Question about Frigidaire Dryers
Rigidaire dryer fgq332es.
Frigidaire dryer fgq332es. how to take off front panel?
thanks
  • 113 Answers
Take a small flat head screw driver pop the top up and there will be two screws holding the front panel take them loose pull the panel out and lift up on it
Posted on Apr 23, 2009
Rigidaire dryer model LEQ1442ESO runs for 18 seconds, lights beeping and flashing and dryer wont work
Check the SAFETY switch on the door. Sounds like it needs to be replaced or fixed.
Jun 10, 2011 | Frigidaire Dryers
How do i get to the inside of the dryer - i need to replace a part in the front and can't figure out how to get the front panel off
Hello- First, BE SURE the dryer is unplugged, and then be sure again. You will need to release the two retaining clips that attach the top the the front. They are located under the front of the lid a couple inches in from each side. The best tool is a putty knife or something a flat paint scraper. Place the tool between the top of the front panel and the lid and pry up a little bit in order to see the clips, they are about an inch wide. You have to press hard right into in (its like a flat metal spring) and pry up at the same time and the lid should release. Repeat on the other side. They can be a bit tricky but just don't force it too much. Once the clips are released the top hinges towards the back. There should be a wiring harness that goes to the timer and switches and one that goes to the door switch, these have plastic connectors that should separate them as a unit. There is one screw on each edge of the interior of the front panel that holds it to the main dryer cabinet, take these out and pull the front panel forward and up and the panel should separate itself from the cabinet. You have to be careful when you put the front panel back on that it slides in on the bottom retainer clips and that the top of the drum is positioned correctly over the felt on the front panel. Just don't force anything. Hope this helps, best regards.
Sep 27, 2010 | Frigidaire FGQ332ES Gas Dryer
Sometimes it light but most times it does not
The problem is the dryer coils have failed. They tend to fail as they heat up.These are inexpensive and easy to replace. The following video will show you how to troubleshoot. There are also other videos on disassembling.
http://appliancehelponline.com/gdryertroublevideo.html
Jun 01, 2010 | Frigidaire FGQ332ES Gas Dryer
Starting gas dryer in perma press mode it stays in cool downmode
Check the ignitor. It should click upon 30 after starting it up. If not heard replace the spark Ignitor
Apr 04, 2010 | Frigidaire FGQ332ES Gas Dryer
Frigidair Crown Model #FDB23RGS1, Serial #XD14406315 - Fire on dryer does not stay lit. Appreciate your suggestions on how to fix the problem. Thanks
Have a technician come out and check the burner valve. Usually when the valve fails or is starting to fail, it won't hold a pilot.
Dec 13, 2009 | Frigidaire FGQ332ES Gas Dryer
Zippers get caught in seal around dryer door and twist around and break off
I had the same problem with zippers and socks. Solution was as simple as replacing the felt seal at the top of the dryer door.The drum rides on the felt seal that has plastic guides imbedded in it. It's function is to seal and more importantly act as a guide for the drum.
Check the drum at the front edge if the gap around it is not the same or if the drum is wobbley when you lift it by hand that is probably the problem.
You will need to open the dryer cabinet. Mine had 2 catch springs at the front top edges that were released by pressing with a thin flat object that will fit between the top and bottom cabinet(butter knife). Once the top can be lifted you may find a couple of screws that secure the front panel and door. Once removed the front panel can be popped off and lifted out (careful of door switch wires).At this point you csn see the felt at the top of the door . It is glued in place and is easily removed. your local appliance part supplier can supply you with a replacement that comes with the glue and installation instructions.
Put the dryer back together and no more burnt socks and ruined zippers.
Jan 22, 2009 | Frigidaire FGQ332ES Gas Dryer
My front load frigidaire dryer stopped going around and around.
call someone in to fix it...it will be easier and the belt can be a pain to put on again.
Jan 07, 2009 | Frigidaire FGQ332ES Gas Dryer
Dryer will not get hot
Hello najibennaji
Welcome to Fixya,
you said, My dryer is not hot enough.
Did you check the vent line for blockage or twists?
check the out side screen of the vent!
Thank You Huuum
Please remember to leave a rating
Oct 24, 2008 | Frigidaire FGQ332ES Gas Dryer
Fridgedaire Gallery Gas Dryer no heat
replace ignitor if 120 volts to it and it doesnt glow red. ohm all thermal fuses & thermostats. if ok replace sensor.
Apr 25, 2008 | Frigidaire FGQ332ES Gas Dryer
Dryers Logo
37 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
