Question about Makita Garden
Echo gas blower PB-201 does not blow full capacity
localwonder
  • 6784 Answers
SOURCE: oil gas mixture of model pb-2100 echo leaf blower
GAS-- Use 89 octane r+m over 2 (mid grade or higher) This gasoline known to be good quality. Gasoline may contain up 10 15% MTBE (methyltertiary-butyl ether). Gasohol containig methyl alcohol is not approved.
TWO STROKE OIL-- 50: 1 is usable.
please rate and god bless.
Posted on Mar 27, 2009
  • 413 Answers
SOURCE: echo pb 200 leaf blower want start
Turn on ignition switch, Choke, prime bulb 5 times (or until fuel flows), hold throttle down and pull starter cord sharply until it tries to start, then place choke in mid position pull cord sharply again until it runs then move choke to off when it will allow it.
Also you can go to toro.com then customer care, then manuals and parts then type in model no. and download an owners manual.
Posted on Apr 06, 2009
  • 31 Answers
SOURCE: I have an echo pb 265l leaf blower. It starts
If its a two cycle engine it sounds like its loading up on fuel.. Need to lean out the fuel on the carb. Not much or it will be to lean an stick the piston..
Posted on Sep 23, 2009
97F350diesel
  • 1326 Answers
SOURCE: I have a Echo PB 2601 made a loud bang then stoped working.
Sounds like it has seized up. If the pull cord won't pull then the motor is locked up. Did you run gas/oil mix for the fuel its a 2 cycle motor...
Posted on Sep 25, 2009
  • 122 Answers
SOURCE: what is gas:oil mixture for Echo PB-500t blower?
50:1 ratio, 2.6oz of 2 cycle oil to 1 gallon gas
Posted on Feb 26, 2011
No power with Echo PB-755st Leaf blower
Try pulling the air filter off and see if it picks up. Also a minor carb adjustment may help. Also make sure your fuel isnt old or watered up. See if you can find alcohol free gas in your area. It may cost a bit more but it saves on repairs!
Mar 02, 2015 | Echo PB-755ST - Backpack Blower, Gas, 651...
Echo PB-251. Wont run full speed,changed ,plug,filters
I'm 99.9% sure it's the fuel line. The ethnoll in gas really shrinks the oem fuel lines
Jan 13, 2015 | Echo Pb-251 Leaf Blowers
Starts dies
Fuel lines could be collapsing from being soft, mush from ethanol in gas, possibly you have wrong carb kit, or something put together wrong, fuel lines reversed, double check everything then make sure you exhaust screen is not plugged, cause this will do same thing.
May 24, 2013 | Echo Blower Nozzle Es 2400 Pb 200 201 2100...
What kind of fuel do you put into an Echo PB201 Leaf Blower?
The blower is a 2 cycle, so you run an oil and gas mixture. Here is the link for the owners manual.
http://www.echotool.ru/files/50_17_21-21G-00.PDF
Apr 08, 2011 | Echo Blower Nozzle Es 2400 Pb 200 201 2100...
What 2 stroke fuel ratio do i use for the es 2400 leaf blower
50 to 1 don't use outboard 2 stroke oil. Use good oil echo, still, Husq ect.
Sep 27, 2010 | Echo Blower Nozzle Es 2400 Pb 200 201 2100...
My echo PB 201 seems to be discontinued and i have been looking for some troubleshooting advice... i cant seem to find the gas to oil ratio. you thimk u could help me out , thx.
New Echo engines use a 50:1 ratio. If you want to play it real safe, you can go lower....say 40:1....that is 3.2 oz. of oil to a gallon of gas.
Aug 12, 2010 | Echo Garden
Loss of power leaf blower - gas
Had the similar problem- start with removing the exhaust intake plate 1st--- clogs with super fine dust initially then larger particles... Mine was completely clogged- cleaned er' out now she blows like the wind!
Mar 30, 2009 | ECHO, Inc. PB-251C Handheld Blower
Garden Logo
19 people viewed this question
Top Makita Garden Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
