Question about Dryers
GE Dryer DHDSR46EE1WW
Dryer runs for a while and shuts down. Timer is still running. It will only restart after waiting a few minutes. I suspect the Bias Thermostat. Would this cause my problem?
watugot
  • 290 Answers
SOURCE: Trouble with Maytag Legacy gas Dryer
Please provide the model number and I will see if I can figure something out.
It sounds like you have covered the common problems. Usually a motor is the cause for this problem, it gets hot and shuts down until it cools off. I have had some problems with the auto dry controls on the Maytags also.
Are you equiped to do some voltage checks if we need too? This would help in knowing where you have power when it quits.
Thanks/Mike
Posted on Dec 12, 2007
Master_Tech
  • 770 Answers
SOURCE: Whirlpool Duet dryer error code
E1=Thermistor open
post your email and i will send you the steps to fix and check it too much to type here
Posted on Aug 05, 2008
  • 3 Answers
SOURCE: Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
Posted on Nov 02, 2008
  • 63 Answers
SOURCE: Dryer runs for a few minutes, then shuts off
thermo sensor inside is bad (are you sure ALL vents and pipes are clear?)
Posted on Mar 13, 2009
  • 29 Answers
SOURCE: Ge dryer model #DHDSR46EE1WW. Dryer will not run
You most likely have a bad motor. Try to spin the dryer drum by hand with the door open, door swich held or taped down, and while pressing start. This will likely get the motor going. If this works try closing the door and starting it again. If it works now the motor may have just had a hard time starting do to it's position or the drum's postition. If it only works when you help it out manually you have a bad motor or maybe a sticky drum/jammed belt/etc. Good luck!
Posted on Apr 28, 2009
Ge dbxr463gd1ww stops before cycle ends
Sounds like a safety or limit switch cutting it out, if you wait 2 minutes and it restarts then repeats.
Aug 27, 2013 | GE Dryers
DHDSr46ee1ww has new heating element and switch but will not start.
Have you checked the motor kill switch? Its located by the motor.When the belt comes off the idler pulley actuates this killing power to the machine. Sometimes the switch goes bad over time and needs to be changed. The part number is wd21x10261 and runs around $12
May 18, 2012 | Dryers
GE dryer stops mid-cycle. If I try to restart it, it won't. Once I wait a few minutes for it to cool down, it will restart. I never know how long it run till it stops. A load last night stopped at...
I would say thermal fuse, here is a website that will tell you how to check, it also has other possibilities, Hope This Helps Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 21, 2010 | GE Dryers
Kenmore 800 dryer shuts down after running down to 40 minutes on the timer. When I restart it at that point it runs for about 30 seconds and shuts down. If I turn the timer back to 90 minutes it runs down...
Sounds like you may have a bad motor. If the motor is overheating it will shut down on its overload.
If its a shorted contact in the timer you could mark the spot where it stops and restart it again. It should stop exactly at that point.
Jan 22, 2010 | Kenmore Dryers
Mar 12, 2009 | Dryers
Timer Continues to run when dryer is shut off
the timer keeps on going even if you open the door this is normal
Feb 18, 2009 | Dryers
Dryer will run for about 20 minutes then it cuts off.
Are you able to restart the Amana dryer right back up when it shuts down? If you can, there is a short issue. If you have to wait a few minutes and you might even hear a faint click, then it will start, your motor needs replaced.....If Ic an help further, I am here.....
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Amana DLE330RAW Electric Dryer
Roper RGX4634KQ will run for 3 minutes then stop.
if you can restart after it stops but have to wait 30 mins or longer suspect bad motor
Jul 21, 2008 | Roper RGX4634KQ Gas Dryer
Dryers Logo
19 people viewed this question
Top Dryers Experts
