Question about Flowtron LE-900 Leaf-Eater Mulcher
How to replace string in vornado leaf eater - Flowtron LE-900 Leaf-Eater Mulcher
4 Suggested Answers
  • 5 Answers
SOURCE: How do you intall the cutting string on a Flowtron leaf eater?
I have an electric weedwacker which may be different. In the leaf wacker there are four small holes very near the center screw on the revolving shaft. These holes form two small tunnels. cut two pieces of line (10-12 inches) and stick one through each tunnel. Center each line, put the two ends together and poke them out through the small hole on the edge of the rotating shaft. You end up with two sets of plastic line facing out from the central shaft. Flowtron may be different. Good luck.
Posted on May 05, 2009
bbreton
  • 437 Answers
SOURCE: I need a replacement spinner assembly for an older
Go to www.flowtron.com. There you can find the parts you are looking for like ler-500 spinner assembly for $20.95.
Good Day.
Posted on Nov 18, 2009
SOURCE: reload cord.
Jeff, I just got a used Vornado. I was able to take that screw off and lift off the cap. We replaced the cutting blade with .06 gauge filament, but the manual calls for .085.
It still worked just fine. Good luck. Barry
Posted on Jan 29, 2010
Echo gt 200r
This is a blower, right? What string are you talking about?
Apr 17, 2014 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I don't remember how to start my weed eater;i've lost my manual
Pump the gas bubble near the black box air filter. Start pulling the string. Keep pulling until it turns.
Thanks
Jun 03, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
What size is the line for replacement. Can't find
www.Flowtron.com is the website for this company. I saw some replacements strings Part# LER100 for about 5 dollars. I did some additional looking but could not find a size on the string but hope finding the website helps.
Good Day.
Oct 18, 2009 | Flowtron LE-900 Leaf-Eater Mulcher
Replacing pull string on Poulan BVM200VS leaf blower
You will need to split the housing and remove the impeller wheel. In doing this you will have to disconnect the throttle cable and the switch assy. This can be a hand full if you have never done one.
In the future when you are purchasing a string trimmer or blower
or hedge trimmer, be sure that the starter can be removed by
removing 4 screws. This makes starter repair a 5 minute $10 job
instead of an hour $40 or more job. The problem is that you will
not find this in most home centers or box stores. You will have to
go to a full service dealer.
Sep 12, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Jun 01, 2009 | Garden
Mar 23, 2009 | Flowtron LE-800 Electric Leaf Shredder
Reload cord.
I just replaced my Flowtron cutting string. That screw in the middle comes off if you turn it hard enough. Then the spool lifted off. I took it to the hardware store to get the right gage string, and installed it like the old. It was curly though, and got caught under the spool when I used it. Then the motor quit and won't start. So I just posted that problem. ~ CarolK
Nov 13, 2008 | Flowtron LE-900 Leaf-Eater Mulcher
Flowtron LE-900 Leaf-Eater Mulcher Logo
205 people viewed this question
Top Flowtron Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Flowtron Garden Expert? Answer questions, earn points and help others
