Question about RCA DRC629N Portable DVD Player
Portable rca twins dvd player for car keeps blowing 5a 250v fuses
SOURCE: Need new car adapter for RCA portable DVD player DRC630N
mine broke when it was new. i opened the cig lighter end and found broken wire. soldered it on and taped up the missing chunk of plastic. worked ever since.
Posted on Mar 29, 2008
SOURCE: Fuse T1.6L250V
no that wont work
Posted on Sep 05, 2008
sree-here
  • 61 Answers
SOURCE: rca drc628 portable dvd not reading disc
This is due to faulty DVD lens/head. Try cleaning it with DVD/CD lens cleaning CD.If still the problem persists, contact near by service center for replacing the faulty Lens.
Posted on Mar 13, 2009
dap_music385
  • 15 Answers
SOURCE: rca portable dvd player model drc6318e doesnt not
first you must check if your portable loads cd or mp3. If it loads cd or mp3 the defect is lens and this should be replace by an expert. If both cd,mp3 and dvd didn't load you check first the ribbon wire for signs of disconnection and foldings and then replace it. If still your portable didn't work the most probable defect is MPEG board.To distinguish if MPEG or lens defect in lens shows malfunction such as not reading dvd but reading mp3 or cd, unwanted stop of play even with a good dvd.
Posted on Jul 11, 2009
  • 80 Answers
SOURCE: RCA DRC6338 screen is dark
There can be dead lamp or invertor. Give it for some special guy who can fix this.
Posted on Aug 08, 2009
Panasonic DMR-EZ48V keeps blowing fuses.
I don';t like to replace fuses with the power on. the fuse is meant to protect valuable parts; this error mode indicates a probable fault internnaly. NEEDS to be serviced.
Apr 07, 2012 | Panasonic DMR-E55 DVD Recorder
We have a blown fuse in our car charger for our durabrand 9" portable dvd player. We are in a small town, no radio shack here. Walmart does not have a fuse to replace our blown one.
Try temporarily overwiring the blown with fuse wire (3A or 5A)
If it blows again then your player is faulty and will require professional attention
Replacement fuses can normally be purchased from Ebay or a specialist Electronic Store (Radio Shack , Maplins etc)
Dec 17, 2010 | Car Audio & Video
The fuse in the power cord has been failing. We've been trying a 0.315amp fuse which keeps blowing. what size fuse should we use?
Well, if it keeps blowing, and it blew out the original, then its trying to tell you that somethings wrong. I would say that you need to replace the main transformer in your power adapter, but it would be waaaay easier to just get a new one.
If you just increase the amperage of the fuses your using, you will surely damage your player.
Mar 25, 2010 | RCA DRC629N Portable DVD Player
Fuse Size??????
The fuse size shouldn't matter with the low voltage problem you are describing..Fuse size should be 10A fast blow(AGC). Verify that you have a good 12v power source feeding your unit...your dimming problem is voltage related.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Mar 29, 2009 | SPL Dynamics SDVD7400R Car DVD Player
Blown fuse in my dvd/vcr player
normaly its on the board
and with a magnifing glass
look at the side of the fuse it should say somthing like this
GMC 250v @ 2.00 ??? this is an example not
the value
Mar 28, 2009 | RCA DRC8335
Electrolux oxygen 3 fuse
The fuse on my ELECTROLUX Oxygen3's sumo board did have clear markings: F5AL250V - this is a 5A/250V 20mm fuse made by BEL FUSE, however, any other such fuse should work. The fuse on my board was blown (luckily, what caused it seems to be a glitch as replacing the fuse was all that I had to do). I got 5A/250V 20mm fuse from RadioShack and, expecting that this could happen again, I also installed a simple (5A/250V-rated) automotive fuse holder (also from RadioShack) (the only fuse holder that was available at a local store) and it works wonderfully now. Should the fuse blow on me again, I should be able to replace it in less than 3 minutes.
Feb 03, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Blowing fuses
Isn't the 1 amp fuse too small? Usually 12 volt operated electronics require a higher amperage fuse. Check with the adaptirs owners manual first before changing again.
Jun 10, 2008 | Disney D7500PDD Portable DVD Player
Fuse Keeps Blowing In Car Plug
try using a 3a or high fuse
You can buy a new car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for Durabrand DUAL 7" dvd player
Feb 09, 2008 | Durabrand Portable DVD
Fuse T1.6L250V
The fuse which you have used is of correct rating 250v/5A, the switching regulator of the SMPS primary section is faulty, so the fuse blows of continously
Dec 22, 2007 | RCA DRC200N
RCA DRC629N Portable DVD Player Logo
35 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
