Printer stopped in the middle of a job with the reported error SC 555 Power On/Off and if it continues, call a service technician. They won't come becaue the printer is 5 years old.
Got an SC 555 error on my Lanier 2138
  • 53 Answers
When the fusing unit is not
running in the Ready condition,
the pressure roller fusing lamp
keeps ON with full power for
100 consecutive seconds.
Replace the fusing unit.
Posted on Jul 28, 2009
Sir ricoh printer is not working in red light and display in c8 whats problem now tell me
Fusing Reload Temperature Error (Fatal Error)
After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.
There is a problem with the fuser section p/n M1014002 -Carl
IF THI IS A SP200
Apr 26, 2016 | Ricoh Office Equipment & Supplies
How can I correct error SC559?
Fusing Unit Third Jam Error (Fatal Error)
The exit sensor failed to detect the leading edge of the paper within the prescribed time and triggered a jam alert.
  • ? Afterthiserrorhasoccurredthreetimes,themachinewill shut down automatically and cannot be re-started until the machine has been serviced by a service technician.
  • ? Checkthepapertransportpathforanyphysicalobstructions (paper scraps, etc.)
  • ? Makesurethefusingunithasbeeninstalledcorrectly
  • ? Afterservicingthemachinetosolvetheproblem,theservice technician must execute a "Fuser SC Reset". Otherwise, the
    machine will continue to issue this SC code and cannot be operated. ( "Executing Fuser SC Reset")
Feb 19, 2016 | Ricoh Aficio SP 100SF e Laser...
WHAT IS THE SOLUTION FOR /////REASON ERROR CODE 559 IN RICOH SP 100 LASER PRINTER
? After this error has occurred three times, the machine will
? Check the paper transport path for any physical obstructions
? Make sure the fusing unit has been installed correctly
? After servicing the machine to solve the problem, the service
operated.
May 21, 2015 | Ricoh Aficio SP 100 e Laser Printer -...
Show my printer on display C8 on Ricoh SP 100Su
Fusing thermistor deformed or out of position ? Fusing lamp harness loose, broken, defective ? Fusing unit defective ? After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.- Carl
Aug 02, 2013 | Ricoh Aficio SP 100SU e Laser...
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
I turned the power to the printer off in the middle of a job and then cancelled it. There is a paper halfway through and the error light is flashing. I cannot print a new job. Janice Simpson the model...
Disconnect the "data" cable between the printer and your computer.
Turn the printer on.
If the light still flashes, you have a "paper jam".
If you cannot "clear" it yourself, take the printer to a qualified technician, for servicing.
On your computer:
Click Start
Click Control Panel
Click Printers
Double-click the icon for your printer.
Click on the "suspended" (or "active") print-job, to "select" it.
Right-mouse-click on the print-job, and choose "cancel".
Nov 09, 2009 | Office Equipment & Supplies
Pitch changes midway through job and randomly reprints over lines
Check the cable. It looks like some sort of interference over the cable. Make sure it does not lie next to power cable.
Jul 17, 2009 | Matrix Okidata 120V Printer
Im having an error sayig SC:542 so how can i solve this kid of problem?
This is a 'fuser" warm up error. You could have a blown out heater lamp, or fuse, but most often this is caused by a power fluctuation. The reset for this is done by simply entering the service mode, and turning the machine of/on with the main power (red button).
enter service mode as follows:
"Clear Modes"
" 1, 0, 7 "
then hold "Clear/Stop" for 2-3 seconds.
The display will change with "service mode" in the top corner.
Now turn power off/ on (red switch)
** Never go further into the service mode, as you can cause all kinds of difficulty.
If the code comes back, then you will have to get a technician on site to troubleshoot the fuser.
Please rate me :)
Apr 24, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh 3800c Error code sc555
SC 555 Pressure roller
fusing lamp
Dec 01, 2008 | Ricoh Aficio AP3800C Laser Printer
Functional Problem SC 302
SC 302 has to do with you charge corona wire.  It's unrelated to the toner spill.  It could be a bad conora wire.  Sometimes it's the power supply.  There could be a lot of troubleshooting and repair to do on this one, you might want to contact a dealer in your area since the have the right tools for the right job.
Sep 30, 2008 | Ricoh Aficio 1013F Copier
Computers & Internet Logo
235 people viewed this question
David Payne
David Payne
