Question about HP Officejet 5610 All-In-One InkJet Printer
How do i correct a paper jam in 5610. What manual
How do i correct a paper jam in 5610. What manual tells me to do does not work
sagarjd
  • 95 Answers
SOURCE: paper jam 5610 hp
Please perform the steps in the following weblink.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00441807&dlc=en&product=441125
Regards,
sagarjd
Posted on Nov 05, 2008
  • 230 Answers
SOURCE: Paper Jam error with no paper ...
Put your hand in and poke at the front and poke all the levers and move things around a bit it sounds like a stuck switch and poking them normaly frees them up.
Posted on May 06, 2009
tumi001
  • 102 Answers
SOURCE: my hp officejet 5610 all in one keeps saying paper
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab47
Posted on Jul 17, 2009
  • 54 Answers
SOURCE: HP 5610 all-in-one fake "paper jam"
I request you to please perform the below steps to reslove false paper jam..
Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next solution.
Posted on Sep 04, 2009
ShreyRuleZ
  • 81 Answers
SOURCE: Hp offficejet 5610 printer showing paper jam
Try This :
>Open the rear access door clean the rollers inside it with the help of a Lint free cloth moistened with some distilled water.
>Check inside the printer if there is any paper jammed inside.
>Unplug the power cable from the back of the computer
> Keep on tapping the power button of the printer
> Plug in back the power button.
> Try to do a photocopy and see if it works .
> Again unplug the power cable from the back of the printer . Press and hold down the (#) & (9) and then plug in back the power cable . Then release the (#) & (9) button.
> It will perform a reset . If still it doesn't work check the link given below :
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00441807&cc=ca&lc=en&dlc=en&product=441125
Still if it doesn't works can contact HP for repair or Replacement
Hp No.: 1-800-474-6836
Regards
Shrey
Posted on Oct 07, 2009
It keeps telling me i have a paper jam and i don't
HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility.
Nov 11, 2010 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-in-One continuous paper jam,
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 04, 2010 | HP Officejet 5610 All-In-One InkJet...
The front pannel of my HP 5800 Officejet pro printer is telling me I have a paper jam but I cant find any after clearing an initial paper jam away. Other that the back cartridge is there another place I...
Lift the cover just as you would to scan a document. Then, lift the side of the cover directly to the left of the glass, closest to the glass, and check for jammed paper.
Nov 30, 2009 | HP Officejet 5610 All-In-One InkJet...
My 5610 all in one series keeps telling me that there is a paper jam. I have checked and there is no paper jammed in the printer. It won't reset. It keeps saying paper jam. Help!
Check to make sure both ink cartridges are installed properly. I don't know why it says "paper jam" when the cartridges aren't properly installed, but it does.
Aug 25, 2009 | HP Officejet 5610 All-In-One InkJet...
Paper jam won't clear.
Try to clean the feed rollers and see if that works.
Jul 31, 2009 | HP Officejet 5610 All-In-One InkJet...
My 5610 wont print on cardstock, creates paper jam!
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
alkkk-2
Jul 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Paper Jam Error Message
hi,
djiu9ofdfd22
Apr 20, 2009 | HP Officejet 5610 All-In-One InkJet...
I have a hp 5610 that gives me an catridge jam error
its should be caraige jam ... remove the catridges try to move the caraige ... and hope that it doesnt move freely ... than check for any paper jams than put the cartridges again and see
Feb 01, 2009 | HP Officejet 5610 All-In-One InkJet...
HP OfficeJet 6110 All-In-One
go to hp.com, support and troubleshooting, type in your pirnter model number and download the user manual. follow the direction to disassemble the printer. you might not need to disasseble the printer, if you can see the jammed paper.
follow the direction and clean the roller and the printer head.
it should work.
Oct 05, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
