Question about Music
Kurzweil rg200 stop squeaking foot pedal
How do I restart when Kurzweil Mark 12 1999 piano hangs at waking up scanner message?
Hard reset procedure
1. Turn the Kurzweil off
2. Hold down the KEY START, KEY STOP, and LAYER VOLUME buttons for 5 seconds while powering the unit up, then release
3. Select RUN DIAGS
4. Press the UP arrow until the display reads RAM TEST
5. Press the START/STOP button to run the test
6. When the display reads SUCCESS, turn the unit off and back on. The unit is now reset.
If your Kurzweil still does not come up to the normal screen after this procedure, it will require service.
Apr 14, 2016 | Kurzweil Music
Kurzweil M1 digital piano is resetting (shutting down and turning on) on its own in the middle of playing.
You're correct, that's a power supply problem, but it may also be the power supply connector on the keyboard. If you have access to a voltmeter, check the power supply first.
Apr 06, 2016 | Kurzweil Music
I am looking for a manual for the Kurzweil Reader Model 7315-60.
Your best bet would be to contact Kurzweil Customer Service directly.Here isa link to their Support page-
Kurzweil Education
Feb 23, 2015 | Music
Cuts out on me while playing
If you';re sure it's the instrument, rather than your amp cutting out or the cord being intermittent, do a factory reset. Beyond doing a reset, it's doubtfull this will be a user servicable problem. You need to contact Kurzweil Support. Here is a link to their page
Support Kurzweil
Feb 08, 2015 | Kurzweil SP3X 88-Key Stage Piano
Tell me some tips and tricks about using the Kurzweil sp3x stage piano
The place to get the best help for Kurzweil gear is Sweetwater Sound.
Other than that, always use it in stereo mode with a decent sound system. Always use speakers with at least a 15" woofer and a horn to get the full range of sound it's capable of.
May 18, 2014 | Kurzweil Music Systems Kurzweil SP3X...
Kurzweil eg 20 piano keys sinking
You may not have the patience level to attack it. Few ppeople do.
Sep 25, 2012 | Kurzweil Music
I NEED KURZWEIL PC2X MANYAL
http://kurzweil.com/content/migration/downloads/pub/Kurzweil/Pro_Products/PC2/DOCS/PC2V3MAN.ZIP
May 06, 2012 | Music
Hi, i purchased yamaha fc15 sustain pedal yesterday. when i connected this pedal to my Roland E-09 keyboard through foot switch port, it activate Start/Stop button ( of arranger & song controls ) and...
The answer is NO... Roland uses the opposite sense switches on foot pedals... They use NIRMALLY CLOSED and your Yamaha is a NORMALLY OPEN switch.
SOMETIMES you can open these pedals and find that the pedal has the opposite sense switch available and you only have to unsolder and move one wire to make it a NORMALLY CLOSED pedal.
Dec 24, 2010 | Yamaha Fc5 Sustain Footswitch
I don't know how to set my roland u-20 for using a hold pedal "Kurzweil". My hold pedal is new, but i can´t make it work.
The Roland requires a NORMALLY CLOSED contact and that usually cannot be changed.
You will need to reverse the contacts in your pedal to meet that requirement.
OFTEN the pedals have BOTH contacts and you just have to unsolder and move the wire to the opposite contact. This is a common problem
Oct 29, 2009 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
Kurzweil digital piano unpredictable voices and volume
The contacts of various switches and keys are likely dirty. They are often conductive rubber and need cleaning with 99% isoprophly alcohol and q-tip. Clean both the conductive rubber pill and th circuit board traces they contact.
Sep 17, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Music Logo
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
