Question about VeriFone Office Equipment & Supplies
TCP error 10030040 on VeriFone Vx570 - VeriFone Office Equipment & Supplies
SOURCE: How do I place a decimal point with Vx570 Verifone
you have to press the #1 key and then the alpha key till the decimal point appears.
Posted on Apr 13, 2009
puertobori
  • 7733 Answers
SOURCE: Problem with the VeriFone VX570 Credit Card
You can get the Installation Guide HERE.
You need To Install/Replace MSAMs where all previous information is stored:
1 Remove the power cord and/or battery (see Smart Battery) from the terminal.
2 Place the terminal upside down on a soft, clean surface to protect the lens
from scratches
3 Remove the MSAM compartment door screw and rotate the door up and back
to access the MSAM cardholders (see Figure 11).
4 Remove any previously installed MSAM card by sliding the card from the
MSAM cardholder.
5 Install an MSAM card by aligning the card and carefully sliding it within the
guides on the cover until it is fully inserted (see Figure 12).
Contact: VeriFone Systems, Inc.
2099 Gateway Place, Suite 600
San Jose, CA 95110
USA
Tel: 1-800-VeriFone (837-4366)
Main Tel: (408) 232-7800
Main Fax: (408) 232-7811
Posted on Jan 18, 2011
edward16
  • 59 Answers
SOURCE: Verifone Vx570 given an error modem profile not set?
error modem profile not set appears when your Verifone VX 570 modem profile is not properly loaded or has been errased due to Tamper error or Bad RTC. Reloading back the modem profile will sometimes fix the error, but there is also a chance that your I/O module (form where you connect the power and telephone wire) is also bad, thats needs to be repaired or replaced. Call (775)358-2922 ask for Randy. Thanks.
Backside of the I/O module of VX 570
Posted on Feb 03, 2012
edward16
  • 59 Answers
SOURCE: verifone vx570 checksum error
Maybe you have a corrupted program/application. Call your credit processor for the download process of your application. But before downloading, don't forget to batch and settle your unit if you can. Then clear all the old program in your machine. I hope this will help you. if need more help call (775)358-2922 ask for Randy. Thanks
  • 113 Answers
SOURCE: Tamper in verifone vx570's
Bad RTC and Tamper can be repaired. the machine is equipped with multiple sensors inside. if one of them goes bad, or the Battery is dead tampering or bad RTC will show this can be fix by replacing the sensor and or the battery if you need this to be done call me @ (775) 358-2922 hope this help : - )
Posted on Dec 01, 2012
We have a verifone terminal (not sure what model but I could find out) that keeps getting the tamper error. It's happened 7 times in the last 8 months. We've switching merchants which helped for a while...
Your problem presents more questions. Has your machine been refurbished during this time? Is the location in a restaurant or bar? Does the merchant turn off the machine daily? Does the machine get dropped often? These are all things that may cause the machine to go into tamper error. Please call Frank (775)338-6634
Jan 10, 2015 | VeriFone VX570 Credit Card Terminal (Dual...
Can a tampered vx570 credit card terminal be settled?
You can remove **tamper** error in your Vx570 through tamper removal software.
psoftware109@gmail.com
Feb 06, 2013 | VeriFone VX570 Credit Card Terminal (Dual...
Oct 26, 2012 | VeriFone VX570 Credit Card Terminal (Dual...
How do I reset a Verifone vx570
You need to reset your Vx570 through Reset Software.
Apr 26, 2012 | VeriFone VX570 Credit Card Terminal (Dual...
Verifone vx570 checksum error
Jan 29, 2012 | VeriFone VX570 Credit Card Terminal (Dual...
CHECKSUM ERROR ON VX570
It will remove through software tool then your Vx570 will working fine.
Verifone Vx570 given an error Modem Profile Not Set?
Jan 18, 2012 | VeriFone VX570 Credit Card Terminal (Dual...
Veriphone "Bad mac"
is your verifone you are talking about is a pinpad 1000se or the creditcard machine (VX510, VX570 etc.) and bad MAC (message authentication code) and i believe if the machine is not encrypted right or the encryption was errased for some reason, bad mac will appear. I've seen some of bad mac error together with tamper error on VerifonePinpad because the battery is going bad. Replaced battery and load the encryption, pinpad works again. Hope this will help you or call (775)358-2922 look for randy and maybe we can help you further. thanks
Nov 01, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
I need to unlock a NorthAmerican Bancard Verifone vx570. Z66831 only gets me past the first password inquiry and not the second
If that doesn't work, try "BEERTIME" or "23378463. if that still doesn't work, all we can do is flush the old program by opening the machine and disconnecting the internal battery, BUT TAMPER ERROR will come up after doing that and the verifone program needs to be reloaded to get the tamper out. Call (775)358-2922 look for randy and maybe we can help you
Oct 21, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
396 people viewed this question
Top VeriFone Office Equipment & Supplies Experts
George Mclaughlin
Willie Cooper
Willie Cooper
Are you a VeriFone Office Equipment and Supply Expert? Answer questions, earn points and help others
