Question about NetGear WGR614 Wireless Router
Help with ds connecting please advise would help
  • jkpf May 11, 2010
    Sorry but the DS can not connect to this router.
  • 854 Answers
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Enabling DMZ:
1. On the left side of the setup page, click on the WAN Setup under Advanced tab.
2. Check the Default DMZ Server and specify the IP address of your computer.
3. Click on the Apply button.
Posted on Jun 01, 2009
Orange screen
Hello there Sir/Madam! My name is Alex and I work under FixYa.com expert team surveillance.
Here you go here's the instruction on how to repair your problem with DS-L.
http://howtorepair.info/408/how-to-repair-a-nintendo-ds-lite-ndsl-bottom-screen-1/
Hope this helped and/or advised you on your next move.Please rate my solution, thanks in advance. Wish you good day
Adzic A.
May 08, 2011 | Nintendo DS Lite
My grandsons ds screen keeps turning off in all angles could you please advise me what to do thank you
I think this is an issue with the hardware itself, meaning there's nothing in the settings that could help. Do you still have a warranty on it? I'd suggest calling Nintendo's customer service.
Mar 14, 2011 | Nintendo DS Lite Console
My ds slot does not show up on my choose games even though i put the games in it says 'no ds card inserted" please help me i have my ds but only the gba slot works
There is probably one or more bent pins inside the top slot (SLOT 1). Remove the battery by removing the battery cover on the bottom (held ny a screw). Shine a small torch into SLOT 1 and look inside to see if any of the pins are bent differently to the rest of the pins. If any pins are bent they can be bent back to their correct positions by using a suitable small tool such as a precision screwdriver. If a pin is actually broken then the complete slot will need to be replaced.
If it is not a bent or broken pin, there may be some other type of blockage inside SLOT 1.
If there is nothing wrong with the pins and there is no blockage inside the slot, then there may be a dry joint where the slot is soldered to the PCB inside the DS. This kind of fault will require the DS to be opened with a special tri-wing screwdriver and the use of a multimeter to check all the connections. If you have soldering experience (and tools) then you can try re-soldering the connections.
Be advised that opening the DS is much easier than putting it back together again!
Feb 14, 2011 | Nintendo DS Lite Console
DS stopped accepting R4
check the pins on the DS that they arent bent or Damaged or dirty u can get a ear cleaner n some alcohol to clean the pins if they r dirty
Mar 22, 2010 | Nintendo DS Lite Console
My son's DS is frozen. We bought a generic DC
Has probably corrupted the DS's memory, small though it is. Replace the memory to unfreeze. Alternatively get angry and stamp on it. (2nd method worked on my psp, though not advised.)
Jul 07, 2009 | Nintendo DS Lite Console
Cannot use multi player on mario & sonic at the olympic games ds
First of all make sure your ds lite is not obstructed by any obsticals example your leg or arm or anything else and maximum 5 feet away from the other ds lite for a good connection. The other ds must be on download ds play after you send the request from the ds with the game in it.
Apr 18, 2009 | Sega Mario & Sonic at the Olympic Games...
TEXT PROBLEM
Visit the link to see the long answer ...other wise the answer is TEXT ME.
http://professorlaytonwalkthrough.blogspot.com/2008/02/puzzle067.html
Have fun.
Don't forget to rate my answers if this helped, please.
Brett
Mar 20, 2009 | Nintendo Professor Layton & the Curious...
Recorder gives error on USB port
This happened to me today. My first time to use a DS-2. The problem did not occur any more after I disconnected the cord from the recorder and reinserted it with the arrow facing down.
Jan 03, 2009 | Olympus DS-2 Digital Voice Recorder
NetGear WGR614 Wireless Router Logo
109 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
