by throwing off the main breaker and all is working fine since... except now, for no reason the oven fan, not the exhaust fan, stays on all the time!
Feb 12, 2007 | Thermador PG486GEBS Stainless Steel...
Thermador PRG304US Gas Kitchen Range Logo
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
