Question about Coleman Heating & Cooling
How many tons is a Coleman 6284B901 serial #12732969?
Need to know the tonnage of this unit
You have a 48,000 BTU or 4 ton unit.
Oct 10, 2012 | Coleman Heating & Cooling
I would like to know how many square feet a Model # BRCQ0421BD Serial # 990905429 Coleman Central Air Conditioning Unit will cover. The unit supply is 208-230V 1 PH 60 Hz 10.8 RLA 97 LRA.
The Old Rule of Thumb is 400 square feet per ton, but you really need to do a heat load calculation to be safe. A lot of windows on the west or south side of the house will really increase your load and you may need a lot larger unit. Insulation also changes your load so you may be able to cool a larger area. You may be able to get the Heat Load Calculation Form either online or from Johnstone supply. They are on the internet.
Aug 07, 2012 | Coleman Heating & Cooling
How old is coleman condensor serial number 981149749
042 is a 3 and a half ton. Take 042 and divided by 12. Is 3.5
Jan 17, 2012 | Coleman Heating & Cooling
Hello. I would like to know how many ton my Coleman Central Air Unit is. The model number is 'ERCS0241BBB". The serial number is "WOD7699360". Thank you.
This is a 2 ton A/C I got that from the 24 in model number it means 24,000 btu which equals 2 tons cooling. If this helps please rate me and do a testimonial.
May 23, 2011 | Coleman Heating & Cooling
How can the model no. on coleman home ac, split system be used to determine specs? ex. mod. 9436G811 can be read as mfg. in 1994? and 36k btu or 3 ton for next two digits??
The mfg. date is sometimes (depends of the brand and the size of the unit) on the serial number.And the 36 in the model number means exactly what you think 36000 BTU or 3 ton.
Sep 03, 2009 | Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
