Question about Refrigerators
Tube Drain WR02X11426 broken on GE GSS23WGTA WW refrigerator. It was laying on the bottom of refrigerator. Where does it go?
fridgetech
  • 473 Answers
SOURCE: clogged fridge drain tube
The drain is behind the back panel in the freezer at the bottom. Sounds like it is frozen over which is pretty common. Will need to remove panel and thaw out drain by running hot water down. You can use a putty knife to break up ice first. Make sure you get all ice around the drain above and below the thin aluminum tray at the bottom. After the drain is free don't be alarmed if you get some water on the floor because the drain pan may not hold all of the water you ran down the drain. Not anything you can do to prevent this on this model.
Posted on Oct 07, 2007
CRTN
  • 716 Answers
SOURCE: GE Side by Side GSS22JERFWW not keeping cold
often there is a cover in the rear of the freezer with some screws remove these and put low temp grease on the fan. The Problem Is %100 The Fan So If You Look Up Your Fridge On Google It Will Tell You Where The Fan Is.
Posted on Jan 05, 2009
Sea Breeze
  • 4655 Answers
SOURCE: TFX25PR TFT25 PR GE Profile 25.2 cu
Here are som links that will be helpful. I believe ice is blocking the defros condensate dran behind the freezer back wall of the freezer compartment.
Here are some helpful links.
http://appliancejunk.com/forums/index.php?topic=22.0 and http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/ Pour a warm solution down the drain with Clorox and I think that will help too. Hope this helps. Thanks, Sea Breeze
Posted on Jul 28, 2009
  • 864 Answers
SOURCE: GE side by side refrigerator(GSS22ifrf ww) not cooling
Try unplugging it for 30 seconds and then plug it in again. It may reset itself that way.
Posted on Jul 29, 2009
  • 401 Answers
SOURCE: I have GE Profile PDS18SBMRBS refrigerator. The
This sounds like it is not defrosting, plus the drain may be clogged not letting the water drain. The drain clog will not block the fan, but not defrosting will.
Posted on Jan 03, 2010
How to fix pn:PS8691807 on whirlpool refrigerator model EB9FVBRWS05
Are you referring to the drain tube, if so you have to disassemble the freezer remove the back panel and pour hot water down into the drain tube until it flows into the pan under the refrigerator. laying towels in the bottom of the freezer floor with help keep the mess to a minium
Dec 24, 2015 | Whirlpool Refrigerators
Water is freezing in the bottom drawer GEProfile bottom drawer freezer and leaking water on floor
Sounds like your drain tube is blocked in the freezer for the defrost water. The drain tube is in the back left or right corner and will have a drain trough under the cooling coils tilting towards it. That trough will probably have ice built up all over it. Once the ice is out you may need to force hot water down the drain tube. I use to use a turkey baster with a rubber hose on it to force the hot water down the drain tube. Its clear when you put water in the trough top and it goes down the tube freely to the drain pan under the refrigerator.
Feb 28, 2015 | GE Profile PDS22MHR Bottom Freezer...
Water leaking under model hss25gfpe ww
If your refrigerator has automatic defrost, the evaporator tray in the bottom could be defective (damaged), maybe even missing or mispositioned. Also, the drain tube could be mispositioned, damaged or defective
Mar 06, 2013 | Refrigerators
I have a GE side by side model #tfx22jrba ww and it is leaking. It is wet under the left front corner. I took off the grill to see if I could find the drip pan and see if it was full but didn't see it. Any...
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Sep 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE model # GSS22WGMD-ww. It is leaking from the bottom on the freezer side. Is it possible that the tube that provides the water supply may be the cause? Lee Giermann
in the back of freezer at the bottom there is a drain. it is iced over causing the water to come out the front. defrost drain and force some water through it this will correct problem . . algi gete in tube and stops water causing ice over .. ****
Jan 05, 2010 | Refrigerators
My refrigerator started leaking underneath on the right back side. Can you tell me what is wrong and what needs to be done?
If you have icemaker in your fridge - remove cover on the back and down and check the plastic water tubing for cracks and loose connections.
If nothing found or you don't have icemaker - there is a drain pan on the bottom, behind the same back cover. Check if it has any cracks or tilted. Check if the drain tube is routed to the drain pan and is securely attached to the drain port on the bottom of the fridge.
Oct 12, 2009 | GE Â 17.9 Cu. Ft. Top-Freezer...
Water is pooling in the bottom of the refrigerator. this model does NOT have an automatic ice maker, nor is connected to any water source. model #frt18g4awo
This is usually caused by the drain tube being plugged. There is usually a collector tray mounted under the refrigerator near the compressor and a small drain tube that runs into the refrigerator. The tube will plug with slime and green mold over time. Without knowing the model or make I cannot tell you for sure where the tray is located. If you find the tray you should see a tube laying into or hanging above the tray and running up to the refrigerator. Clean this tube and the little drain hole in the refrigerator with a pipe cleaner or soft piece of wire. Also check your door seals as a bad seal will also cause excess moisture to form in refrigerator, and children constantly opening and closing will also cause excess moisture to form and if the drain is plugged it will build up in the bottom.
Oct 07, 2009 | Refrigerators
TFX25PR TFT25 PR GE Profile 25.2 cu ft no frost Serial GS248611 Model TFX25PRYD WW Water collecting and freesing in bottom of freezer side and running out the front, Drain tube at back is NOT...
Jul 28, 2009 | Refrigerators
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
