Question about Weedeater 25cc 2-Cycle Gas Blower - FB25
Gas bubble will not prime ( fill with gas) - Weedeater 25cc 2-Cycle Gas Blower - FB25
I have a BG55 blower when I try to prime it no gas come in bubble. I have made sure there nothing in gas line,and it skeet when I put a pin in the little hole, but no gas when u try to prime.
Apart from the bubble there is at least one non-return valve that could be stuck or not working because it is dry.
Could be removing the bubble and wetting everything thoroughly with fuel and quickly refitting it could kick-start it and make it work.
Sep 05, 2016 | Stihl Bg 55
Pump bubble wont fill up with gas.
its leaking air.. maybe ahead of the gas line running unto the bubble.. is it leaking any gas at all?
Dec 07, 2015 | Stihl Garden
Gas line bubble not priming
most likely the bubble has a pin hole in it. replace the priming bubble.
Apr 05, 2013 | McCulloch Garden
I have a 124l e-tech trimmer and the prime bubble wont fill
Sounds like you have an air leak. Either in the primer bulb is split or punctured, hole or leaking fuel line or primer bulb base, and is sucking air instead of fuel.
Aug 20, 2012 | Husqvarna 124L 28cc Gas Line Grass Lawn...
Stilh trimmer wont start changed plug still doesnt even fire
Please make sure you have no leaks on the carburetor, if it has not been turned om for a long time, prime the engine for cold start. Here is how to do this.
Clug exhaust pipe while you crank it up.
Pump the bubble filled with gas closed to the carburator.
Thanks,
Jul 17, 2011 | Garden
I have a huskavarna leaf blower 140 back pac i run it for 5 min then it srarves for gas let off on the throtle for 10 seconds put on full it gos to full rpms the starves agian
Carburetor may need adjusting or rebuilding. I would try mixing up some fresh fuel mixture and try that first. Use gas from the station not from the can sitting in the garage.
Good Day.
Oct 28, 2009 | Husqvarna Backpack Blower, Model No. 356bt
Leafblower won't start
I assume this is a Gas blower? So first off is the gas bad? Did this blower sit for a prolong time? These do require premix fuel and you must add 2 stroke oil to the gas ... if you don't you will ruin the motor. Check the spark plug for corrosion. Also it should have a gas bubble to prime the Carburetor with ... make sure gas is flowing through this bubble you can tell buy pressing the bubble you should feel and hear the gas squish thou it. Also check inside the gas tank look at the feed tubes make sure they are not deteriorated if they are you may just need to get a new one. Good Luck
Sep 29, 2009 | Craftsman Garden
Primer bulb won't prime
it sounds like the filter on the fule line is cloged try to remove the filter and then try to prime the trimmer. it it does you need to replace the filter. just about any filter that will fit will do.
Jun 05, 2009 | Troy Bilt Tb70ss Gas Trimmer
Weedeater 25cc 2-Cycle Gas Blower - FB25 Logo
Top Weedeater Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
ray gallant
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
