Question about Home Security
Cannot remember the combination of my bikemate mcp 30064 combination lock
I have a 3 digit 'Design Go' combination lock which we cannot remember the code (lock is in closed position) - how do we reset it so we can use it?
3 digits is only 999 combinations. You can dial each one and try it. Even if you are so slow that it takes 2 seconds per try, you'll go through all combinations in half an hour, and you'll likely find yours in ten minutes or so.
Oct 07, 2014 | Locks & Locksmithing
I have a black dog TSA lock and can't remember the combination help
if you have forgotten the combo the only way to figure it out is to progress the combo starting from 000 and then 001,002,003,004 etc...( trying the lock at every new series until you get the correct combo. a 3 digit combo should only take about 10 to 20 minutes to solve. you can cut the time in half if you can remember the first number or the last number.
chris...
Sep 13, 2012 | Ultra Hardware Black Dog 55164 3 Digit...
Cannot unlock my husbands tsa lock we are in argentina
To set/reset combination on TSA Cable Lock
TSA Cable Locks come preset from the factory to 0-0-0. Set the combination to 0-0-0 or your already chosen combination. if different than 0-0-0. To set the combination, use a pointed device such as a pen to press in on B. While pressing on B (do not release B until combination is set), pick your 3 digit combination.
Once all 3 dials are set to the combination you want, release B. Your TSA Cable lock Is now set to your combination. TSA Lock will NOT be locked at this new combination - turn one or more dials and your lock will be locked. To unlock, follow instructions above.
Please make sure to remember your combination!
You can also use the video below:
http://www.youtube.com/watch?v=OfchUwkEckI
Good luck..
Aug 26, 2011 | Locks & Locksmithing
I found 2 Kryptonite combination cable locks out of a storage box and do not remember there combination! Both are open! Is there a way for me to reset combination while there open? Thanks Denys
Probably not. But a simple solution for this is to turn the numbers and listen for a click when the tumbler locks into place. You' should be able to get the combination from both locks by doing this.
Aug 07, 2011 | Kryptonite Kryptoflex 1218 Combo Cable...
Lost combination for bicycle master lock. It has 229T sticker on it.
If you can remember an numbers in the combination you will just have to try all other numbers in combination until it opens
Apr 30, 2011 | Master Lock 8143DSG Combination Cable Lock...
How do you set your own combination for the locks on the briefcase,there were no instructions with the case
  • 1 Turn the lock to the correct combination and open the briefcase.
  • 2 Look at the lock. There should be one or two pins that you can slide with your fingers. If there is one, simply push it in. If there are two, push them together. It may be the same button you use to open the case.
  • 3 Change the lock to an easy-to-remember value, such as 000 or 123, to test the lock. Release the pin.
  • 4 Close the briefcase and turn the lock to another value. It should not open. Now turn it to the test combination. It should open right up.
  • 5 Repeat Steps 2 and 3, but this time choose a number that will be easy for you to remember, but hard for someone else to guess. Write down your new combination and keep it somewhere safe.
  • Dec 29, 2010 | Office Equipment & Supplies
    How to creeate a new combination for a sentry 1310 valueguard saf
    Have a 1310 Sentry Valueguard safe and cannot remember the combination nor can i remember where i put the paper that i once wrote the combination down on....need help!
    Aug 01, 2010 | Sentry FIRE-SAFE Combination Safe DS3431,...
    I don't remember the combination but it is open. please tell me how to set it
    same problem with the spinner model.
    My suitcase is open but since I dont have the lock combination (3 digits) I can't close it (not lock it, just close the case) . The combination changed when the case was open - is there a way to reset it ?
    Mar 05, 2010 | Samsonite Tripod
    Home Security Logo
    293 people viewed this question
    Top Home Security Experts
    Lawrence Oravetz
    Are you a Home Security Expert? Answer questions, earn points and help others
