Question about Yard Machines Garden
I have a Yard Machine 28CC grass trimmer 15" 2800M that I need to replace the fuel line that goes into the fuel tank but the line will not pull off tank. I am wondering if it is up in the talk and there is something I need to do other than just pull harder or is it just on tight because of the heat and I can just pull or split it and then pull it off.
5 Suggested Answers
mitchjl_1692
  • 3 Answers
SOURCE: Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
Posted on May 27, 2009
  • 3600 Answers
SOURCE: Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Posted on Jun 21, 2009
#1 Taper
  • 1040 Answers
SOURCE: craftsman 28cc gas weedeater gas line connections
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
SOURCE: repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Posted on Sep 05, 2009
HOW TO REPLACE DUAL LINE ON GRASS TRIMMER
search google for "YARD MACHINE 31CC GAS TRIMMER Manual". the manual is there I have seen it. also check youtube.com
Hope this helps...
May 01, 2016 | Yard Machines Garden
Ryobi Grass Scorpion Petrol lines from tank to primer to carby where to where
Thanks to doityourself.com.
The line off the top of the primer bulb goes to the top of the carburetor.
The line on the bottom of the primer bulb goes to the fitting on the center of the fuel tank and the line off the side of the fuel tank goes to the bottom of the carburetor.
Regards,
Worldvet
Oct 28, 2008 | Ryobi 15" Electric Factory Reconditioned...
Fuel lines
Fuel lines on this model just pull out of the fuel tank. they are a rubber bung push fit. Here is the parts manual for this model.
Sep 30, 2012 | Husqvarna Gas blower 125b 28cc
I have a 124l e-tech trimmer and the prime bubble wont fill
Sounds like you have an air leak. Either in the primer bulb is split or punctured, hole or leaking fuel line or primer bulb base, and is sucking air instead of fuel.
Aug 20, 2012 | Husqvarna 124L 28cc Gas Line Grass Lawn...
Fuel line on husqvarna weedeater need replaced
They are just a pull/push fit. The fuel line has 2 flanges that should fit either side on the fuel tank. Pretty simple to replace.
May 12, 2012 | Husqvarna 28cc Gas Line Trimmer
Gas line connections
Fuel lines can only go on 2 different ways, fuel line out of tank with the filter on it, to primer bulb in, primer bulb out goes to the carb in, the other line goes from the carb to the return to tank
Mar 31, 2012 | Husqvarna 28cc Gas Line Trimmer
How to hook up fuel lines
Fule line comes from tank to primer, primer then goes to carb and carb back to tank
May 04, 2011 | Husqvarna 28cc Gas Line Trimmer
I HAVE A HUSQVARNA MONDO LINE TRIMMER.WHERE DO THE FUEL LINES CONNECT.THE MACHINE HAS A WALBRO CARB.
For a machine with a remote primer bulb: The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. For a machine with the purge/primer bulb on top of the carb: The small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Oct 25, 2010 | Husqvarna 28cc Gas Line Trimmer
Replace fuel lines,craftsman weedwacker, 358.798520 . Fuel lines disintegrated in gas tank. Three parts left in tank, fuel filter and two small plastic hose connecting items.How are these parts related to...
Fuel filter in tank with line going directly to the fuel pump side of the carburetor This is the end of the carb with a solid cover. . This line should have length in it inside the tank where it can flop around and stay on the bottom to collect fuel. The other line in the tank should have one of the little connectors on it and can be right up to where the hole in the tank is to hold it there.. This line should connect to purge/primer bulb on the longer outlet nipple. Another fuel line should run from the metering chamber side of the carb (the end with the hole in the cover) to the purge/primer bulb with the shorter outlet nipple.
The purge bulb "pulls" fresh fuel out of the tank via a vacuum created after depressing the bulb and the fresh fuel flows completely thru the carb and any air or old fuel ahead of it are drawn to the purge bulb which then "pushes" this mixture back to the fuel tank.
Jul 05, 2010 | Craftsman 25cc Gas Line Trimmer
Craftsman 28cc gas weedeater gas line connections
Jim
Jun 30, 2009 | Craftsman Garden
Garden Logo
76 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
