Question about eMachines W3506 PC Desktop
Emachine w3506 motherboard diagram - eMachines W3506 PC Desktop
Is it possible to make my W3506 Desktop Emachine wireless?
If by wireless you mean you are looking to be able to connect to a wireless router, then yes, it is simple. You can either install a wireless card inside the computer, if you have an empty slot available, or you can get an external wireless card, which plugs into an open USB port, the easiest way to go. Best place I know to find these is at www.newegg.com, or try Amazon.
Aug 01, 2013 | E-Machines eMachines Desktop PC
Installing memory
This perticular model can handle up to 4GB of RAM. There are 2 DIMM slots on the motherboard the lay vertical about 4-5 inches long. Simply push the white plastic clips on each side of the chip and it will eject the chip out. Replace by reversing the process. And be sure to replace with proper RAM that is compatible with that board. Use SIW (free download) to find out which ram you have in it now.
Apr 21, 2011 | eMachines W3506 PC Desktop
Hi! How do you make the W3506 sleep/ hibernate?
go to control panel from the start menu select performance and maintenance then select power options. then where it says stand by select how long after not being used you want the computer to stand by
Jan 31, 2011 | eMachines W3506 PC Desktop
Is my e machines w3506 desktop compatable with windows 7
HI There,
Here is the link to the drivers and applications for your computer which also shows on the left that WIndows 7 is not supported. Sorry for the bad news so please don't thrash my rating with a negative feedback.
Thanks and best of luck.
http://www.emachines.com/support/drivers.html
Sep 01, 2010 | eMachines W3506 PC Desktop
An intel celeron D socket 775 ddr2 motherboard for w3560 desktop
yes a mid sized. and it is call mATX for the form factor.
-socket 775
-DDR2
-PCIE
-mATX
Jun 05, 2010 | eMachines W3506 PC Desktop
My computer wont boot up the power light comes on,the speakers come on but the keyboard doesnt come on and nothing to the monitor...oh by the way its an emachines w3506
If the keyboard doesn't briefly light up the Caps Lock, and Numlock keys, when first starting the computer, and there's no video signal to the monitor, (No Signal), the computer isn't working.
Suspect the Power Supply first.
Bad Power Supply, is one of the most leading causes of computer failure.
This is brought about usually by one of two things, or a combination of both.
1) eMachines are Budget line of computers. Cheap quality parts are used, to defray the cost of making the computer.
One of the cheap hardware components is the Power Supply.
2) Computer is dirty inside, as well as the Power Supply.
The hardware components inside a computer, as well as the Power Supply, are cooled by air from fans.
Dirt, dust, etc, cause the cooling capacity of the cooling system, to drop tremendously.
Heat = Wasted Energy.
The Power Supply tries to keep up with the call for power, cannot, and components inside the Power Supply fail.
The Power Supply has a weak voltage power rail.
It may seem that the computer is receiving power, but it isn't receiving enough.
A) ALL the lights use less than 1 Watt of power
B) EACH fan uses 2 to 3 Watts of power
C) A typical Processor uses anywhere from 51 watts to 125 Watts.
Depends on what Processor it is.
The W3506 comes with an Intel Celeron D 352
(Single core processor, that operates at a maximum frequency rate of 3.20GigaHertz. 3.2GHz)
eMachines Support>Specifications>W3506,
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=W%20Series&model=W3506
Information on the Intel Celeron D 352 processor,
http://en.wikipedia.org/wiki/List_of_Intel_Celeron_microprocessors#.22Cedar_Mill-512.22_.2865_nm.29
The Intel Celeron D 352 can use up to 86 Watts, when operating at maximum capability.
This is why it may seem as though the computer is working, but in actuality it isn't.
The Processor isn't running.
No Processor operating, no computer.
No computer, No Signal to the monitor.
No Processor running, there is nothing to make the Operating System work. (Windows XP is one example of an O/S)
No Operating System working, the keyboard isn't going to 'light up'.
From here the diagnoses should be to test the Power Supply, or replace it with a KNOWN to be good, compatible power supply for a test.
[Compatible being the Power Supply has enough Wattage, the correct power cables, and enough of the correct power cables]
The Power Supply can be tested in the computer, with all the power cables disconnected.
Use a multimeter, or a power supply tester.
Example of an economical Power Supply Tester,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5250576&CatId=5471
This gives information on the various power cables used, in a personal computer,
http://www.playtool.com/pages/psuconnectors/connectors.html
Using the multimeter, the Positive (Red) probe is connected to the power wire to be tested, then the Negative (Black) probe is touched to a Ground wire.
There are three main voltages, given out by a personal computer power supply, (All are DC volts),
1) The 3.3 Volt power rail.
Wires that have Orange insulation are 3.3 Volt wires
2) 5 Volt power rail. Red insulated wires
3) 12 Volt power rail. Yellow insulated wires
For 12 Volt power, 11 to 13 Volts is okay. Below 11 Volts it's time for a new power supply.
4) ANY Black wire is a Ground wire.
Questions? Post in a Comment.
May 19, 2010 | E-Machines eMachines Desktop PC
Need correct MOB location for power switch on emachine W3410.
what kind of motherboard did you change..?
try to search in the internet.. just type the name of the board and including the diagram.. sample.."ASUS MOTHERBOARD POWER DIAGRAM"...
Apr 27, 2009 | Computers & Internet
Missing start up diac
I would try and contact emachines and see if they can help you but more than likely if you want windows you are gonna have to buy it. But Linux is free.
Apr 18, 2008 | E-Machines eMachines Desktop PC
eMachines W3506 PC Desktop Logo
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
