Question about Electrolux EW1000i Front Load Washer
The washing machine is counting down minutes but not doing anything and when I hit cancel the door is still locked
  • Official Brand Answer
  • 4,342 Answers
Good Morning Tara, I am happy to assist you!
If your door is in the locked position, first reset the power to the unit for about one minute. Can you open the door? If so, the main control board may need replacing. If you cannot open the door, then the door switch assembly may need to be replaced. This is not a typical DIY job. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. Parts are often costly and if the problem is precisely diagnosed, it can save you a lot of time and funds. I hope these troubleshooting tips help you in some small way.
Posted on Oct 11, 2013
I was using the spin cycle to spin water from a scarf. I decided to stop the stop so I hit cancel button. Now the washer door is locked and I can't open it.
• If the cycle is interrupted during spin, it will take approximately 2-3 minutes for the door lock to release. DO NOT force open the door. • To stop the washer, press Cancel.
Jan 05, 2011 | Frigidaire Affinity ATF7000E Front Load...
My washer has 14 mintues left and it is blinking 14
you can try to unplug the machine for 30 minutes, let it reset itself that way. I'm not sure that'll work but it's worth the effort. What do you have to lose?
Aug 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Unable to cancel cycle and restart machine
Instead of hitting cancel twice, only press once,. You should hear the washer unlock. Then try to start again. If that doesn't work, try unplugging the washer in mid cycle. Are you getting and codes popping up?
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
Not responding to anything!
Unplug it for 30 min to reset some time 2 hours. It has a computer in it That is like rebooting.
Jan 13, 2009 | Kenmore Elite 45986 Front Load Washer
Clean light flashes constanly. Won't clear out to start new cycle
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Door would not unlock - got an error code f-22 what does that mean?
well all you have to do is hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
Jan 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door locked
f 22 is the code for door Lock failed after six tries try hitting pause/cancel twice if door unlocks spray lock with wd 40 try again and advise
Dec 29, 2007 | Whirlpool WFW8500SR
Electrolux EW1000i Front Load Washer Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
