Question about Maytag MDB7100AWB Dishwasher
Maytag Model # MDB7600AWW door will not latch
Problem with door latch.  Replace door handle and latch and dishwasher will still not work.  THe door latch sounds like it is latching but you can pull the door open.  when you grab the handle to open door you can hear a click noise as if it is trying to make a connection to initiate a cycle. Nothing happens
    Champion:
  • 219 Answers
Double check door latch make sure connections are proper if right and still not working probably main board and panel
Posted on May 01, 2009
The latch is sticking on my dishwasher. How can I
replace the door latch and the handle check to see if the console loops that hold the latch are broken if so replace the console
Jun 02, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Cannot open the dishwasher door. Maytag Quiet Ser...
This model has a problem where the handle must be depressed fully upwards to allow the latch to clear completely without straining the mechanism. The lip on which you pull open the door gives the operator a better handhold to force it open even when the mechanism is not fully depressed. Do this enough times, and the plastic tabs on the handle begin to fatigue and eventually break. The handle becomes lodged but can be forced down to eventually open the washer. By this time, a specific portion of the latch that depresses a micro-switch will most likely be broken, and the washer won't turn off if the door becomes ajar. Remove the torque screws along the inside perimeter of the door and you can spread the face panel open to access the latch unit for replacement.
May 19, 2010 | Dishwashers
My maytag quiet series is leaking from the door what do i need to do to stop this leak. The flow on the bottom right move freely.......
Not sure why your enquiry landed in the Kitchen Aid dishwasher category?
It is hard to provide suggestions without having the Dishwasher Model no. I have looked at the manual for MDB7600AWW which is one of the Maytag Quiet Series category. (they must be all similar I presume)
If the water leak is minor - it could be steam condensing from the top right corner vent that is used for drying the dishes.
Other sources of water leak could be -
  • foaming of detergent - use the recommended detergent
  • unclean door liner - clean the door liner
  • dishwasher is not level - refer to installations instructions
  • door liner is damaged - replace door liner
User Manual for Model MDB7600AWW
http://shared.whirlpoolcorp.com/assets/pdfs/literature/6_919201_A.PDF
Installation Manual
http://shared.whirlpoolcorp.com/assets/pdfs/literature/6_918789_Rev_A.pdf
Technical Information (won't be much help unless you are an expert in repairs.)
http://www.servicematters.com/maytag_library/docs/16023212.pdf
good luck
Jan 01, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
How do I replace the latch on my maytag quiet series 100 dishwasher?
Unfortunately, the Maytag quiet series models have plastic latch handles that are prone to crack after time.
You should be able to order a replacement handle through a distribtor.
If you can, unlatch/open the door. Using a star screwdriver, unscrew all the screws on the inside of the door frame.
Once all the screws are removed you should be able to separate the inside of the door from the latch assembly.
From there you'll need to squeeze the latch handle together and replace it in. I'll warn you that it feels like you have to squeeze the thing so hard you might break/crack it on your own. It is a hard/tight fit if I remember correctly.
One last thing you may want to do to is check the food grinder in the middle of the washer. Sometimes the cracked pieces of the latch can end up there stuck in the grinder causing it to be louder than it should.
Hope this helped.
Nov 06, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Maytag MDBH950AWB handle/latch failed.
Replaced handle/latch unit. Killed power to the unit. Removed the inside door panel then unplugged the two switches on the latch. Removed old latch with broken handle (removing inside panel frees latch/handle). Installed new latch with handle reconnected the two switches, reinstalled inside door panel. Very simple. Note: Latches can be purchased with or without the handle. Less expensive to buy with the handle already installed on the latch.
Jun 24, 2009 | Maytag 24 in. MDBH950AWS Built-in...
Broken handle on dishwasher
Bernie,
TURN OFF POWER TO UNIT. Open door, remove all torq screws from door panel, separate inner and outer door panel. latch assy is able to be removed, place black wire connector and white white connector back respectively, place inner part of door back and replace the torq screws. Then turn power back on for unit.
Jan 09, 2009 | Maytag Dishwashers
Maytag dishwasher MDB7600AWW handle
Welcome
At the site below is the diagram for the door latch and assembly.
You can order there too!
W10130694 HANDLE, LATCH (WHT) (Series: 10) In-Stock $ 16.75 99003347 LATCH ASSEMBLY (Series: 10) In-Stock $ 21.80
http://www.pcappliancerepair.com/model-display.php
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 25, 2008 | Maytag MDB7100AWB Dishwasher
Broken maytag door latch assembly Maytag quiet series 300: the latch is not working, door is closed and cannot open, seems something snapped inside, how can I open the door ? and change the broken part ?
To open this latch, the handle works as a lever to push inward when you push up on the handle. If your handle if broken, it has probably ceased to work as a lever (the pivot pins have likely broken). You want to push in on the handle to open the latch, ideally toward the bottom of the handle opening. Once you get the latch open, you'll likely want to order a replacement (here is one source : http://www.repairclinic.com/PartDetail/Door-Latch/W10130694/1266678 ). Remember to turn off the power to the dishwasher, and you'll need a star head driver to remove the screws from the inside of the door to access and replace the latch.
Andrew
Nov 17, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Maytag
If the door handle appears loose, you could have a broken door latch which will prevent the dishwasher from running if the door is not able to latch properly. The latch usually has two micro switches that are pretty delicate. Not to accuse you of abusing your appliance, but if you're in the habit of slamming the dishwasher door shut, you could inadvertently break the switches in the door. The switch assembly and handle are sold separately, so you may need to purchase both. Let me know if this helps.
Jul 08, 2007 | Maytag PDB3600A Built-in Dishwasher
Maytag MDB7100AWB Dishwasher Logo
704 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
