Question about Panasonic KX-T7420 Corded Phone
How to reset the panasonic kx-t7420 message system.
cnavarro
  • 2460 Answers
SOURCE: Panasonic telephone system KX-TD816e
re:reset On the side of the cabinet near the power switch is a reset button and a SET CLEAR switch. Turn off the system, put the switch in CLEAR and push the reset button with a pointed tool. When the red light flashes and within 10 seconds, put the switch to SET.
I'm hoping you have a programming manual even though you must not have an installation manual.
Carl
Posted on Dec 04, 2008
  • 19 Answers
SOURCE: how do i pre-set an area code so i don't have to
What phone system are you using? we will need to know the exact PBX or KSU to help. If your phone is a 7420 could be on a number of units, you will also need a 7430, 7453 or other display phone to program. In some cases this may not be an option or could require programming software by your vender to make work.
Reply and we can take this the next step.
Posted on Aug 10, 2009
cnavarro
  • 2460 Answers
SOURCE: I have a Kx-t7420 panasonic phone system.
Actually, you have a Panasonic TD phone system and a 7420 phone, but no matter. The feature you have is probably "idle line preference" or "preferred Line Assignment-Outgoing". In TD systems by default, you select lines from highest to lowest. If you only have 2 lines and PLA is set, you get line 2 then line 1. You can change it to get line 1 first, or chage the trunk access order. The first is something you can do from each phone, the second requires access to system programming. The bad thing about the first solution is if line 1 is busy, you won't get any line. The second will give you the entire trunk group.
Anyway, from each phone without picking up the handset, press PROGRAM 99 and dial 1301 STORE. That will give you line 1 when you pick up the handset. Just so you know or can change it, 11 is none, 12 is idle line, 13xx is specific line and 1+the intercom is intercom. Pick up the handset and drop it back down to exit programming.
As far as the noisy line, it's probably a central office issue. It's hard to test as that line is the outer pair of the jack that plugs into the phone sytsem (RJ-14 pair 2), but you can probably take a regular phone and test it at the demarc point.
Carl
Posted on Jul 14, 2010
cnavarro
  • 2460 Answers
SOURCE: Need to change password on voicemail extension on
If it's a Panasonic brand voice mail, you administer the system from the System Owner's mailbox (999). With that, you can use option 4 or 5 and reset the mailbox password to any and all mailboxes (except 999 :-)
Carl
Posted on Sep 03, 2010
cnavarro
  • 2460 Answers
SOURCE: Panasonic KX-T7420. There are several of these
Reset? How about you just program new ones over the old? I'm guessing you mean intercom DSS buttons, so you dial PROGRAM 99, press the button and dial 1+ the new extension STORE. Keep doing that to all the buttons you want to program and then pick up the handset and drop it back down again when you're done.
Carl
Posted on Dec 23, 2010
Hello i have a Panasonic KX-T7420 phone. how do i listen to the messages? thanks
Which ones? A Pana brand VM has an access code of 165. Your personal messages are in your box, the system messages (General Delivery Mailbox) are in mailbox 998. When you dial 165, you're automatically in your box. Mailbox 998 has a special access code that you dial and use to retrieve messages. We try to prevent messages from being dropped into the GDM, but it happens.
Carl
Apr 13, 2011 | Panasonic KX T7436 Corded Phone KX-T7436
Need to change the ringtone on Panaswonic KX-T7420. How do I do that?
I'm going to guess here, sort of. In the TDA's, it's PROGRAM press the button twice, and dial a number and store. So, in your TD system it should be PROGRAM 99 press the button twice, and dial a number from 1-8 (1 being the default) and STORE
You have to do this from each line and intercom you want to change.
Carl
Feb 11, 2011 | Panasonic KX-T7420 Corded Phone
We have Panasonic KX-T7420 Switchboard but no voice message in the phone system, how do I add that into the system and the cost?
You add a Panasonic brand voice mail system. You can do it yourself, but it's easier to call a dealer. You have to have a specific issue software on your TD phone system and it requires programming, both in the voice mail and the KSU. I charge about $700 for the hardware and programming, your Pana dealer will probably charge about the same.
If you want to gamble, you can probably pick up a used TVS voice mail box for less than $400, but again, there are so many boxes that don't work. As a minimum, a TVA-50 would be best, since it's the current manufacture and it can be upgraded.
Carl
Phone line went down need to reprogram voice, transfer button for panasonic KX-T7420 DIGITAL PHONE
Program 99 press the button and dial 8 165 STORE. That assumes that you're using the default VM access code.
Carl
Feb 09, 2011 | Panasonic KX-T7420 Corded Phone
Panasonic KX-T7420 New arrival in the company.old employee's message is on voice mail, plus I don't have the password. How do I reset?
You log into the system owner's mailbox (999) and follow the prompts to edit the mailboxes. One of them will let you reset the password.
Carl
Feb 01, 2011 | Panasonic KX-T7420 Corded Phone
Our office has both T7420's and T7433's, and I'm trying to work on changing the initial voicemail message, as well as having each individual extension receive their own voice mail, password to access it,...
Voicemail passwords are in the VM system, not the phone system. You add and delete mailboxes and reset passwords from the VM owner's mailbox (999).
There is an installer's password to your TD phone system, it is controlled from the manager's or attendant's phone. If you don't know it, you can't mess up your system. The installation manula has instructions.
Carl
Dec 24, 2010 | Panasonic KX-T7420 Corded Phone
Panasonic KX-T7420. There are several of these phones in our office, I would like to know how to reset all extension numbers at each phone and create new ones.
Carl
Dec 23, 2010 | Panasonic KX-T7420 Corded Phone
Carl
Sep 03, 2010 | Panasonic KX-T7420 Corded Phone
Hi: I have a Panasonic KX-T7420 phone. When one of the incoming lines is ringing and I pick up the handset, it picks up the intercom and not the incoming line. Is there a way to get the thing to answer...
There are 2 things that would prevent you from being able to answer a ringing phone by picking up the handset. Your phone has to be ringing, and you need to set preferred line ringing on incoming calls.
The second part is easy. Press PROGRAM 99 and dial 22 STORE on your phone. Now when a call rings on your phone you can pick it up. If you can't, then your phone is not ringing.
Ringing is set in system programming.
Carl
Aug 04, 2010 | Panasonic KX-T7420 Corded Phone
How do i pre-set an area code so i don't have to dial it every time? The office uses the panasonic kx-t7420 phones. Thanks
Aug 03, 2009 | Panasonic KX-T7420 Corded Phone
Panasonic KX-T7420 Corded Phone Logo
27 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
