Question about Motorola Mobility Boost i415 Cellular Phone
Phone died and now will only charge
The phone died and I charged it it shows a charger is attached, but when I try to turn it on it won't turn back on. I have paid $200.00 for this phone and it didn't even make it to the first bill was due!
    Problem Solver:
  • 7 Answers
I have same problem with digital camera, take it back and they can repair it
Posted on Apr 23, 2009
Iphone won't charge if on
Hello My Dear::::::\
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 12, 2013 | Apple iPhone 3GS Black (16 GB)
The phone won't turn on
Try replacing the rechargable battery inside that phone.
Jan 12, 2013 | HTC Amaze 4G Smartphone T-Mobile
My Nokia E73 won't charge
First Option:
Second Option:
Sep 15, 2012 | Nokia E73 Mode Cell Phone
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
My SCH-a930 won't charge. I still have battery life, and the phone works fine, but the phone won't charge. I have tried multiple wall outlets. Does anyone know how to fix this? Thanks!
Please, try using another charger with the phone.
If the problem continues, get a screw driver, unscrew the phone and bring the charging port out. The charging port is at the tail end of the phone.
Clean the surface of the panel where the charging port contact the panel with a spirit and allow it to dry for 30 minute. Couple back the phone and i am sure the charging phone will work fine.
Regards
Jun 28, 2011 | Samsung SCH-a930 Cellular Phone
Sonim xpi jcb toughphone,the phone won't switch on,but when the battery is removed and replaced the phone comes on.However none of the buttons pressed gets a response,can,t enter pin and it won,t turn...
Remove battery,attach and switch on charger,for about 10mins or until charge mode displays,should flash.Insert battery, donot disconnect charger,leave for 2 hours,disconnect charger ,phone should switch on.
Jan 24, 2010 | Sendo Sonim XP1 JCB phone extreme...
RAZOR v3 -- i have 2 batteries, both good, 2
try taking out the sim and blow the stuff out of it. Then put it back together and see what happens
Dec 29, 2009 | Motorola Mobility FOR MOTOROLA RAZR RAZOR...
Phone dies and will not charge
Your Battery Is maybe Too Old, If the Phone Is Very old Then The Battery Is Just dead Because Of too much Use.
Hope it helps.
Sep 22, 2009 | Samsung Lands Phones
Motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
Motorola Mobility Boost i415 Cellular Phone Logo
50 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
