Question about AKG Audio Players & Recorders
AKG UHF PR40 pocket receiver has static noise on output even when powered off
2 Suggested Answers
ButtFuzz
  • 463 Answers
SOURCE: it powers up....no modulation ...output power..or
Sounds like the PLL may be toast. Either that, or someone has **** with the wrong potentiometers or tuning slugs in the radio, causing to to no longer resonate on the correct freqs.
Posted on Mar 02, 2009
Surha AKG uhf ht 40 handheld mic
You need a pop filter while recording. There are different reasons why a "pop" would get recorded in the signal. Either because of the harsh P's and T's while singing or rapping like "Business", "Pain", "Property", etc. or it could be jitter problem due to an unstable clock. Mostly you would recognize these ones cause they don't sound like the pops coming out o a persons mouth. They're more like clicks. Your problem, from what I understand is due to the former reason. That's why you will need a pop filter.
Jul 06, 2014 | AKG Audio Players & Recorders
Error code F441 on akg HT 450
Anyone find an answer? Or did you just buy a Shure?
Mar 13, 2014 | AKG Ht450/D Wireless Uhf Handheld...
I Have 2 recivers and 4 mics but can't use all 4 only 2 works
A wireless mic receiver will only reliably work with one mic at a time. For that reason, you need to have 4 receivers in order to use 4 mics simultaneously. You could switch back and forth between mics by setting them to the same frequency and turning them on and off, but they will not work reliably if they're both on at the same time.
Nov 10, 2013 | AKG SR40 - UHF Receiver SR4054 Microphone
I have the AKG wms 40 dual mini mic set with two wireless mics. When mic on ch 2 is in the off position, I get lots of static. Works perfectly fine when on. What do you think is the issue?
Channel 2 mic's receiver needs the Squelch adjusted. The squelch control mutes the receiver so that when the transmitter stops transmitting, erroneous noises are not picked up and amplified.
Jan 23, 2013 | AKG WMS 40 Professional Microphone
Unit is an AKG SR40 Dual Pro Wireless receiver, PT 40 transmitter. 662.3Mhz operating frequency. The right side channel is hypersensitive and indicates that it is picking up a signal when the transmitter...
I would suggest that you change your operating frequency. The antenna being removed suggests that the receiver is picking up interference on that frequency. This frequency is in the UHF TV band, and although analog TV no longer exists, digital TV still uses some of the frequencies.
Nov 04, 2017 | AKG Radio Communications
Static noise in headphones over music
well dumby all you got to do is get some new headphones, it's like 10$ stupid
Jun 01, 2010 | AKG K 206 Consumer Headphones
Static in speakers
I own this receiver, I assume you refer to the "hiss" rather than actual static.
I've found it seems to be related to temperature/humidity changes especially going from warmer to colder. And it is more pronounced from the analog audio outputs. Here is what I've done to remedy the problem quite effectively and the noise floor is now very very low, inaudible in fact.
Don't turn it off. You don't have to be powering anything with it, just leave it on. It doesn't have a standby mode but leaving it on will help keep it a constant temp. It doesn't produce much heat at all even when playing very loud.
The digital outputs are considerably quieter than the analog outs. I haven't completely remedied the problem with the analog outs.
Use ferrite clamps on the power cord and the analog audio outputs. Three on each helps.
You may notice that if you turn it off for a while, or your room gets cold or humid it gets more pronounced even when the above tips are employed. In this case I've discovered that simply playing it, let it "warm up" for example while movie previews are on at a moderate level, can make it go away.
Mar 22, 2010 | Sony STR-DA3000ES Receiver
Akg sr40 wireless microphone
take your broken aerial and go to (radio shack)near you and buy a similar one and fix it in your system with screwdriver.
Apr 05, 2008 | AKG SR40 Diversity - UHF Receiver...
67 people viewed this question
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Vito Vacirca Jr.
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
