Question about Sewing Machines
Singer touch sew 645
I am having problems with my Singer 645's tension and I can't find my manual. As I sew, the bobbin thread catches, knots and loops as I sew. Help! and thank you.
    Scholar:
  • 102 Answers
Singer website has a plethora of manuals to download, http://www.singerco.com/accessories/instruction-manuals is the link, your manual is there for $15. If the bobbin thread is knotting up in the bobbin then I'd say you need to rewind a fresh bobbin and make sure it is smooth with even tension as it goes onto the bobbin. If your bobbin thread looks a bit chunky and uneven, then you won't get good results from it. Also, check that you are putting the bobbin into the bobbin case the right way, the thread needs to come off the bobbin and make a reverse direction into the tension spring (assuming yours is a removeable bobbin case, not top loading)
Posted on Oct 12, 2013
  • 19 Answers
SOURCE: Singer Simple bottom thread is loose
hi there
raise pressure foot up thread making sure thread passes between thread guide this should solve problem never alter bobbin tension,
mary h
Posted on Dec 30, 2008
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Posted on Aug 16, 2009
SOURCE: singer touch and sew 648
Thread the machine as if you were going to sew. When you thread the needle, pull the thread off to the left and wrap it around the thumb screw on the left and just above the needle. Wrap it only 2 or 3 times and hold the end of the thread. With bobbin in place and the face plate slid open, push the thumb lever on the left under the face plate to the left. Begin to 'sew'. As you do, the bobbin will wind and the thread you are holding will detach. Once the bobbin is full to the outside line, slide the face plate the closed position. As it closes, it will release the thumb lever. Put the needle in the slightly lowered position and slide something blunt under the pressure foot pulling thread from both the bobbin and the needle; cut the thread when you've pulled it out sufficiently.
Posted on Apr 16, 2010
  • 139 Answers
SOURCE: Singer touch n sew 750 winding bobbins
You can find Singer bobbin winding instructions at http://www.singerco.com/resources/bobbin_wind.html.
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
SOURCE: how to thread the bobbin on a singer touch and sew model # 625
how to wind the bobbin of the singer touch and sew model 625
Posted on Jul 26, 2011
The drop in bobbin on my Singer model 600 will jam up when sewing. It will be okay for a short time and than jam up again. It will cause the thread to knot up when sewing w/material. Help
may have to go into an authorized singer repairer for that problem..
might not just be the bobbin but the tension of the cotton winder for the bobbins
or needle pickup issue
Page 1 Instructions for Using Touch & Sewo DELUXE ZIG2ZAG ...
www.singerco.com/uploads/download/1310_600revised.pdfInstructions for Using. Touch & Sewo. DELUXE ZIG2ZAG. Sewing Machine. Model 600 by SINGER. T H E S ' N G E R C O NM P A N Y ...
Oct 11, 2016 | Singer Sewing Machines
My singer touch n sew model #645 is not drawing up the lower thread. How can I fix?
here is a link for a free manual, also try changing the needle, make sure the bobbin is turned counter-clockwise, even try a different bobbin. try rethreading the sewing machine, also be could be a timing problem.
http://www.singerco.com/uploads/download/794_white-645-x.pdf
Dec 13, 2014 | Singer Sewing Machines
I have a singer touch and sew and the bobbin keeps knotting up when i sew. what could be the problem/
You may have tangled thread or the bobbin not threaded right. Totally rethread your machine according to your manual. If, you do not have your manual handy, download one for free at singerco.com. Good luck
Sep 12, 2010 | Singer Touch Sew 7462 Mechanical Sewing...
Singer 301a sewing machine does not sew for more than 2 secs...top thread just knots into a huge ball on bottom of fabric...everything is threaded correctly and all tension set well...next step is trash...
Recheck the top thread and bobbin tension for equal balance of thread when sewing. The knotting of thread problem is usually because the tensions are too tight or too loose and/or thread may not be properly threaded. Another reason is when the bobbin thread is wind imbalanced it will cause the thread to knot-up when sewing. This problem is notorious when the bobbin is winded within the bobbin case on some machines. The bobbin thread need to be wind smoothly in the bobbin to avoid this problem.
Jan 24, 2010 | Singer Sewing Machines
Bobbin thread knotting up
Well I have to say the first problem is with "we sew". How many people are trying to sew at the same time ": ).......
That was supposed to be funny by the way.
The problem is listed under Singer but you didn't include the model #.
Depending on what model it is it may be a factor so please respond with that info. Thanks.
What I can tell you is that the most common cause of this is incorrect bobbin tension.
Oct 27, 2009 | Singer Sewing Machines
I purchased singer bobbins to use in my singer 5050. I thread the machine and bobbin per manual instructions, but when sewing, the thread severely bunchens and knots up on the bottom side of the item I'm...
Sep 30, 2009 | Singer 5050 Mechanical Sewing Machine
The thread keeps knotting up near the bobbin on my older model singer
Sounds like a tension problem. You may can email the singer company at talktous@singerco.com
Jun 24, 2009 | Singer Sewing Machines
Jun 21, 2009 | Singer 7442 Mechanical Sewing Machine
Problems with Singer 2732
Jan 02, 2009 | Singer 2732 Mechanical Sewing Machine
Sewing Machines Logo
103 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
