Question about Chicago Pneumatic Air Tools & Compressors
Need breakdown on CP1200 1/2 ton air hoist. - Chicago Pneumatic Air Tools & Compressors
New neiko 1 1/2 ton ratchet hoist won't lower
Take it back for warranty repair.
Nov 26, 2016 | Cars & Trucks
Youtube repair
safety catch worn or spring weak.
Aug 13, 2014 | Jet 310015 JLH-100WO-15, 1 Ton Capacity...
How to measure air conditioning tonnage to square feet of hom
Read size of air conditioner you need , each ton of air conditioning will keep cool 400 square.so higher ton yo pick you feel cool.please read below square feet to ton chart.
1 ton on 400 sq. ft.
2 ton on 800 sq. ft.
3 ton on 2000 sq. ft.
5 ton on 2570 sq. ft.
May 28, 2014 | Computers & Internet
Are wire hoists as strong as chain hoists?
Wire hoists are as strong and in some cases can be stronger even than chain hoists being able to lift between 1/2 up to 80 tons.
Nov 21, 2013 | Hoisting
How much can my lever ratchet hoist lift?
Common ratchet lever hoists have the capasity to lift up to 5 tons, but some can only lift 1/2 ton its important to consult your user manual for exact numbers before use.
Air compressor model vt633400aj looking for breakdown of unit
if you google vt633400 (leave off the AJ) you'll find tons of diagrams and parts.
Feb 21, 2013 | Clarke Power Products AC2002A 2 Hp Air...
I bought the system in 1994. Have no buyers guide. Is there any warranty on this system. It is a three ton unit. Thank you
Dear friend!
For any A/c unit the maximum warranty is 7 years and also only for compressor. Hence take a repairman to service and attend for breakdown calls by enrolling an AMC (Annual Maintenance Contract) with him.
Hope helpful tips?
Jan 19, 2011 | Heating & Cooling
How do i change out front wheel bearings
Compare to a rear wheel drive care, the bearings are totally different from the tapered style from the old days. Those where much easier to remove and don't require special tools. FWD bearings have high temp grease which is thicker and doesn't breakdown into a soupy state when it gets hot.
  • You'll need an air hammer and the correct sizes of metric sockets
  • You need to remove the CV joint nut which is torqued at least 120lbs psi on the spline part
  • You'll need a long 1/2" breaker bar for leverage
  • You'll also need a 1/2" torque wrench
  • At least a 10 ton hydraulic bench press and corresponding flanges to push out the old bearing
  • If you have a bearing tool you might get away without a press
  • Must have factory manual with torque specs
  • If you don't have all of the above mentioned tools then I'd suggest to forget the idea doing it on your own, you'll need tons of power just to start the bearing out of the wheel bearing housing (carrier).
Feb 17, 2010 | Toyota Avalon Cars & Trucks
Need info for RUDD upflow oil furnaces
Contact your nearest Ruud DISTRIBUTOR, usually The Noland Company, and ask them if they could go into the historical documents and print out or send you the files for the wiring, spec's and parts breakdown. From the model number, that unit is rated for 3 tons of a/c. You can find a 3 ton coil that will fit in the space and get a straight cool condenser of 3 tons cooling and swap thermostats so it brings on the furnace and fan in heat and the condenser and fan in cooling. Or just add a simple White - Rogers model 444 for the cooling. Ron
May 06, 2009 | Ruud UBHC Air Conditioner
Brake diagram
If you call a dealerships parts room they can fax you a picture breakdown of the exact area you need.
Dec 16, 2008 | 1994 Chevrolet K1500
Air Tools & Compressors Logo
Top Chicago Pneumatic Air Tools & Compressors Experts
John Trevino
Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
