Question about HP Vs17 17" LCD Flat Panel Monitor
White screen I have a hp vs17 monitor that only shows a white screen. No input, no menus.
  • walker6017 Apr 23, 2009
    my monitor also just went white! i tried all my cables/connections after talking to a tech at radio shack, who said my monitor was prob. gone. so i had to buy a new one, which works perfectly as soon as i connected it. so guess it was gone out. i don't know if they can be repaired or just have to be trashed. hope you find a solution or a good deal on a new or good used one.........
  • dalex01 Apr 26, 2009
    yep just a white screen.ive done the rudimentary checks and have decided that the monitor must be kaput.im gonna see if i can get inside and have a look.i did notice a slight browning around the power cable input but prob just coincidence.will get back with my findings.Dave.
Sunil Panem
  • 80 Answers
SOURCE: SPEAKERS
Hi Jonathan,
Pls check if the cables are connected to the right port.
Also check the monitor volume settings.
Pls check with a set of powered speakers.
Pls run dxdiag from Run in Start menu if you are using windows.
Also you can check for any issued with the drivers or any driver updates.
Pls try a system restore also if none of the above steps work.
Posted on Jan 30, 2008
SOURCE: HP Pavilion Vs17 LCD MOnitor
an answer to this problem would be great because mine does the same thing...like blinks but monitor wont come on.
Posted on Jul 14, 2008
SOURCE: NO SOUND!
there is no sound in my hp vs 17 monitor's built in speakers after iam format my system
Posted on Sep 28, 2008
  • 119 Answers
SOURCE: Nothing happens when I press
You might want to check and make sure that your power is plugged in [obviusly], next check to make sure that your data cale is properly connected or that your computer isnt in stand-by mode or hibernation. When your monitor doesnt receive data to display it goes into 'power saving mode' which simply is this 'Wake me up when you have something you want me to show'. SO try and unplug your your AC power for a bit and while doing that double check that your data cables are 'thumbs up' then reconnect your AC and try powering up. If all this doesnt work, and you're using a graphics card to send input to your monitor, check your graphics card, or try and listen for any fan noises just to make sure your computer has life...
Posted on Jun 22, 2009
Santhosh_7
  • 233 Answers
SOURCE: I want know where can I purchase a power supply
You can purchase a power supply board for HP laptops from the below link:
http://www.partshere.com/online/detail.asp?partno=0950-2417
If we can know the part number of your HP computer, you can find the exact Power Supply board for your computer model.
You can find the part number of your computer from the below link:
http://partsurfer.hp.com/cgi-bin/spi/main?jumpid=reg_R1002_USEN
You can find it even from HP parts store.
Posted on Jun 23, 2009
1901w white screen
tried to check first weather the connectors going to the display panel get loose or flex ribbon get broken. if those are ok, then the problem is the lcd board controller.
Oct 28, 2012 | HP 1901w Monitor
Computor keeps trying to restart,monitor only shows vertical lines,first black and white then colored lines,
Probably the problem is not with the monitor. Your computer is defective and probably the lines appear because your VGA is defective.
To make sure your monitor is OK, you can connect it to another computer.
First check replacing the RAMs and then VGA.
Sep 21, 2011 | HP Vs17 17" LCD Flat Panel Monitor
Doesnt want to turn on
Turn modem off and keep pressing F8 until you get to the screen that says enable vega and click on that and follow the directions from there.
Jul 16, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Monitor turns on and computer runs monitor is plain
look like ur RAM is crrupted...if u can see some alpha numeric char while starting then screen is OK
or Windows may be corrupt...
May 08, 2010 | HP Vs17 17" LCD Flat Panel Monitor
No input signal
that is the problem of cpu not a monitor to confirm disconnect signal cable and power on. monitor will show "no signal check signal cable" it means that monitor is ok and fault lies in cpu .then open the cpu and disconnect ram and listen the beep. contineus beep should be heard then ram is faulty replace it. if no beep heard then motherboard is faulty .
Mar 08, 2010 | HP vs17
Hp vs17 has white screen at boot. I have eliminated the chord from the tower and the tower works fine. I have audio, no video. Only a white blank screen. It does not blink or flicker. It just stays white....
There are three choices here...bad screen, bad connection, or bad video card, if the card is integrated onto the motherboard, then that part of the motherboard could be bad. If you have access to another monitor or a TV with a vga input, try the computer with another monitor. If you get a signal on that other monitor then you know you either had a bad connection with the other monitor or you lost the screen on the old one. Go back and reseat your video connections with the computer off. Don't ever remove or move cables to the monitor and video with the computer running...the screen can suffer permanent damage. If there is no signal on any monitor, then either you have a bad vga cord or your video graphics card had died.
Nov 11, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Nothing happens when I press the power button on HP vs17 lcd monitor.
Jun 22, 2009 | HP Vs17 17" LCD Flat Panel Monitor
The screen on my monitor suddenly went white. i have nothing on the screen, no border, icons,etc. what could my problem be? can it be repaired?
Try connecting your monitor with another PC and check if the problem is with your Monitor or is it the Video Card of your PC which is not sending Video Signals to your Monitor.
Apr 21, 2009 | HP Vs17 17" LCD Flat Panel Monitor
HP vs17 monitor power button flashes blue but screen stays black.
Try put off Monitor uplug power cord and the VGA cord for 1min and reinsert and restart your PC.
Nov 25, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Still not working!
You did get my other extended message, right? You are still showing up in my unsolved messages with no rating...
Aug 24, 2008 | HP Vs17 17" LCD Flat Panel Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
262 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
