Question about Onkyo SKW-200 Subwoofer
Skw- 591 b mdd - Onkyo SKW-200 Subwoofer
How do you connect the skw 360 subwoofer to the onkyo tx-sr505 av receiver
Hi Kenny, sorry you can't. The TX=SR505 requires a powered subwoofer. The SKW-360 is passive. Thank you, Onkyo USA
Dec 02, 2016 | Onkyo Audio Players & Recorders
Where can I purchase the Dispersion Prisms?
Fuzhou Antyco Optics Co., Ltd.
Tel: +86-591-83853506
Fax: +86-591-83853765
E-mail: sales@antyco.com
info@antyco.com
Mobile:+86-18960876052
Web: www.antyco.com
Add: 4/F, 12th Bldg, Taijiang Industrial Park,
Juyuanzhou Industrial Zone, Fuzhou, Fujian, China
Post Code: 350002
Nov 10, 2016 | Optics
Onkyo skw 591 subwoofer...blue light is on and no sound? any thoughts?
Hello, To test the subwoofer when the blue light is on if you apply your thumb to the end of the subwoofer cable (the end that you would plug into the receiver) there should be feedback from the sub. If there is no feedback then the sub is not working correctly. Thanks, FJD
Apr 27, 2016 | Onkyo Audio Players & Recorders
What is the buzzing in my subwoofer?
It has being a long, long time since I've work with a subwoofer.
Check to see if it's making ground inside the subwoofer. Not sure if this will fix it, but it works in mine.
Dec 19, 2015 | Audio Players & Recorders
Denon AVR 591
This is where a circuit diagram would come in handy, displays are tricky to trouble shoot, and this a job for a pro.
Apr 02, 2012 | Denon Audio Players & Recorders
I was given a singer 591 D300A and I was after a user's manual on it.
Hi try the link below you can download the manual.
http://sewingonline.co.uk/library/Singer-591-D200A-%20591-D300A-Machine-Parts-Chart.html
Good Luck
lacala69
May 02, 2011 | Computers & Internet
I have 2 onkyo home theater systems, one is an older ht-r8230 with an skw-8230 powered subwoofer & the other system is a ht-r420 with s powered skw-420 sub. all i did was change the rooms the 2 systems...
It's possible that you have accidentally switched off the sub-woofer outputs on the receivers. Onkyo have a speaker set up test. You should run that and see if the speakers are on and that a signal is getting through to them.
May 28, 2017 | Onkyo SKW-110 Subwoofer
Onkyo skw 150 powered subwoofer output code
whatisthe codewriten behindtheoutput of the onkyo subwoofer skw 150my ou6666088.jpgt put is bad in sucha way that ican not retrieve the the code
Feb 12, 2010 | Onkyo SKW-200 Subwoofer
Onkyo SKW-200 Subwoofer Logo
78 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
