Question about Sewing Machines
Espn midnight hoops building instruction - Sewing Machines
Do The ESE ESante Baby Lock hoops fit the ESI ESante Baby Lock machines
The Babylock Esante ESE1 and ESE2 hoops are not compatible with the Esante ESI1 or ESI2 hoops. The Babylock ESI1/2 used the same hoops as the Brother PC7000 and PC7500. The ESE1/2 use the hoops that are compatible with the Brother PC6500 and PE700 series embroidery machines.
I wish that I had better news for you. This site has hoops for sale for both the ESI1 and the ESE1: http://www.allbrands.com/categories/871 . If you need hoops for either machine, use the compatibility data on each machine type to help you find more vendors that may have the embroidery hoops.
Jul 30, 2015 | Baby Lock Esante
Instruction manual for Grand Hoop
Try this
http://www.ehow.com/how_7807598_use-pfaff-grand-hoops.html
Mar 11, 2014 | PfaFF Sewing Machines
Embroidery hoop
No there should not be a lot of play.
Jan 31, 2014 | Janome Memorycraft 9700 Computerized...
Use elna mega hoop
Read the instructions. If you don't have any download them from the manufacturers site on line.
Jan 17, 2014 | Sewing Machines
How do i calibrate the hoops on a baby lock emp6
This is a translation of instruction from the Service Manual for the Brother PR600, the twin of the Babylock EMP6. I will testify this works because I just did it to stop the insanity of my EMP6 thinking everything was a 5x7 hoop. If you look on page 4-36 of the free PR620 manual http://www.brodyrmaskiner.se/service/pr620/pr-620-service.pdf you will find the same exact set of instructions that are in the PR600 manual. So here are the exact steps to augment the manual's instructions.
1. Turn off the machine.
2. Press all three buttons (start, threader and cutter) and keep them pressed while turning the machine on.
3. Press MAIN BOARD TEST MODE.
4. Press A/D TEST.
5. Put the largest hoop on the machine (7 7/8 x 11 3/4).
6. Press LL.
7. Put the smallest hoop on the machine (1 1/2 x 2 3/8).
8. Press S.
9. Take the smallest hoop off the machine.
10 Slide the arm to where the knob on the arm is when the large hoop is on the machine.
11 The reading on the screen should be very close to the value that is in the LL setting.
12 If not, go through the large hoop steps (5-6) again.
13 Slide the arm to where the knob on the arm is when the smallest hoop is on the machine.
14 The reading on the screen should be very close to the value that is in the S setting.
15 If not, go through the smallest hoop steps (7-8) again.
16 Press close when you have both settings close. They need not be identical but they do need to be no further than 200 away from the screen value.
17 Turn the machine off.
18 Turn the machine back on, load a file, and see if you have the same results that I had; it will show the proper hoops when you press the hoop symbol and it will also center itself in the hoop properly.
You can buy the PR600 service manual online for about $12. However, you have the 620 manual for free and there is really very little difference. I have found the manual invaluable in saving me trips to the shop and doing my own repairs.
Aug 26, 2013 | Baby Lock Sewing Machines
Bernina artista hoop not recognized
Calibrate the embroidery hoop
Note
The embroidery hoop can only be calibrated with the oval hoop.. You'll find the instructions for each machine in the relevant user manual.
Aug 15, 2012 | Bernina Artista 180
For the HV #1+ embroidery unit, using the plus hoop and embroider
Hi!
You can find the solution by following these steps-
Slide in embroidery card 21 and companion cassette. Touch Embroidery ON.
Touch FUNC to Program mode, The “E” inside the hoop will appear on the left end of the Program display window. If Plus Hoop programming is desired, touch the rotational arrow E one time and you will see the hoop in the Programdisplay window change into a Plus Hoop with a small arrow pointing to the top portion of the hoop, indicating position 1.
Toward the right side of the Program display window are
F1 S1 M1. F1 = Font style (1, 2 or 3), S1 = Size (1 or 2) and M1 = Menu (1, 2 or 3).
FONT: Select 1. Palace Script 2. Clarendon (block) 3. Kalligraphia
(Note: Programmed letters are always displayed in block)
SIZE: Select 1. Large 30mm 2. Small 12mm
MENU: Select 1. Upper case, 2. Lower case, or 3. Numbers and Symbols—check Program display for upper or lower case indication.
Note: You must select the Font, Size and Menu before selecting the letter desired.
Do rate the solution accordingly.
Thanks
Rylee
Mar 16, 2009 | Husqvarna Viking 1
Hoop errors
I have the same machine 1 year old ,check thet the hoop is on pins correctly and tight and that the large hoop is selected on the program.as these machins are verry sensetive.Hope this helps.
Lea
Jan 19, 2009 | Singer CE-200 Quantum Futura Computerized...
How do you use the Plus Hoop on a Husqvarna Viking "Rose" Sewing Machine?
The plus hoop is a multi positional hoop that allows you you to embroider designs up to 4" x 6". It is essential for monogramming and lettering using your Rose. The Rose hooping system is the same as the 1+, the Scandinavia 300 and 400.
The designs you use must be formatted for the plus hoop. That is, the design has already been divided into two or three elements. Each element is an individual design. For instance, say the design is a long stemmed rose. It would probably be divided something like this: design 1: the flower and the top part of the stem, design 2: The middle part of the stem and the leaves, design 3: the bottom part of the stem.
You would hoop up your fabric to be embroidered, attach the hoop to the machine, set the hoop to position 1, select design 1, stitch out design 1, set the hoop to position 2, select design 2, stitch out design 2, set the hoop to position 3, select design 3, stitch out design 3. You should have a complete design when you're done and everything should match up perfectly!
The hoop is divided up into three squares, 4" x 4". Position 1 square overlaps position 2 square and position 2 square overlaps position 3 square. This overlapping allows the designs to stitch out more smoothly.
I hope this helps. Let me know if you have further questions. Carrie
Aug 27, 2008 | Husqvarna Rose
Sewing Machines Logo
114 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
