Ineed the wiring diagram for a charmglow electric stove hbl 15sdlp/m 20
4 Suggested Answers
red54eyejp
  • 25 Answers
SOURCE: Broken thermostat for the Charmglow HBL-15SDLP/M20
you can get your parts at this web site.................www.grillstuff.com......scroll down to CHARMGLOW parts..enter your model # ...they will ship the part to you...I was just at that web site to verify.....GOOD LUCK..!!!
Posted on May 09, 2009
SOURCE: I have a Charmglow model HBL-15SDLP/M20 electric
The switch itself is a (double pole single throw ) 15 amp 250 volt /20 amp 125 volt.You can buy any switch like that.The hard part is trying to find the same size to fit the hole in the heater.
Posted on Nov 24, 2010
SOURCE: Charmglow electric heater blown fuse
Fuses blow for a reason. Almost every time there is a high amp draw due to many possible reasons, power is to unforgiving to gamble.
Posted on Oct 26, 2012
Need a wiring diagram for a rse37bal3
Your Frigidaire motorcycle has an electric stove?
Most stoves I have worked with in the past have had the wiring diagram glued either to the back or under the top. I have never seen one installed on a motorcycle, however.
Feb 16, 2013 | Motorcycles
Oct 25, 2012 | Leisure HOMEPRIDE Electric Fireplace...
Wiring Diagram Defy 521 Electric Stove
NEED A WIRING DIAGRAM OF A DEFY 521 ELECTRICAL STOVE
Sep 29, 2012 | Kitchen Ranges
I have a Charmglow propane heater model CGL300TQ with a bad fan. Where can I find parts for this stove and does Charmglow have a website for parts?
Depends what is actually wrong with fan, if tis the blower barrel part you can by replacements but if its the fan and you van't find manufacturer try an commercial or indutrial fan place to match the one you have be careful to make sure that it is electrically compatible and that it will connect to heater safely and do as old fan did as fan speeds on heaters can be important
Nov 17, 2010 | Stoves Heating & Cooling
Charmglow, 2-stage electric fire stove made by the Elite Group. Fan/heaters no longer work. Switches operating items appear to work (light in switches illuminates). Checked for loose wires, all appear to...
If all looks good, you may have a "limit" switch in the circuit. Some "limits" have a manually operated re-set switch. Even the automatic ones can quit working. I would look for one of those first. ...Lee
Oct 20, 2009 | Fire Sense Corner Unit Electric Stove...
May 09, 2009 | Heating & Cooling
I have a Charmglow model HBL-15SDLP/M20 electric heater. The rocker switch went bad on it and I can't find a replacement part anywhere. The manufacturer said they can't get replacement parts. The part...
Apr 04, 2009 | Heating & Cooling
I have admiral Stove top burner is workni but oven is not working
This may be due to a bad main clock/electronic control but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Admiral Stove Parts: http://www.repairclinic.com/Admiral-Range-Stove-Oven-Parts
www.RepairClinic.com
Feb 03, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Schematic wiring diagram
I have a copy of a STOVES 720EF Manual (including wiring info) posted on BT Digital Vault. Supply an email address and I will give you access to take a copy.
parsonm
Oct 30, 2008 | Stoves 720EF Electric Double Oven
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
