Question about Canon PIXMA iP90 Mobile Printer
How to disassemble canon pixma ip90 - Canon PIXMA iP90 Mobile Printer
Mike258
  • 1498 Answers
SOURCE: canon pixma ip90 green light
Hi there SWCopiers,
Four flashes indicates 'Ink tanks installed incorrectly' or 'Printer needs repair'.
Click here for iP90 ink tank install procedure.
Click here for reset procedure.
Click here for instruction on contacting Canon Support. They have been very helpful. If it turns out that one of your ink tanks is faulty, they have replaced them at no cost in the past.
Hope this helps.
Remember: Good things come to those who Rate!!
Mike
Posted on Aug 07, 2008
SOURCE: Canon Pixma ip90 printer
service error 5100
Posted on Jan 04, 2009
  • 5 Answers
SOURCE: Print head for Canon Pixma
take print head out of printer and put a couple of drops of inkjet cleaner on the gauzes, dab off, reassemble and run the deep clean a few times. Printer should then work.
Posted on Apr 15, 2009
  • 71 Answers
SOURCE: Canon Pixma iP90 - Jagged text and lines
The printer has a plastic band that runs from one side to the other. The print head has a sensor that passes over it each time it moves. The band is a little transparent and appears to have vertical lines in it. That needs to be cleaned.
  1. Remove power from the printer,
  2. Wipe it clean,
  3. Move the head manually to other side to clean the other areas.
Hope this helps.
Posted on Jun 02, 2009
  • 130 Answers
SOURCE: my Canon Pixma IP90 will not print. It pushes the paper
you going to take printer in for repair.or get a new one
Posted on Jul 18, 2009
How to work a Canon PIXMA iP90 printer in win 7
Hi miggoservo,
If you cant use your printer, you need the driver. Try to click the link: http://drivers.softpedia.com/get/PRINTER/CANON/Canon-PIXMA-iP90-Printer-Driver-Vista32-200.shtml
Hope this helps.
Thank you for using Fixya!
Sep 24, 2011 | Canon PIXMA iP90 InkJet Printer
We need to get canon ip90 printer driver software for window 7 ,pls
Hello. You can find the drivers here and follow the steps below:
1. Under About Pixma iP90, click on Drivers & Software.
2. Then Choose Operating System
3. Click Drivers.
4. Finally download the file name aomwin110ea23us.exe ( File size 4.10MB)
Jun 14, 2011 | Canon PIXMA iP90 InkJet Printer
Would not print, oraqnge light blinks 5 times then one green flash. Open the door to ink and the head does not move to center as it used to.
This is a waste ink code and needs to be reset. follow instructions below.
Canon pixma iP90 released almost at the same time with canon Pixma iP 1880. Canon iP90 is printer with single function. Cartidges which used in canon Pixma iP90 is BCI-15BK, BCI-115C dan BCI-16C. Resetting procedure canon iP90 almost the same as manual reset canon iP1880. You can use combination of button in the printer to reset the printer.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off .
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indocator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
Please rate my help++++Thanks for using FIXYA
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Nov 24, 2009 | Canon PIXMA iP90 Mobile Printer
CANNON IP 90 PRINTER PROB: ink try full. how do i clean it? i saw instructions on resetting codes. it will not print at all...HELP...Thank You!
How to Reset The Canon Pixma iP90 PrinterHere is the reset procedure for the Canon iP90 printer, which uses the BCI-15BK, BCI-115C and BCI-16C cartridges.
Just follow these step by step instructions, to reset the Canon Pixma iP90 printer
  1. Turn printer OFF.
  2. Press the RESUME button together with the POWER on button.
  3. While pressing POWER on button, RELEASE the RESUME button.
  4. Press RESUME button TWICE then release both buttons.
  5. The green LED indicator will start blinking, then stop.
  6. Wait until the Power LED lights are green, then press the RESUME button 4 times.
  7. Now press POWER button OFF.
  8. Turn printer ON again, your Canon iP90 printer should now respond normally.
  9. If you need to unclog your print head click on next line
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros Magic Inkjet Flush Kits (Ebay)
Sep 12, 2009 | Canon PIXMA iP90 Mobile Printer
My Canon Pixma IP90 will not print. It pushes the paper
Jul 18, 2009 | Canon PIXMA iP90 InkJet Printer
Pls enter this webpage, in select category pls select printer
in select product type, pls select PIXMA iP series
in select model pls select PIXMA iP90, then click on the GO button, you should now be in another page where you need to click on the Drivers and Downloads tab
in the Select OS, pls select whatever you are using
pls click on ip90vst200ej.exe to start your download.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | Canon PIXMA iP90 InkJet Printer
Canon pixma ip90 printer
if your printer is flashing 4 orange and then back to green repeatedly - i found a solution to it for my ip90v - i opened the printer and checked the right hand side cogs - carefully turn them and you may see that some stray paper jam debris is blocking the cleaning unit from returning to its home in the bottom front of the printer - carefully remove it and replace the casing - turn on and with any luck you will have a dully functioning ip90 like i did.
Hope it helps some others out
Mar 12, 2008 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA iP90 Mobile Printer Logo
21 people viewed this question
old marine
old marine
