Question about Gateway Computers & Internet
Gateway ML6232 laptop will not, boot, hard drive not recognized in bios, keyboard locks when attempting to navigate to hard drive to change setting
  • 46 Answers
First thing to try is the manufacturers diagnostic software.if that doesn't work try the ultimate boot cd
http://www.ultimatebootcd.com/ it is free and has a lot of utilities for hdd diagnostics. if you still can't get a definitive answer i would say you have a faulty logic board.
Posted on Apr 23, 2009
Boot screen drive dvd key
Did you made any harware changes to your laptop lately? I suggest you press f2 or F12 immediately at the startup. This will open up the BIOS configuration. Navigate to boot devie priority and locate your hard drive. Put it on the 1st priority and hit F10 to save changes and exit. Once the computer restarts the sustem will try to boot from the Hard drive..
Regards
David
Sep 18, 2013 | Acer Gateway 15.6" Laptop PC NV56R14U-US...
Now What can i do to get my Bios to recognize my Hard drive ? I took Drive out Hooked it to USB adapter And i could see files open files ,On reboot USB attempts to boot and i see Windows XP screen but,...
here is a software available to back up and make the hard disk recognised by the mother board.you can still do it by installing a fresh copy of windows xp
Apr 03, 2012 | Gateway Computers & Internet
I turn on laptop and it says need boot up disk. I do not have a boot up disc
Email Microsoft about your problem and they will most likely send you a replacement.
http://support.microsoft.com/ph/14019
Jul 29, 2011 | Computers & Internet
Gatewat CX2724 original HD died (Hitachi 100GB @5400RPM) I just installed a brand new WD 250GB @7200RPM. Since I didn't have the original recovery disk I'm trying to install a full version Windows XP...
if you have a new hard drive you will have to install the windows operating system from an external source such as a cd drive
go to bios --boot settings and change from 1st boot hard drive to 1st boot cd
install the win os and then you can install the rest
when finished go back to bios and -boot and change back to 1st boot hard drive
Apr 24, 2017 | Gateway CX2724 Notebook
I forget the hdd password
to remove the hdd password do the follwing
1) Restart your computer. Note that during computer restart, the screen goes blank for 3 to 5 seconds. Text then appears and the operating system boots up.
2) As soon as the first text lines appear on the screen, press the "Del" key on your keyboard to enter the BIOS setup
3) Navigate to "Security" in the BIOS menu using the arrow keys on your keyboard
4) Navigate to the option "Hard Disk User Password" and press "Enter
5) Navigate to a hard drive, press "Enter" and select "Disable" to remove the hard drive password.
6) Press "F10" to save and exit the BIOS settings. Computer booting resumes.
this will remove the hdd password
Jan 15, 2011 | Computers & Internet
My gateway 2118u netbook will not boot or turn off the screen says: For Atheros PCIE Ethernet Controller v2.0.0.9(05/08/09) Check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable...
Can you access your BIOS when you turn on the computer?
Somewhere in the BIOS you may have inadvertently changed the netbook to boot from the "Network via PXE" instead of from your local hard drive.
To enter the BIOS, you must restart the PC and enter BIOS setup or BIOS features by pressing Delete or another hardware specific key on BIOS screen startup.
From there, you should encounter a series of menus that you can navigate only with the keyboard... not the mouse. With luck, you will find a boot menu option that you can correct.
Make sure you save your choices on exiting and restart your PC. With a little bit of trial and error, you should be able to coax your netbook to boot from its internal driver.
Sep 09, 2010 | Gateway LT2001u Netbook
Gateway 200ARC goes to "Last Known Good Configuration" screen
try reseating the dvd drive and then go into the BIOS to be sure that the drive is being recognized. Actually go into the area of the BIOS that shows the name of the dvd drive that it recognizes.
It it does recognize the dvd drive properly then try other boot cd's. It still may not recognize them.
If so try another known good dvd drive in the laptop and if you have the same problem then take out the hard drive and then see if the system will boot up off of the dvd drive then. If it still doesn't boot then the motherboard is bad.
If it does boot then that means the new hard drive is bad and shorting out the dvd drive controller on the motherboard and the hard drive would need to be replaced.
Hope this helps clear up things for you and sorry for not responding sooner.
Ben
May 18, 2009 | Gateway 200 ARC Notebook
Replaced harddrive and dvdroom wont recognize in bios
Goto bios menu. And change the setting on hard drive and cdrom. It could be it still set in the old configuration. Try to set it in auto detect. Then save the setting. Then goto bios once again to check if the settings doesn't change. Restart again and wait if something you didn't expect still happens.
Leave a comment if this solve cd rom detection.
May 12, 2009 | Gateway M-6750 Notebook
Change boot sequence for HP L2000
You need to enter BIOS at startup. The correct key to press will be displayed at the bottom of the black screen when you bootup. Usually, F10, F8 or F11 or Del. Mash them all on booting up.
Now navigate the Bios settings with the arrow buttons and select cdrom as 1st boot device with the enter button. Then Save and Exit.
Fixya!
Chris (ziraffa)
Jan 10, 2009 | HP 418446-001 - HP Special Edition L2000...
Computers & Internet Logo
533 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
