Question about Honeywell Programmable Thermostat Heater
How do you set the temperature on the a/c
My thermostat is set on 74 for cooling and I can't change it
It depends on the make or model but usually it is a simple arrow(either up or down). The older ones though have a sliding bar that you use to set the temp you want.
Posted on Apr 25, 2009
I would like to set the cooling temperature on my LUX TX9600TS thermostat below 74 degrees. At this time I can not get it to go lower. Is there a way to change that ?
Lux tech support 856-234-8803. I Google your tstat info and there is a downloadable manual that explains it. If I read it correctly, set it to cool, hold menu button, when screen changes scroll to "cooling limit", enter 00(that's like a pass code), then it's probably set to limit at 74. Lower that setting. Now from a professionals opinion, someone may have set that to 74 because that machine may have a history of freezing up when set below 74. Most all cooling systems are designed for a 75°f indoor at 95°f outdoor temps and 55% RH(humidity). Anything beyond that is also beyond design specifications. So it may freeze up which has the potential of compressor damage.
Oct 11, 2017 | Heating & Cooling
What is the on/off temperature (heat) range for a RTH111 series
Heat range: 40 to 90 degrees F
Cool range: 50 to 99 degrees F
1 degree deadband
Here's the operation guide:
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2603EF.pdf
Please mark my answer as helpful.
Jan 05, 2015 | Honeywell Digital Manual Heat/Cool...
Set thermostat at 74 heat pump will not cycle it will cycle at 75 degrees ?
check stat calibration. see if you can measure temperture at stat. the thermostat cover temperture reading is not that accurate.
Jun 01, 2014 | Goodman CLQ36AR49 Air Conditioner
Why won't my VT60 hold a temperature in the high 50's any longer? It is at 74 and won't let me change it to the 50's.
Make sure all the dust is removed from coils, fan blades and intake vent grill / filter!!! drain the condensation collection pan, and then reset the thermostat and wait 24 hours; before checking the temperature with a digital temp. gauge.
May 06, 2014 | VinoTemp VT-60 Wine Cooler
My Honeywell PRO 4000 Programmable Thermostat is set to 62 but last night went to 74 & then to 78 & heat would not go off. We have a Trane XB furnace - Both 5 years old. Took face plate off...
You probably have it running a program. Try using it simply on heat mode. Then set temperature and press hold on thermostat. The word hold should show up on the screen.
Feb 02, 2018 | Honeywell Heating & Cooling
Simple comfort 2200 thermostat not working properly
We have a Simple Comfort 2200 Electronic Thermostat and last night it quit blowing cool air and the # sign beside the air temp (the set to temp) starting blinking
Aug 11, 2012 | Heating & Cooling
At what temperature do I program the thermostat for a comfortable cooling(at how much do set the cool and h ow much should I set the heat). Thanks for your help
Normal settings are heat 70 and cooling 74 to 76 I like 76 if your not active its fine. They say the every degree above 70 heat cost additional 5%.
Jul 02, 2011 | Honeywell Programmable Thermostat Heater
Vinotemp VT-16TEDS has light on but doesn't cool
First check the grating over the fan in the back. If it is covered with dust, there won't be enough air flow and the unit won't cool. Clean the dust off and see if it cools back down. It may take a long time to cool down if it is full of wine, so I recommend taking the wine out to test if it works.
Jan 17, 2009 | VinoTemp VT24-G 24 Bottle Wine Cooler
Heating & Cooling Logo
52 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
