Question about Solar Intermatic Rc2343pt 4 Function 2circuit Air Switch
Install a 133rc1144 air switch on a intermatic rc2343pt
2 Suggested Answers
SOURCE: I have an Intermatic 4
You might need new trippers?
Problem is not fully clear.
Can't tell what is new, and what is not working. Add a comment.
You have a new timer with same problem as old timer.
And you have a new control box and switch.
At your new house.
You have RC2343PT air switch, likely with PB913N84 24-hour timer module with manual override knob.
http://waterheatertimer.org/images/Intermatic RC2343PT.jpg
http://waterheatertimer.org/pdf/Intermatic-PB800-PB900-timers.pdf
http://www.poolandspacontrols.com/~/media/Files/PoolAndSpaControls/Products/Instructions/RC2403RT.ashx
The RC2343PT air switch operates a pool-n-spa blower switch.
Pool and spa blower successfully turns on-and-off with circuit breaker.
Did you install a new PB913N84 timer module?
Are both ON-and-OFF trippers present? Are the 107TN222 and 107TN221 on-off trippers worn down and need replacement?
Does the timer dial rotate and keep good time?
What happens when you manually rotate the timer dial clockwise two rotations? Does the blower turn on-and-off?
Have you checked wiring terminals for signs of loose or burned connections?
Add a comment with more information for possible additional help.
Posted on Aug 31, 2011
Intermatic e1010
Is this new timer installation, or older timer that stopped functioning?
1) Copy following link to help identify timer, download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#E1020
2) If this is new installation, then check wiring for single pole installation. This timer will not work for 3-way switching.
http://waterheatertimer.org/How-to-wire-timers.html
3) If timer worked before, and now clock motor has stopped working:
Turn power off, use compressed air to blow out timer, then see if you can spray highly flammable vapor from WD40 can into the motor.gears.
4) There are replacement trippers for this timer, but no replacement clock motors.
Buy another single-pole in-wall timer.
Dec 03, 2012 | Intermatic Hardware & Accessories
Rc2343pt installation
Open following link for similar door label and manual:
Neither is exactly the same as your timer.
Intermatic does not have clear manuals for the air control product
http://waterheatertimer.org/pdf/RC2403RT-Door Label.pdf
http://waterheatertimer.org/pdf/RC2403RT.pdf
Mar 12, 2012 | Solar Intermatic Rc2343pt 4 Function...
I have an Intermatic 4 function Air Switch with Timer RC2343PT for my pool and spa blower switch. The timer no longer turns off at night. I have to manually turn the breaker off each night and turn it on...
At your new house.
Aug 30, 2011 | Solar Intermatic Rc2343pt 4 Function...
I have installed a motion sensitive light outside that is controlled by an Intermatic light switch inside. Is the motion sensitive light incompatible with the Intermatic switch?
as long as the switch operates properly there should be no problem, I would delete the switch from this type of application ,some times more control means more problems,
Jun 12, 2011 | Intermatic Hardware & Accessories
I have an old intermatic air swith control box that is brown in color, and the wiring diagram has come off the switch still works how ever I'm trying to hook it back up going trough a timer and not...
I need a photo to work with. Photo of switch, and terminals, and timer.
Put camera on macro, with the flower icon for in-focus close-ups.
Post photo(s) on Flickr, and then add a comment with link.
Another DIY resource:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#air
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 10, 2011 | Intermatic PART - AIR SWITCH 4 FUNCTION...
I am installing an intermatic t104m with firemans switch.I hooked up the switch to the pool heater and no power to heater?
Add a comment and provide more information.
A lot of factors need to be narrowed down.
Did everything work fine before connecting fireman burn-out protection switch?
What happens when you disconnect switch?
Is the timer rotating?
Does the manual override work?
Is this a new installation?
This sounds like a dual T-104 pool timer that controls more than the heater, what else is controlled, and do the other Loads work correctly?
Nov 19, 2010 | Intermatic HEATER DELAY SHUT OFF SWITCH...
New unit, just purchased, after installing new batteries, it will not work (no display). Model ej500c
Try this:  http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej500c%20-%20english.ashx
May 06, 2010 | Intermatic EJ500C - Indoor Digital Wall...
Solar Intermatic Rc2343pt 4 Function 2circuit Air Switch Logo
60 people viewed this question
Top Solar Electrical Supplies Experts
loft404
loft404
Level 1 Expert
obsteiner
T-Comtech Repairs
T-Comtech Repairs
Are you a Solar Electrical Supply Expert? Answer questions, earn points and help others
